Ryzen 3700x with ASROCK B450 Steel Legend ATX MotherBoard
47 (0.03/day)
Hello I about to upgrade to ryzen 3700x and
And 2*8 gb ram s3200
Will I face any problem with the processor and motherboard as I heared that I must update bios to make processor work
1,638 (0.99/day)
Check whether it'll come with the Ryzen 3000-ready sticker:
On another note, I would recommend against the 3700X. The 3600XT is both cheaper and has better single-thread performance, the 3600 is just the value-town, and the 3900X has 50% more cores, depending on your usage scenario.
RAM should be fine; I'd recommend 3,600 because of IF scaling, but some people have reported issues with that speed.
633 (0.13/day)
System Name Smooth-Operator
Processor AMD Ryzen 7 3800x
Motherboard Asrock x570 Taichi
Cooling AMD Wraith Prism
Memory 2x16GB 3200MHz CL16@CL14 DDR4
Video Card(s) Sapphire Radeon RX 580 8GB NITRO+
Storage 2x4TB WD HGST 7K6 7200RPM 256MB
Display(s) Samsung S24E370DL 24" IPS Freesync 75Hz
Case Fractal Design Focus G Window Blue
Audio Device(s) Creative X-Fi Titanium PCIe x1
Power Supply Corsair HX850 80+ Platinum
Mouse Gigabyte Aorus M3
Keyboard Zalman ZM-K300M
Software Windows 10 x64 Enterprise/Ubuntu Budgie amd64
If you already own the motherboard then yes, to make it support new cpus you have to upgrade bios to version supporting this cpu, otherwise new cpu will not be detected and will not work.
47 (0.03/day)
Thanks for replying guys so If I mange to upgrade the bios or it already has the 3rd gen sticker I will not face any problem with this two
633 (0.13/day)
Check bios version you have applied on motherboard, go to asrock motherboard's page, check if your version of bios supports the cpu. If it does then you are ready, if not then update bios to version supporting this cpu. General rule is latest bios version supports latest cpus.
191 (0.09/day)
The Heart of Dixie
System Name Forgal
Processor Ryzen 7 5800X
Motherboard Asus RoG Strix X570-E Gaming
Cooling Arctic Liquid Freezer II 280
Memory 4x16 GiB Crucial Ballistix PC4-28800, 16-18-18-38
Video Card(s) MSI Suprim Liquid GeForce RTX 4090
Storage 2 TB ADATA XPG SX8200Pro + 4 TB S860 + NAS
Display(s) Asus RoG Swift PG42UQ + LG 32UD99-W
Case Fractal Design Define 7 Compact
Audio Device(s) Audioengine HD3 + S8
Power Supply Super Flower SF-1000F14TP Leadex V P130X-1000 Pro
Mouse Razer DeathAdder 2
Keyboard Leopold FC900R OE mx-brown
I’ve been using the B450M Steel Legend with a Ryzen 5 3600X since the beginning of March. Unless your supplier has some really old stock without a recent BIOS, you should be fine.
Note that with this motherboard (and others from ASRock) you’ll want to run the Fantastic tuning routine in the UEFI BIOS to establish the lowest speeds that your fans can run before you set up custom fan profiles.
47 (0.03/day)
Thanks guys now I want u opinion in something is that
I get the Ryzen 3700x with ASROCK B450 Steel Legend ATX MotherBoard
Or get
Ryzen 5 3600 with motherboard GIGABYTE B550 AORUS Elite
And safe some money to upgrade my body case
Most of my using gaming and some times I work at maya program
555 (0.16/day)
In the middle of nowhere
System Name Scrapped Parts, Unite !
Processor Ryzen 5 3600 @4.0 Ghz
Motherboard MSI B450-A Pro MAX
Cooling Stock
Memory Team Group Elite 16 GB 3133Mhz
Video Card(s) Colorful iGame GeForce GTX1060 Vulcan U 6G
Storage Hitachi 500 GB, Sony 1TB, KINGSTON 400A 120GB // Samsung 160 GB
Display(s) HP 2009f
Case Xigmatek Asgard Pro // Cooler Master Centurion 5
Power Supply OCZ ModXStream Pro 500 W
Mouse Logitech G102
Benchmark Scores Minesweeper 30fps, Tetris 40 fps, with overheated CPU and GPU
I wouldn't recommend B450 Steel Legend, as its widely known with poor VRM, you cant go wrong with any of decent MSI board like B550 A Pro/Tomahawk Series
1,638 (0.99/day)
Get the 3600 and some other stuff. Given the current pricings, the 3700X makes absolutely no sense at all.
