RX 6600 Weird Noises
lOphis
4 (0.04/day)
This GPU has a lot of that noise I forgot the name, when it's being heavily used (that noise people say it's pretty common on AMD GPUs).
And now, I also noticed THIS noise while the GPU is idling (I'm almost sure it's coming from the GPU). Should I be worried?
13,905 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Coil whine?
3,196 (1.06/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Nonsense, the AIBs making video cards use the same PCB components to make Nvidia and AMD cards. The only difference is the GPU die itself which isn't the source of coil whine.
It's a roll of the dice if you get coil whine and how bad it is. My 4090 is vastly worse than what I can hear in the video.
6,734 (3.04/day)
California
System Name His & Hers
Storage lots of SSD.
Had to try 3 different 4090s to get one without coil whine and def just a lottery although I found it comical that out of Asus, MSI, Gigabyte the Giga card has almost 0 you have to put your ear right next to it when it's pushing 500+ fps but on the Asus and MSI card you could hear it from 5 feet away.
I can deal with loud fans any day but coil whine hell to the na na.....
Not Gonna Happen No Way GIF by FaZe Clan
To the OP it's normal just annoying AF.
409 (0.25/day)
System Name Old friend
Processor 3550 Ivy Bridge x 39.0 Multiplier
Memory 2x8GB 2400 RipjawsX
Video Card(s) 1070 Gaming X
Storage BX100 500GB
Display(s) 27" QHD VA Curved @120Hz
Power Supply Platinum 650W
Mouse Light² 200
Keyboard G610 Red
353 (0.93/day)
did you run benchmarks to stress and see if the whine was there or as soon as you started using it the whine was audible?
is the whine strnger with more stress on the gpu or all the time, same level?
6,734 (3.04/day)
California
Tied to framerate and I do play games that exceed 200fps but both models I tried were audible starting around 100fps.
lOphis
4 (0.04/day)
Coil whine?
Yup, but is this needle-like noise also a, like, lighter coil-whine? Lol.. Cuz I never heard it before, it's indeed a very low noise, and I just happened to notice it by coincidence. If it's just a coil whine, as people are saying, then I'm ok with it.
Yup, but I never heard it before, and GPU was just idling.. lol (I really wasn't playing anything for at least 30 minutes, and only browser was opened). I didn't know this needle-like was also coil whine, since I only know coil whine as that very loud, static-like noise, which yep, is annoying af.
3,196 (1.06/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
I can't with 100% confidence say it's coil whine, I was just pointing out the fact that GPU brand shouldn't matter when it comes to coil whine.
I amplified the volume of your YouTube video to the max with Audacity before clipping kicks in and am listing to the video with a ridiculously overpowered amp and from what I can hear it's either coil whine or some other noise that's the result of vibration (typically the fans generating the noise directly or vibrations causing the case to generate noise). You could always open you case and try to see if you can't directionally pinpoint the source of the sound.
The potential sources of unwanted sound in a PC are 1) fans (both the sound of the air moving and vibrational noise) 2) coil whine 3) HDD
I didn't hear a HDD in the clip so I'm going to assume we can eliminate that.
You can eliminate fans as a potential source by either unplugging them, setting them to 0 RPM is software / BIOS, or by pressing on the fan hub with your finger. If the noise persists, it isn't a fan bearing noise or resulting vibrational noise.
In terms of coil whine, the GPU is almost always the source. There have been cases of motherboard VRM coil whine but they are vanishingly rare.
Honestly it's hard to tell just how loud your unwanted noise is given how quiet the video is and even when amplified the fan whirling noise appears to be quite a bit louder. Are you getting higher pitched noise as well? YouTube tends to remove higher pitched noises at the edge of human hearing as they tend to be unwanted and it saves bandwidth.
1,101 (3.40/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Most of the time my cards make the PSU audible for coil whine. Are you sure to have pinpointed the card being the issue? The coils are rather small and don't typically become audible.
8,041 (3.91/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Sounds like coil whine and it's normal.
Typically it's only audible when your GPU is rendering something at a few hundred FPS. Vsync should reduce or eliminate the noise.
