Ryzen 3950X Build Help
1,098 (0.16/day)
System Name Beaver's Build
Processor AMD Ryzen 9800X3D
Motherboard Asus TUF Gaming X670E Plus WiFi
Cooling Corsair H115i RGB PLATINUM 97 CFM Liquid
Memory G.SKILL Trident Z5 Neo DDR5-6000 CL30 RAM 32GB (2x16GB)
Video Card(s) NVIDIA GeForce RTX 4090 Founders Edition
Storage WD_BLACK 8TB SN850X NVMe
Display(s) Alienware AW3225QF 32" 4K 240 Hz OLED
Case Fractal Design Design Define R6 USB-C
Audio Device(s) Focusrite 2i4 USB Audio Interface
Power Supply SuperFlower LEADEX TITANIUM 1600W
Mouse Razer DeathAdder V2
Keyboard Corsair K70 RGB Pro
Software Microsoft Windows 11 Pro
Benchmark Scores 3dmark = https://www.3dmark.com/spy/51229598
I'm going to do a new build around the 3950X on the X570 Platform. What motherboards do you recommend? So far i'm looking at the ASUS X570 Crosshair VIII Hero.
I also need RAM recommendations.
So far i've already got the following components:
RTX 2080 Ti FE
Inland 1TB NVMe M.2 (Phison E12 Controller)
Samsung 950 Pro 512GB NVMe M.2
Corsair AX1200 PSU
Corsair H115i RGB AIO Water Cooler (Hope it's compatible ?)
1,098 (0.16/day)
Perhaps wait for 3950X to actually get released?
What's the point of "building" something with a non-existing part ?
do you think we'll see a new line of motherboards related to the 3950X release?
584 (0.25/day)
No but I do think there will be a bunch of reviews done on different boards once it gets released.
Right now the closest you can get is to look for reviews of 3900X, but it doesn't mean it will be the exact same thing.
AMD delayed that chip for a reason, and that reason might be binning... they just don't get enough "best quality" chiplets to build them 3950X'es
2,285 (0.79/day)
Tanagra
System Name Mac Pro 2013
Processor Xeon 2667v2
Motherboard A collection of mother and daughter boards connected by ribbon cables
Cooling Thermal core triangle
Memory 64GB ECC DDR3-1866
Video Card(s) Dual FirePro D700 6GB
Storage WD NVME 1GB
Display(s) ASUS Pro Art 27"
Case Apple Cylinder
I think you don’t want to get parts too soon, cause if you run into trouble, you have less time to troubleshoot and return parts.
7,746 (3.28/day)
California
System Name His & Hers
Storage lots of SSD.
I agree with wavetrex. Wait till you can actually buy the cpu and then decide on a motherboard.
That being said all of the high end boards will handle it no problem Asrock Gaming X, Aorus Master, Crosshair VIII, Meg Ace.... The slightly cheaper Taichi will also handle it just fine from a Vrm perspective.
I would just go with whatever your preference and I/O needs align with the most.
I'm really liking the Master but a couple of people on the forum are having issues with it unfortunately.
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
The 3900X is hard to get, you will not get a 3950X anytime soon!!!You can get a 3900X but you'll pay the same price as a 3950X.
1,098 (0.16/day)
584 (0.25/day)
what about RAM then being considered ahead of time?
3600 MHz?
Keep your money in the bank ahead of time.
There is no way of knowing, really !
Maybe 3950X can work with 4000 Mhz RAM with 1:1 IF speed (2000 Mhz), something that the already released ones cannot (they top out at 1900)
Also, by the time 3950X is on the market, more memory models might launch, and prices could vary a lot.
However, I'm almost convinced that the best DIMMs will still use Samsung chips, that can do CL14 at 3600 without breaking a sweat. That Corsair you linked is C18 ... eww.
I really don't understand why waste your brain effort with something that doesn't exist yet ?
1,098 (0.16/day)
Getting excited for the 3950X i guess is why the waste of the brain effort...
CL16 and CL14 get extremely expensive :( to almost double
scope out my current situation:
130820
3,984 (1.10/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
Why would you buy the most expensive CPU possible, gpu possible, and then skimp on the ram?
Toothless
Tech, Games, and TPU!
9,761 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Pointless thread until the chip is released. No one can recommend anything of value (no offense to anyone but no one knows the performance of the 3950x)
1,098 (0.16/day)
almost 600 (or double the price for CL14) seems quite a bit for what seems not much difference in performance unless i'm wrong :-\
6,782 (1.36/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
Ram speed barely affects performance. Cpu and gpu will net you more performance per dollar spent than ram ever will.
Edit: I mistyped memory instead of gpu. It was corrected.
11,025 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
Plus with ryzen even low speed ram, if you crank the timings down you will get 95% there. linus has some benches of tightened 2133/2400mhz kits getting the same fps as 3600 c16/ 3200 c14 in his memory deep dive.
3,984 (1.10/day)
System Name Wut?
Processor 3900X
Cooling Water
Ram speed barely affects performance. Cpu and memory will net you more performance per dollar spent than ram ever will.
I'm confused.
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
1,098 (0.16/day)
I am not sure why you are confused but you should read the tpu memory scaling performance. https://www.techpowerup.com/review/amd-zen-2-memory-performance-scaling-benchmark/
This does seem to indicate a lot, ~5% gain for 3600 @ CL17 compared to 2400
3,984 (1.10/day)
System Name Wut?
Processor 3900X
Cooling Water
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
9,704 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
The need for high memory clocks is indeed exaggerated. After 3200mhz you're in the diminishing returns realm.
3,984 (1.10/day)
System Name Wut?
Processor 3900X
Cooling Water
It has been corrected.
My point is: You are spending stupid money already. What is another $100? You'll get 5 to 8% improvement.
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
More like 1-5% improvement by the review I linked. I personally bought fast memory because cpu speed is important to the workloads I do. I bought a 3600mhz Cas 18 kit and overclocked it to Cas 16.
Another $100 could be a month of food for someone. It just depends.
Another $100
18,140 (2.45/day)
This is my $89 (equivalent local price converted) RAM. It's running way beyond my expectations and rated spec.
This is on a 3800X though, so you'd get higher writes on a 3900X or a 3950X.
Just FYI, a lot of people have reported having issues with Corsair RAM and Ryzen 3000. I also tested my old RAM, which was Corsair and it would not run at its rated speed of 3200MHz on the same setup.
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
I am running corsair ram. Although I am running it faster than stock, I am having issues.