47 (0.03/day)
So the 3600 will be good for me as I heared that the 3700x with extra 2 cores better in multitasking and in render in programes like 3dmax and maya
191 (0.09/day)
The Heart of Dixie
System Name Forgal
I wouldn't recommend B450 Steel Legend, as its widely known with poor VRM.
How relevant are any voltage regulation differences if you're not trying to push a bleeding-edge overclock? If the motherboard is designed to handle a 16-core Ryzen 9 3950X, then an 8-core Ryzen 7 3700X at stock speed shouldn't challenge it much.
2,715 (0.57/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
What are you going to use the processor for?
555 (0.16/day)
Cooling Stock
Display(s) HP 2009f
Mouse Logitech G102
even for normal usage without any overclocking in mind, it's still objectively bad board when compared to similarly priced board that have much better VRM. You spent same amount of money that otherwise that could be spent on higher quality board.
2,259 (0.99/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
i have a Aorus B450 elite and have used it with a 2700x for two years running cpu@4.2, ram @3400 and a 1080 @2100 without any problem at all, i do have a fan on the VRM but its just for piece of mind i have a p5 case which is open so i like to make my own airflow.
heres a pic to show vrm cooling.
241 (0.14/day)
System Name Yin/Yang
Processor Ryzen 7 3700x
Motherboard msi mag x570 tomahawk
Cooling CoolerMaster ML240V2 / asiahorse fs9002 120mm fans
Memory 2 x 16gb g.skill trident z neo 3600
Video Card(s) msi gaming X 2070 super 8gb
Storage 1tb sabrent rocket nvme / 1tb samsung evo 860 sata ssd / 3tb Toshiba hdd
Display(s) lg ultragear 2560x1440 144hz 1ms 27"ips
Case nzxt h510i
Audio Device(s) logitech g635 / creative sound blaster
Power Supply evga supernova 750ga 80 plus gold
Mouse logitech g402 hyperion fury
Keyboard corsair k55
Alot of people disagree with you, myself included. You can look at the numbers but 3700's are selling like hot cakes. Alot of people don't want to put 6 cores in a brand new modern gaming system the consoles are coming out soon with 8 cores and i think that will be considered the new "baseline" if you will, rather soon.
Edit* i see the price has gone up by almost 20$ since i bought mine a month and a half ago? meh, maybe you're right...the 2700x looks pretty good to me now for $60 less
1,638 (0.99/day)
Now, if only multithread game (engine) developement was so easy ... oh, wait. I very much doubt that 6 cores will bottleneck any gamer anytime soon.
Just because (a lot) of people choose something, doesn't mean that this is the correct/optimal choice. Quite besides, going by sales volume the 3600 beats out 3700X so ...
241 (0.14/day)
Case nzxt h510i
no you have a point, the thing is with the market as over-saturated as it is right now small changes in pricing can make certain options look less appealing rather easily. for example when i bought my 3700x not only was it almost 20 cheaper, but I'm pretty sure the 2700x was also slightly more expensive. As far as the whole multi thread developement thing, like i said as soon as both consoles are released i would have to think that's pretty heavy incentive for devs to start leaning that way wouldn't you? In other words alot of people aren't buying for what they feel is optimal now but rather what will likely be optimal in the near futue.
1,638 (0.99/day)
You aren't necessarily wrong obviously but fundamentally, making something like a video game utilise multiple threads is quite the opposite from a trivial task - it will take many years until we'll see a game that can fully utilise all 8 cores to their fullest. Quite besides, given SMT and all of that a game that runs on 8 cores should also be able to run (at a reduced performance) on 6.
Realistically, the only games that will ever be able to take advantage of all those cores are (heavy) simulations.
2,259 (0.99/day)
south wales uk
VR uses all the cores thats why i build that rig but not untillized 100% yet but ive checked with fallout 4 VR and halflife Alyx uses all 16 threads at about 70%.
1,638 (0.99/day)
What happens (performance wise) when you turn two of the cores off?
2,259 (0.99/day)
south wales uk
i havnt a clue, i wouldnt want to do that :). it would prob increase utill. im a bit bottle necked with my gpu.
