RX 580 8gb Phantom gaming overheating?
twitchvictim
8 (0.00/day)
I recently built a pc i5 9800F 16gb 2666mhz ram and Phantom gaming rx580 8gb. Was surprised how well it handles most of games I throw at it. However I am facing an issue with card temperature, every time I am in the game, the temperature of the card goes up to 85-87 degree. (keep in mind that card is like 1 week old and bought as brand new). I did notice that the fan speed goes up to 68%, didn't try to push it to 100% yet.
My question would be is there something wrong with these temps? If so, what could be the issue considering that card is brand new? Therefore, is it bad for fans to work on 100% all the time?
I did not do any overclocking, the air flow in case is quite decent with lots of fans. Temperature in my room is also not high at all. Used MSI afterburner to monitor all the temps. Any comments would be appreciated guys.
sneekypeet
not-so supermod
29,667 (4.32/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
twitchvictim
8 (0.00/day)
sneekypeet
not-so supermod
29,667 (4.32/day)
System Name EVA-01
My room temperature Is like 19-22C, if not even lower. Yes, the card in your link is exactly the one I have
I should also mentioned that even in Idle the temp of the card would be around 42-45C
There will be some variance in card temperatures, even with the same model. I do not see that 6 to 8 degrees over his testing to be that big of a deal. Of course, I run a 2080ti with an FE cooler, and its hot as balls when fully loaded.
twitchvictim
8 (0.00/day)
Would it be okay if I manually set my fan speed up to 100% for every time I begin gaming session? I mean I don't mind the loudness as long as my card stays cool
sneekypeet
not-so supermod
29,667 (4.32/day)
System Name EVA-01
If you don't mind the noise, have at it. Would make your life easier if you just set a fan curve in something like MSI Afterburner. This way you can game without the need to manually change things. It will ramp when temperature thresholds are met in the software.
853 (0.32/day)
Asia
Processor Intel Core i5 4590
Cooling Intel Stock Cooler
Power Supply Corsair VS450
Mouse A4Tech N-70FX
What case??
8,226 (2.14/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
MSI Afterburner is what you need to create and adjust the fan curve.
43,378 (6.75/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
Its a typical rgb case, airflow is bogus on them. Get fans that exhaust quicker and intake, better off removing side of case and blowing fan in
3,776 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
Improve the case's air flow if possible. You may have low ambient/room temp but that does not mean the case has also low internal ambient.
Plus this is a slightly OC model with an overvoltage as well (1340Mhz -> 1380MHz / 1125~1150mV -> 1175mV). You can try with MSI Afterburner to undervoltage it, about 10~20mV for start. Mine stays at about 1131mV (1360MHz) by default.
And as others said you dont have to mess with your fan every time you stress the card. Create a fun curve to your liking.
2,963 (0.82/day)
Long Island
Well A FE card runs about 78C at full load OC'd so ... any balls that hot are certainly sterile
sneekypeet
not-so supermod
29,667 (4.32/day)
System Name EVA-01
twitchvictim
8 (0.00/day)
if I downgrade the voltage a bit, should I downgrade the clock as well? Also, will there be a noticible downgrade in performance?
3,776 (1.91/day)
No if not necessary. Just begin with -15~20 and test/game alot of different benches/games for 1~2 days. dont rush it.
Always with afterburner...
Copy all those...
And here all the green stuff...
Mind that afterburner sets the voltage in specific steps (GPU or VRM requirement) and you cant change by 1mV at a time. Mine goes like 0, -6, -12, -18 and so on...
lolipita
1 (0.00/day)
If you are still here or get to see this reply this is my settings rx580 asrock 67 degrees 71 max
9,689 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Or use Radeon relive and let AMD auto undervolt your card.
Fearless_23348
1 (0.00/day)
Hi, i didnt crash or anything? cause i tried it and squares of pixels appeared in my screen and then i restart the pc, not your config
