RX 5700 Performance Issues?
118 (0.03/day)
Australia
System Name Gladiator
Processor i7 7700k (Kaby Lake) 4.2-4.4ghz
Motherboard Gigabyte Z270m-D3H
Cooling Exhaust fan: Corsair - CPU: Coolermaster liquid
Memory Kingston Hyper-X Fury 16GB DDR4 @3200mhz
Video Card(s) Asus 2060 Dual OC
Storage WD 1TB 450ssd
Display(s) Samsung 23inch curved@ 1080
Case Cougar 330G
Audio Device(s) Logitech 5.1 Stereo
Power Supply Antec 650w Gold
Mouse Logitech G300S
Software Windows 10 64bit
Hi there, I'm not too familiar with amd cards but I've recently bought a RX 5700 dual evo. I'm not too sure if these monitoring graphs are correct but the card gpu power seems low when I play Assassins Creed Odyssey for an example and the gpu is not recognised in the in-game performance tool. Also the memory clock seems a little off. I'm noticing significant drops in frames too. The Gpu usage goes very high also in the menu, and even with 80-90% usage power draw goes from 70-80w.
I'm hoping this image might help, cheers. And don't worry about the low fan speed, I fixed that up. The curve was too low. But gpu power still doesn't go too high.
Specifications :
i7 7700k
Antec vp550w psu
16GB Ram
RX 5700 Dual Evo
Coolermaster ml240
1TB hdd
240gbssd
19,375 (3.51/day)
Looks like you have some form of vsync stopping your FPS at 60. Check in game... GPU settings, etc.
118 (0.03/day)
Australia
Case Cougar 330G
I'm using a 60hz monitor so I just have adaptive vsync on in the settings to stop stutter and screen tear. But I'm not sure why the gpu doesn't come up in the performance bar. There are only a bunch numbers?
Run 3DMark FireStrike and post a screenshot of your scores.
Running the demo but this is what it came up with. Would the fact that I'm running it on a pcie 3.0 have much of an impact or not really?
Regeneration
NGOHQ.COM
3,136 (0.45/day)
According to the UL database, your card is operating within normal parameters. Performance should be slightly higher.
Are you running this VBIOS?
118 (0.03/day)
Australia
Case Cougar 330G
I'm going to assume you mean overclocking or unlocking it? No just running it as normal. I'm running it on pcie 3.0 if that makes much of a difference? I don't know much about pcie 4.0. But if its as you say then it's running normally
19,375 (3.51/day)
pcie 4.0 doesn't make a difference with that card.
296 (0.06/day)
System Name Gaming PC/ EDU PC/ HFS PC
Processor Intel i9-9900KF/ Dual Ryzen 7 2700X
Motherboard Asrock Z390 Taichi Ultimate/ Dual Asrock X370 Proffesional Gaming
Cooling Noctua NH-C14S/ Arctic Xtreme Freezer/ Ryzen Wraith Prysm RGB
Memory 64GB Corsair Vengeance PRO RGB 3200/ 32GB Corsair Dominator 3000/ 16GB Corsair Vengeance Pro 3200
Video Card(s) EVGA RTX 3080 FTW3 Ultra / MSI RTX 2080Ti Ventus / EVGA GTX 1060 SC Gaming
Storage Dual 970 EVO Plus 1TB + 6Tb 860 EVO/ 960 EVO 500GB + 18Tb R0/ 840EVO 250Gb + 16Tb R0
Display(s) Samsung 32" U32R590 Curved 3480x2160 / Samsung 32" LC32H711 Curved 2560x1440 Freesync
Case Cooler Master Stacker 830 NV Edition/ Dual Cooler Master 690 Advance II
Audio Device(s) Creative X-Fi Surround 5.1 SBX/ Creative X-Fi Titanium Pci-E/ On-board Realtek
Power Supply Triple Corsair Platinum HX850i
Mouse Logitech G7 WL / Logitech G903 Lightspeed / MS BT 8000
Keyboard Dual Logitech G19s
Software Win10 Pro
assuming you are using vsync or other sync to your 60hz monitor, and thats why your gpu is not at 100% load. Leave it that way, else it will show more fps which you cant see on your monitor and it will operate at higher temperatures...
19,375 (3.51/day)
No clue, but performance doesn't appear to be an issue...
118 (0.03/day)
Australia
Case Cougar 330G
Alright then, thank you for all the clarification! Much appreciated!
7,412 (2.70/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
you gotta have an adaptive sync compatible monitor, turning on adaptive sync in windows on a fixed refresh monitor does nothing
