RX580 mining VBios
weebeey
1 (0.01/day)
Hi all,
I have been looking at this site for almost a week now but I can't really figure out how these VBios files versions work. Please point me to the right direction, I don't wanna brick a card just random testing.
I have 5 RX580 cards mining on HiveOS. They have a hashrate of 10-13MH/s on Kawpow. They should have something like 14-16MH/s so I suspect I have a gaming VBios instead of mining VBios.
How do I know wich VBios I have? And how do I know which VBios to flash instead? There is like a 1000 VBios files for RX580. If I have a mining VBios already on one card, can I use the same on all other cards?
If there is a guide or a thread already explaining this, please kick me in the right direction.
1,780 (0.29/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
I dont think you will get much support here since this isn't a mining forum.
Couple of methods you can try:
Method 1: Put the graphics card in a normal Windows system. If the bios is modified, the bios signature is fucked up due the bios editing and will not load the driver in Windows.
Method 2: Make a dump of the bios and compare it on binary with a stock bios in the Video BIOS Collection.
Method 3: Make a dump and use a bios editior to see if the voltages/memory timings are changed.
3,480 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3667MT/s 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (375W current) PowerLimit, 1060mV, Adrenalin v24.10.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2161), upgraded from Win10 to Win11 on Jan 2024
Hi all,
In order to get the max hashrate and minimum power usage the RX580 must lower core clocks to about 1100MHz, core voltage to about 0.8~0.9v and increase VRAM clock to 2000-2200MHz + tighten timings (depending VRAM chips).
