I have a rx 570, an it suddenly crashed when watching a video
since then the amd driver interface fails to open, it says that my gpu is not recognized, gpuz and afterburner show clock and memory speed stuck at 0 (gpuz displays other information accurately) and videogames and high resolution videos render at low framerates (games run at like 3 fps)
I have tried uninstalling drivers using ddu and amd cleanup utility and installing many driver versions and it keeps giving the same error message when trying to open amd driver interface
I have also tried:
-Booting on linux ( I loose video signal when trying to boot)
-flashing gpu bios (I got dual bios, both give me the same error, flashed one and the issue persist)
is it posible that both bios got corrupted at once when the issue started?
-Booting on linux from a pendrive (also loose video signal when trying to boot)
my specs: Rx 570 saphire nitro plus 4gb, asus h81md, psu evga 600 ba, 8gb ddr3 ram, i3 4130 cpu
could a defective mobo cause the issue?
is it most likely a gpu hardware problem?
(already testes psu using a multimeter and it display correct voltages)
I have also tried:
