Rx 580 starts to thermal throttle at 70C
Skizi
6 (0.16/day)
I recently noticed that my gpu rx 580 4gb starts to thermal throttle at only 70C. I have no idea why this happens and I already tried to keep my card under 70C but its impossible. I have undervolted it and put my fan speed higher to no use, I average ~75C, haven't seen it go higher than 77C. However before I knew what undervolting was I had the card at default settings and it was thermal throttling at over 80C.
1,673 (0.28/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
Couple of questions:
  1. Does the fan work normally?
  2. Does the cooler make proper contact?
  3. Is the cooler dust free?
  4. Did you try a repaste?
  5. Are you using a stock bios?
  6. Which brand and model card do you have?
  7. Can you make a picture of your card?
Skizi
6 (0.16/day)
1.The fan does work normally yes
2-4. The temperature is fine. The issue is that it starts to thermal throttle way to soon. Like dialling down the clock speed.
5.Yes
6.Asus dual oc: https://www.bhphotovideo.com/c/product/1336822-REG/asus_dual_rx580_o8g_radeon_rx_580_8gb.html this but 4gb
7.I don't think that is needed
1,774 (0.61/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 in RAID 0+ HDD 500Gb +Samsung 128gbSSD +SSD Kinston 480Gb
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
Can you see the temp of the hot-spot on the GPU because sometimes hotspot could be much higher than the overall GPU temp and it will cause thermal throttle......also can you check your GPU VRM temp this will also cause your GPU to throttle if it's to hot.....
Skizi
6 (0.16/day)
unfortunately I cannot check those
1,673 (0.28/day)
Can you please make a picture of the PCB?
Can you also share the output of GPU-Z (Graphics card tab + Advanced tab -> AMD Bios)
41,479 (6.58/day)
Skizi
6 (0.16/day)
I see it says there target temp 70C I think that's the issue
41,479 (6.58/day)
I hate to burst your bubble but the asus dual/mining are bare bones bottom tier cards, they will be limited in tdp.
1,673 (0.28/day)
Yeah but I was not thermal throttling at 70C like a year ago
The thermal paste can be up to 7 years old on that card. It can also cause some issue since thermal performance will become less due dry thermal paste.
I see multiple waranty stickers on screws which doesn't seems the orginal. Normally a manufacturer will only place one (small) sticker.
Did you buy this card second hand?
Skizi
6 (0.16/day)
Yeah but if the thermal paste was indeed old it would've had much worse temps in my mind. From what i've seen other people say this same model they get on avg 80C.
As for buying I bought this card 1 and a half years ago from a local store with extra warranty. Might be an explanation for the stickers
8,027 (3.91/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Target temp is suggested by BIOS but can be overruled by drivers.
If you haven't ever flashed your BIOS then remove all graphics drivers with DDU and try a clean install.
41,479 (6.58/day)
When you mention extra warranty, how much longer is it?
