- Jan 12, 2023
- 381 (0.45/day)
System Name | IZALITH (or just "Lith") |
Processor | AMD Ryzen 7 7800X3D (4.2Ghz base, 5.0Ghz boost, -30 PBO offset) |
Motherboard | Gigabyte X670E Aorus Master Rev 1.0 |
Cooling | Deepcool Gammaxx AG400 Single Tower |
Memory | Corsair Vengeance 64GB (2x32GB) 6000MHz CL40 DDR5 XMP (XMP enabled) |
Video Card(s) | PowerColor Radeon RX 7900 XTX Red Devil OC 24GB (2.39Ghz base, 2.99Ghz boost, -30 core offset) |
Storage | 2x1TB SSD, 2x2TB SSD, 2x 8TB HDD |
Display(s) | Samsung Odyssey G51C 27" QHD (1440p 165Hz) + Samsung Odyssey G3 24" FHD (1080p 165Hz) |
Case | Corsair 7000D Airflow Full Tower |
Audio Device(s) | Corsair HS55 Surround Wired Headset/LG Z407 Speaker Set |
Power Supply | Corsair HX1000 Platinum Modular (1000W) |
Mouse | Logitech G502 X LIGHTSPEED Wireless Gaming Mouse |
Keyboard | Keychron K4 Wireless Mechanical Keyboard |
Software | Arch Linux |
Hi all,
New to the forum (hello), not new to IT but am new/returning to high performance computing and hardware has never been my strong suit. I recently built my first gaming rig in ~10 years in Oct '22 (I have worked entirely off laptops since then) and I am hoping someone can give a layman an understanding of the 7700X and the "95C is the new normal" meme. I've tried my best to understand it from my own research but it's hard to work out what is correct and incorrect.
To summarise my understanding:
- When put under heavy load, the 7700X will immediately clock up and push to 95C (or as close to as it can) and stay there without throttling. Presumably throttling would start if it exceeds this temp?
- 95C is the "TJMax" of the CPU, TJMax being the max operating temperature of the chip (which older chips would normally begin to throttle at).
- TJMax is different to the max SAFE operating temperature and is not putting the chip at any risk. Older chips throttle to prevent reaching damaging temperatures.
- TJMax is a completely arbitrary temp set by the manufacturer.
- Degradation and/or damage to the chip wouldn't occur until much higher temps (I can't find anything from AMD specifically but I see a lot of people mentioning 125C?).
Have I understood the "new normal" correctly?
