If you go to settings -> sensors , is it not in there? Also try HWINFO64. I have a Sapphire Pulse RX 570 8GB and all the sensors for Power use are there.I'm using RX 570 4 GB. However, the GPU-Z program does not turn on the power consumption section in the sensors section. I wonder why?
In mine it's called "GPU only power draw". Or "Chip power" in HWINFO64. It's the same reading that the Performance monitor in the driver reads so I assume it's actually the board power. (The GPU also throttles when this number reaches the card's stated board power, which in my card is 135W at stock but I limit it to 95W).Is using another name instead of 'power consumption' was previously used nvidia GPU 'power consumption' was the name.
For my RX 570 yes that is correct. I've not owned an NVIDIA GPU in a long time so i don't know what's in theirs. So I'm assuming the TDP /TBP is based on that numberNvidia = power consumption
AMD = GPU only power draw ?
System Name | Good enough |
Processor | AMD Ryzen R9 7900 - Alphacool Eisblock XPX Aurora Edge |
Motherboard | ASRock B650 Pro RS |
Cooling | 2x 360mm NexXxoS ST30 X-Flow, 1x 360mm NexXxoS ST30, 1x 240mm NexXxoS ST30 |
Memory | 32GB - FURY Beast RGB 5600 Mhz |
Video Card(s) | Sapphire RX 7900 XT - Alphacool Eisblock Aurora |
Storage | 1x Kingston KC3000 1TB 1x Kingston A2000 1TB, 1x Samsung 850 EVO 250GB , 1x Samsung 860 EVO 500GB |
Display(s) | LG UltraGear 32GN650-B + 4K Samsung TV |
Case | Phanteks NV7 |
Power Supply | GPS-750C |
