RX580 2048SP issues
8 (0.16/day)
Belgique
System Name Main
Processor AMD Ryzen 7 5800X3D
Motherboard ASUS Strix B550-E Gaming Wifi
Cooling Arctic Freezer III 280mm ARGB
Memory 4x8Gb DDR4-3600 CL18 Corsair Vengance Pro RGB
Video Card(s) Gigabyte RTX 4070Ti Eagle
Storage Samsung 990 Pro 1Tb + Samsung 970 EVO Plus 2Tb
Display(s) Asus PG279Q
Case Fractal Design Define R6 TG USB-C
Audio Device(s) HyperX Cloud Flight
Power Supply Corsair RM850X
Mouse Corsair M65 Pro
Keyboard Corsair K70 RapidFire
Hello !
First of all, sorry for my bad english, I speak French :D
I have 2 identical RX 580 2048SP (6pin) :
The first one : weird colors at startup and during boot (windows logo), but no issue on logon and after.
The 2nd one : black screen for post and boot but ok on logon and after.
The 2 cards show the same GPU-Z informations.
Here are some additionnal details :
GPU AMD M75MR.00
215-0876406
Memory Samsung 025
K4G80325FC HC25
Maybe a vbios issue ?
Thanks
1,814 (0.30/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
Hello !
GPU AMD M75MR.00
215-0876406
Memory Samsung 025
K4G80325FC HC25
Thanks
Are you sure both cards have identical vbios installed? It sounds like different vbioses
8 (0.16/day)
Belgique
System Name Main
Hello
In the GPU-Z panel, the Bios version is the same.
1,814 (0.30/day)
Hello
Bios version number doesn't say anything at all. Please check the "Video BIOS Collection" on this site and you will notice the same bios version is used for multiple cards.
Please make a vbios dump of each card and share it here.
8 (0.16/day)
Belgique
System Name Main
Hello,
Here are the 2 bios files, I don't know how to read it :)
  • Ellesmere.rom
  • Ellesmere2.rom
1,814 (0.30/day)
Hello,
Ellesmere.rom contains Samsung K4G80325FB and Hynix H5GQ8H24MJR memory support
The first dump has the same SHA checksum as this bios: https://www.techpowerup.com/vgabios/237747/237747
Ellesmere2.rom contains Micron MT51J256M32HF memory support
The second dump has the same SHA checksum as this bios: https://www.techpowerup.com/vgabios/257628/257628
Based on the bios dumps, those cards are physical not identical since they dont have the same memory.
The following bioses will likely work on both cards:
When flashing, you must use AMDVBFlash 2.93. Please follow the flash instructions below.
For RX 500 Series (Polaris) and Older:
Get amdvbflash 2.93
Then look for Version 4.68, underneath 4.68 you will see a link to show older version, click that and you should see version 2.93
Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to 5 digits with .rom on end Example RX 580, change file to rx580.rom (r****.rom)
4. Move r****.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
8. Type in amdvbflash.exe -i to identify the gpu you want to flash with a 0, 1, or 2)
9. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked" (or 1, 2)
10. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 r****.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0).
(Or 1, 2)
Press Enter
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on screen.
8 (0.16/day)
Belgique
System Name Main
Thanks for help, I'll try that !
The fact that my memory chips of the first card are Samsung K4G80325FC instead of K4G80325FB isn't a problem ?
I've tested the suggested vbios.
RX #1 (Samsung memory)
original bios : weird colors until logon, then ok, score 3DMark ok.
Bios #1 : weird colors all the time.
Bios #2 : no signal.
Bios #3 : weird colors all the time.
Back on original bios at this time.
RX #2 (Micron memory)
original bios : no signal until logon, then ok, score 3D Mark -20% than average (GPU +/- 800Mhz).
Bios #1 : weird colors until logon, then ok, score 3DMark -15% than average (GPU +/- 900Mhz).
Bios #3 : weird colors until logon, then ok, score 3DMark -20% than average (GPU +/- 800Mhz).
Stay with bios #1 at this time.
1,891 (1.44/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Well if you have FC for sure you won't use FB bios.
You must use the BIOS that will match your card's ID, subID and memory type.
Anything else would brick it.
42,143 (6.63/day)
Ah yes the typical chinese market weak 580.
1002 6FDF 1002 0B31.
The bios files you use must specify what ram is written in the file.
When the card has Samsung FB, FC, FD, FE etc, or Micron HF, HFB, or Hynix AJR, MJR, or Elpida ram, the file must match the specific ram, you can't use a Samsung FB bios on a card that has FC ram etc.
8 (0.16/day)
Belgique
System Name Main
I've checked the memory on the RX #2 :
Micron 0QB77D9VVR
I don't see anything else.
1,814 (0.30/day)
Sorry my bad for the wrong Samsung support. The original bios which you shared with us mentioned K4G80325FB instead of K4G80325FC which you had listed in your starters post.
Please try this bios on both cards. RX570 has the same performance as a RX580 2048SP bios.
This bios might also be interesting:
Micron 0QB77D9VVR
You need to decode the FBGA Code => https://www.micron.com/sales-support/design-tools/fbga-parts-decoder
The second card has Micron MT51J256M32HF
8 (0.16/day)
Belgique
System Name Main
Thanks for the help, but unfortunately, black screen for the 2 suggested bios !
42,143 (6.63/day)
1,814 (0.30/day)
Did you try the other display outputs on the graphics card?
42,143 (6.63/day)
This is for your samsung fc card
42,143 (6.63/day)
And nothing
8 (0.16/day)
Belgique
System Name Main
Hello! Sorry for the delay. I’ll try it when I have time! Thanks ;)
8 (0.16/day)
Belgique
System Name Main
1,814 (0.30/day)
Can you upload your working Samsung bios here? It might help us with looking for a beter match
42,143 (6.63/day)
