RX 5700 XT not booting
Martylegrand
18 (0.02/day)
Hi everyone!!
I purchase a used Saphire pulse 5700xt, and when I plugged it, I have a black screen... I know the rest of the system is OK cause when I put my 1060 6g back in, it is ok.
I use DDU to uninstall all the olders drivers (amd ans nvidia), and it it dont work.
I use the motherboard integrated graphics, and in the device manager I can see the card.
I downloaded AMD Adrenalin with the driver for my card, and it always freeze (in safe mode too) halfway...
I read a lot on the subject, and decided to try flashing the GPU bios. But I have always the same 0FL01 error and on top of that "newer rom already installed"...
I tried to flash the second BIOS too, but I had no success
Thanks
41,740 (6.60/day)
Where did you buy it from?
Wrong bios will brick cards
Hi everyone!!
Thanks
Martylegrand
18 (0.02/day)
I bought it on ebay for really cheap (I knew it was unfunctionnal)
I know that a wrong Bios will brick the card, but it can be unbricked , I juste want to know how haha
Thanks
1,891 (1.47/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
@eidairaman1 posted this short video on another post:
Take a look there.
41,740 (6.60/day)
Yeah I saw it , but I am able to boot the system with the MOBO graphics (safe mode) with the GPU plug in... can i flash it this way? I will try to short the 1-8 pins for sure
Thanks
You can flash it but You will need to pull the heatsink and get a ram chip pic and a pic of the sku and p/n sticker on the heatsink, usually on the side of it.
Also buying nonfunctioning gpus is a crapshoot.
Martylegrand
18 (0.02/day)
By RAM chip do you meen the bios chip (8 legs chip like in the video above)? If so, heres the pictures
41,740 (6.60/day)
1,891 (1.47/day)
Romania
In the attached picture taken from that youtube clip, i highlighted the VRAM chips.
Take off the thermal pads at least from one chip and make a clear picture where we can see the correct code from that chip.
Martylegrand
18 (0.02/day)
Okok thank you!! I will check it out later
8,146 (3.93/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
I'm currently running 24 RX5700 at home 24/7/365 with zero failures after about 30 card-years of operation. Have another 100+ 5700XT at work in daily use by staff with zero failures.
I cannot say the same for RTX 20-series cards, already had to RMA a Gigabyte 2080Ti and couple of Palit 2070S from a sample size of only 60 cards.
Even my sample sizes aren't good enough to call solid, but that's about 200 cards so with a 1-2% typical RMA rate, I ought to have seen at least a few dead Navi cards by now, and I have not.
1,891 (1.47/day)
Romania
Martylegrand
18 (0.02/day)
Hello
Here you have :
Its one of the three, or I have to try them all?
Thanks
Hello
Here you have :
I already try thoses BIOS drivers, (2 of them) and it always shows the same thing : "0FL01 error" and on top of that "newer rom already installed"
Heres my process:
- create a BIOS flash drive
- download the AMDVBFLASH 4.68 (DOS)
- Download the the good BIOS flash
- format the USB flash drive
-put the BIOS.rom on flash drive
-restart PC and BOOT it in flash drive
-when its ready, type : AMDVBFLASH.exe
-when its ready type : AMDVBFLASH -f -p 0 BIOS.rom
- Newer rom already installed 0FL01 Error
what am i doing wrong?
thanks
41,740 (6.60/day)
Radeon 5000/6000 known for high GPU defect rate
not reliable cards
Bullshit, get lost troll
From afterwarranty repair center
Not proof
Thanks
Heres my process:
thanks
You need to pay attention to my directions, you are using the wrong tool yet again.
GET AMDVBFLASH 2.93.
Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to sp57xt.rom
4. Move sp57xt.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
8. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked"
9. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 sp57xt.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0)press enter.
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on screen.
Martylegrand
18 (0.02/day)
Not proof
So, I did all you said and the command prompt said to restart. So I stopped it, I unplugged the DVI cable of my integrated mobo graphics, and plug the hdmi in my 5700 xt. Turn on the PC, and nothing. The VGA light of the mobo was solid white like before (when it.dont boot) .
So I plugged back the DVI in the mobo, and tried to install the drivers of the card with Adrenalin. Like before, the process is freezing halfway.. I let it do its things?
Thanks
Martylegrand
18 (0.02/day)
This is what my pc sees.
I know it is in french , but I think you can understand
Martylegrand
18 (0.02/day)
And this is when I flip the bios switch. I try to flash this one too?
41,740 (6.60/day)
1,891 (1.47/day)
Romania
What ? Both BIOS-es from your card are wrong ?
Who flashed them ? And for what purpose ?
Martylegrand
18 (0.02/day)
Probably for mining... my question is: if the secondary bios is bricked, can it cause my problem?
Also, does a hard reset of my mobo can help? (I updated the bios already)
Thanks
41,740 (6.60/day)
Thanks
Yes you need to get the 2 bios from impero
Martylegrand
18 (0.02/day)
So now the two Bios are identical.
It didn't work, so I did a Hard Reset on the MOBO. I didn't reinstall the newest drivers
Didn't work either ....
Like before, when it try to boot up on the GPU, the VGA light on the mobo stay solid white and the screen didn't even turn on...
When I try to install the drivers, it freeze at exactly 50% (with adrenalin)
I try the 1-8 pins technic?
41,740 (6.60/day)
Try another bios
