(FIXED) RX 580 XFX GTS XXX 8GB at 1100 MHZ instead of its default 1257 mhz clock speed
ShadowGGGZXZ
5 (0.12/day)
Hello guys can somone tell me whats the problem with my rx 580? it is defaulted to 1100 mhz clock instead of 1257 mhz
my specs MSI B350M GAMING PRO motherboard
AMD RYZEN 5 2400G
16GB OF CORSAIR VENGEANCE DDR4 3200MHZ RAM
Samsung SATA ssd 256gb
500GB NVME SSD from Gigabyte
3,754 (0.87/day)
System Name Skunkworks
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software openSUSE tumbleweed/Mint 21.2
DO you have any GPU tuning software installed E G afterburner? Post a screenshot of GPU-Z when running a GPU intensive benchmark. What GPU driver are you using?
2,622 (4.50/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / Viewsonic VX3276-MHD-2
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
This isn't the 3rd party software, it's a mining BIOS which is plain obvious due to VRAM speed. 2120 MHz is very odd despite being even.
Find the original BIOS file and flash it. NB: you MUST have a backup GPU for that to be safe.
1,665 (0.28/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
AMD RYZEN 5 2400G
500GB NVME SSD from GigabyteView attachment 359678
I think your card has a bios switch. Did you move the switch to the mining bios?
Its seems to be a valid mining bios from XFX themselves.
When changing the bios switch to the other position, this bios will be likely loaded.
ShadowGGGZXZ
5 (0.12/day)
i moved the switch to the gaming one and its still on 1100 mhz
ShadowGGGZXZ
5 (0.12/day)
i even tried flashing it maybe i did something wrong,what flashing tool do i need?
1,665 (0.28/day)
Are you the first owner of this card?
If it worked normally before did you try to move the switch back and forward a couple of times? Could be the switch is no longer making proper contact internally.
Otherwise it could be both bios switch position contains a mining bios....
What did you use? AMDVBFlash 2.93? Can you share the part number on the card itself?
ShadowGGGZXZ
5 (0.12/day)
Thanks man i used vbflash 3.31 it restored my gpu to its default clock 1386 mhz now i dont get artifacts or any driver crashes anymore thx so much you all!
