RX580 No Display Flashed as RX590 Restore BIOS help
Boomz
4 (0.00/day)
Hi! All,
I got a Sapphire Nitro+ RX580 4GB Graphics card from Ebay.
It works as system boots fine caps lock works fine but I get no display output from Display port, HDMI or DVI on both BIOS switches.
Putting an old spare HD7750 into the primary PCI-E and the RX580 in the 2nd PCI-E I can see in device manager it says its an RX590 but is a 580 so it looks like the Bios has been flashed incorrectly
I downloaded GPUZ and it does say its a RX590 under both BIOS's and both show exactly the same info and it on both BIOS's wouldn't let me export the BIOS or click the UFEI I get error message "Bios reading not supported on this device"
I downloaded the BIOS from Techpowerup and tried to use AMDVBFLASH under administrator to update the BIOS but I get the "error reading from ROM" error which I guess it's going to be from reading the primary HD7750 card.
I have included a screenie of what its shows as in device manager, the GPUZ error and AMDBVFLASH error. I've also included the label from the card to confirm what it is.
I don't know if I'm missing something or doing something wrong but there a way around this so I can update the BIOS back to the correct one as I think it will be fine with the correct BIOS onboard.
Thanks again in advance for any help
Boomz
4 (0.00/day)
Anybody able to help me with this please, stuck on how to update the bios with the RX580 as the 2nd display
6,364 (0.87/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Boomz
4 (0.00/day)
Thanks Assimilator
Did A ddu unstaller and it looks like it helped
Windows version of amdvbflash still doesn't work have the same error. Using the command line version as Administrator and got little bit further.
It won't work in 1st slot so have it in the 2nd slot I can see both cards now in amdvbflash at the command line.
I disabled it in device manager and rebooted already.
It has the BIOS details below on both switches
asic : Polaris10
flash: R600 SPI
romsize: 10000
test: fail
bios p/n: -
I've unlocked the rom at the command line successfully & tried load the rom again using amdvbflash -f -p -1 romname but no joy says
Failed to read ROM
ERROR 0FL01
Anybody had this before ?
Boomz
4 (0.00/day)
Am I going to have to do the 1+8 Method on this ?
Does anybody know where the Bios chip(s) are located on the Sapphire Nitro+ RX580 4GB ??