It's a bit of a crapshoot - cards will whine in some PCs and not in others, making me think the PSU, the motherboard, or both are contributors.
Sometimes coil whine can get picked up by onboard audio circuits and amplified through your speakers/headphones - so using a USB audio device solves that particular component of the problem.
lOphis
4 (0.04/day)
Thanks guys... I really ain't hearing the same sound today, but if I ever hear it again, I'll try to confirm better where's it coming from... I'm quite sure it was the GPU though, cause I approached my ear near it, and could hear it better, but I'll try to confirm for real next time.
Edit: I just opened my browser (Opera GX) to post this reply, and the noise was there again... It's coming from the GPU indeed... Really weird how opening my browser triggers it, imho.
6,833 (1.47/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
As long as not spooky sounds. You should be fine.
8,041 (3.91/day)
Case Veddha T2
Mouse MX Anywhere 2
You got a high-refresh monitor?
If so, three (four) options for you:
  1. Reduce desktop refresh rate to 120Hz or lower
  2. Disable hardware acceleration in your browser
  3. In the Radeon driver, setup a "game" for Opera GX's exe and enable a frame-rate limit.
  4. (Just ignore the noise, it's not doing any harm)
3,196 (1.06/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
Could be the hardware acceleration browsers typically enable that's triggering it. Technically your video card is always producing noise, it just that certain workloads tend to push that noise into the audible human hearing range.
lOphis
4 (0.04/day)
Thanks a ton man. Limiting the framerates actually worked like magic. Awesome!
41,483 (6.58/day)
Coil whine?
I hear a clicking noise, like a keyboard or a fan going bad, if its a popping noise, electrical arcing can produce it.
353 (0.93/day)
easier said then done for some people who may have misophonia. especially high pitched ones. id sell my card and get something else that doesnt whine
someone should make a log from others inputs of what cards have whine and those with less.
41,483 (6.58/day)
Makes no difference, please reference this
To fix is to stabilize the coil, and coil whine affects both nvidia and amd.
353 (0.93/day)
it makes a huge difference. for people who want to know. also will put pressure on then 2 to make gpu and consider the whine issue. im sure once a log is out, that would be a good thing for consumers. not good for oem, but who gives a shit about oem. they dont give a shit about users. thats been proven
dont deflect. it needs to be done
gpu are ridiculous. theyre oversize, overweight, TDP is crazy high, crazy prices and coil whine. a database is important.
41,483 (6.58/day)
Never was deflecting fyi,
Whining about Coil Whine here isn't going to get their attention, go to their social media pages, create videos on youtube about it.
Please see fix below, it doesn't require a Rocket Surgeon.
@lexluthermiester
2,303 (0.49/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Sounded like a watch to me, literally. I hear what sounds like ticking.
41,483 (6.58/day)
Exactly, a tapping/clicking, which are fan bearings or a wire being hit by a fan blade, coil whine is a chirp/hum
24 (0.27/day)
USA / Europe
Processor Ryzen 5 5600X
Motherboard ASUS TUF B550 Plus Wifi II
Cooling Cooler Master Hyper 622
Memory G.SKILL Ripjaws V Series 32GB (3600MHz) DOCP II
Video Card(s) ASUS Dual GeForce RTX™ 4060 V2 OC Edition 8GB
Storage Crucial P3 1TB NVMe SSD
Display(s) ASUS TUF Gaming Monitor 23.8'
Case Corsair 4000D
Power Supply Segotep 650W 80 Plus Gold
Mouse Razer Basilisk Ultimate V3 Pro
Keyboard Corsair K70 RGB TKL
Most likely gpu fans the root of the issue. My rtx card doesnt make much noise but my amd one does at specific rpms no matter the fps. If i set the rpm to around 2000 it will make the whine, but if i set it to the max 3000 rpm, it sounds loud but no whine. I was able to get a free set of fans for my amd gpu cuz of warranty, and they still have the noise but a lot less noticeable this time around. Could also just be the design of the card, doesnt have to be the fans.
