Ryzen 5600 PBO Enabled (120* Watt) + Deepcool AK400?
Rise
1 (0.00/day)
Hi all,
I've just upgraded to Ryzen 5600 and paired it with Snowman X4 Cpu Cooler which was supporting me with my previous build on Ryzen 1500X.
Now I know that Cpu cooler is not great but its better than stock cooler. I was wondering if I buy something like Deepcool Ak400 will it make significant difference in terms of temperature? I dont really want to spend more money on high end cpu coolers like ak620 since its a lot more expensive in my country. (also I am not sure if it fits my case)
I am currently using my 5600 with pbo + 100 enabled. Curve Optimizer -30 -30 -20 -30 -30 -20. At full load it draws 100-105 watts.
And these are temps on Cinebench benchmark:
r/PcBuild - Ryzen 5600 PBO Enabled (120* Watt) + Deepcool AK400?
If i want to use pbo + 200 enabled. Curve Optimizer -30 -30 -20 -30 -30 -20. At full load it draws 120-130 watts.
Cinebench Benchmark Temps:
Also Idle Temps seems quite high when PBO enabled (50 C on 46 Watts). I dont know if its because of the cooler or just a Ryzen 5000 thing.
So in conclusion how much Ak400 benefits me in terms of temperature here? Do i need to buy high end cooler if i want to use this CPU with PBO enabled or is it overkill?
PC Specs
CPU: AMD Ryzen 5600
Cpu Cooler: Snowman X4 https://www.amazon.com.tr/Snowman-CPU-Soğutucu-Fan-Rainbow/dp/B098K4D166
MOBO: Asrock B550m pro4
RAM: Corsair LPX 32 GB CL18
GPU: 3070ti Palit Gamerock
Case: Dark N10 https://www.dark.com.tr/computer-co...m-fan-fan-kontrolculu-pencereli-atx-kasa.html
Case Product Page says:
First of all you need to specify the ambient temperature where your computer is running. Your numbers would be great in a 35C room, not so much at 18C.
Generally speaking I see nothing scary with the first numbers. But I would leave the +200 alone because that is overheating.
Your computer will benefit from a better cooler, especially if you want to push PBO further. But as long as you don't push PBO to hard, it is not a required upgrade.
