Ryzen 7 7800x3d Cooling Problems
sospicyy
4 (0.40/day)
hi guys, i made a build last week and im noticing right now that my temps are kinda high.
I have mounted a ryzen 7 7800x3d with a thermalright 360 notte, with a total of 9 fans (two in the bottom, three on the diagonal, three on the radiator, and one in the back) my case is the h9 flow by nzxt.
My idle temps are between 55-65 degrees and with 10m of cpu stress test with cinebench and the 100% load i reached max 81.8 celsius. Yesterday i was playing at microsoft flight simulator and i noticed that my temps peaked 81.8.
I am sure that my thermalpaste is placed correctly and that there arent any stickers/plastic pieces on the radiator pump. Am i ok with that or i should maybe change radiator?
304 (0.59/day)
System Name Can it run Warhammer 3?
Processor 7800X3D @ 5Ghz
Cooling Enermax Liqmax III 360mm
Memory Teamgroup DDR5 CL30 6000Mhz 32GB
Video Card(s) Gigabyte 4090
Storage Silicon Power XS70, Corsair T700
Display(s) BenQ EX2710Q, BenQEX270M
Case NZXT H7 Flow
Audio Device(s) AudioTechnica M50xBT
Power Supply SuperFlower Leadex III 850W
What is "idle" for you? All background crap closed? Your idle temps seem more like light load temps.
Your cinebench temps are completely fine, mine runs about the same, as does TPUs review unit.
8,604 (3.23/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Did you remove the plastic cover for the block?
dgianstefani
TPU Proofreader
4,840 (1.98/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+, TOFU-R CNC Alu/Brass, SS Prismcaps W, Jellykey, Lube/Mod, TLabs Leath/Suede Wristrest
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
AM5 chips run hot because they're dense and the heatspreader isn't great.
82 C is below throttle point so you don't have anything to worry about.
Toothless
Tech, Games, and TPU!
9,513 (2.49/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
This is all normal for these chips. My X3D will skyrocket to 86c if I keep a full load on it for a while, but it never gets "hot" in day to day or games. You have nothing to worry about.
11,351 (5.49/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 4 + 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Your idle temp is quite high (are you sure nothing is running in the background?), but 81 °C at load is perfectly normal.
3,374 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 163W PPT limit, 80C temp limit, CO -8~12
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~466W (366W current) PowerLimit, 1060mV, Adrenalin v24.7.1
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSBuild 22631.4169), upgraded from Win10 to Win11 on Feb 2024
Almost any Ryzen CPU will peak north of 75C eventually.
And its more likely to reach 75~80+C on low loads and gaming than full (100%) CPU load.
With default settings that is.
For example my 5900X is peaking usually at 77-78C but under full load max temp is under 70C.
Peak temp is like spiking briefly, like frequency is spiking to max briefly. Those going hand to hand and its normal. High frequency bursts are happening so fast that the "produced" heat doesn't have time to reach the cooler. Heat dissipation needs some time to pass from core die to CPU heat spreader, to cooler cold plate and fins... and eventually to water/air
The peak °C you see under normal usage or gaming is probably not the temperature of the entire Core Die (CCD). There are small parts into the CCD that get hotter than others.
At least from Zen2 Ryzens are reporting those hotspots.
X3Ds are hard-er to cool because of the extra layer above the classic 8-core CCD.
If you run any full CPU load then I bet the temp will settle lower.
89C is your CPU max operating temp. If you get peaks at 80~85C but the average overtime is lower, you are more than fine.
Your idle temp is looking a bit high but that depends on your system settings on how true idle it is, and how fan rpm are curved with temp.
If you are willing to dig into your CPUs operating conditions then HWiNFO64 is your best friend
Other than temperatures you can look A LOT!
Like CPU core C-State Residency (States of cores)
C0: Active state
C1: Sleep/Parked state
C6: PowerDown state
Average Active Core Count: how many cores are active on any given time
PPT is whole CPU package power draw (Watt)
CPU usage
...to name a few
This screenshot below is 12hours mixture of normal every day usage and "idling".
To me all sensor readings have some value depending on what you want to see. And also min/max/avg values.
You can leave it on your tray running and use your system. The more you leave it the better.
If you want to see it during gaming sessions, click the clock down right and go into the game. When finish gaming (at least 1hour) take screenshot, save it and then you can study it.
For more accurate readings go to main settings (tray icon) and:
6,619 (3.01/day)
California
System Name His & Hers
Storage lots of SSD.
C0: Active state
C6: PowerDown state
CPU usage
...to name a few
Also I'm not sure how accurate Tdie is anyways on ryzen 7000 seems amd set a large buffer to keep the silicon at a specific temp. They moved it with 9000 to make it more accurate allegedly.
Op Idle temps are slightly high but even just moving the mouse can jump you 10-15c on Ryzen. 81c is pretty normal on a 7800X3D on a CB load all 5 that I've worked with sat in the 78-83 range after an hour of blender on a 360 aio so yours is basically right dab in the center.... Without knowing your ambient and how good that aio is you sound fine.
I agree with others above there are plenty of data points of ryzen behavior it will boost to a specific temp right up to the thermal limit if allowed and every board is slightly different in behavior. Unless you are consistently over or near 85C it's a non issue if it bothers you set a lower thermal limit or lower your TDP.
3,743 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
sospicyy
4 (0.40/day)
yeah im sure, 13% of cpu usage with only brave open, my mins are 51.3 celsius and max 66.5, i dont really know why
Mounting problem.
can you be a little more specific please? It's my first build and I may have made some mistakes, but I installed the computer without problems, and the thermal paste seems good to me
379 (0.50/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
Well, the thermal paste that Thermalright gives you is meh at best, I used MX6 on mine. It also seems that you do not have the plastic cover on as the working temps seem too low, but I have seen it happen.
When you instilled the pump on the CPU, did you tighten the two screws with the springs until they had a hard stop? You do not need allot of force to do this, just go slow with the screwdriver while tightening them. I would check the other two brackets that mount on the motherboard as well, and make sure they are tight.
The other thing I would do, is enable PBO and do a negative under volt. It will make the CPU run cooler and clock higher longer.
Tech Yes City PBO Video
Level1Techs BPO Video
Ancient Gameplays Under Volt
Edit: Make sure that you have the pump power plugged into the correct port on the motherboard, and you have it set correctly in the BIOS. I would also setup a curve for the pump and fans.
2,671 (0.42/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Same CPU here and 43C idle temp. Cinebench goes up for me too to about 82C.
I bought an Noctua D15 G2 aircooler and used the included offset mounts for optimal baseplate position for new AMD CPUs. The offset mount kit is good to have (not a must) since on the AMD CPUs the dies under the heatspreader are somewhat in the south position and not middle.
559 (0.11/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Creative AE-9 w/ Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
Your temps are fine. Mine will spike to 82C on occasion and I have an open loop on mine with a 4090. As others have said, it will keep itself in check. No need fixing what isn't broken.
8 (0.14/day)
Processor Intel i5 12490f
Motherboard maxsun B660M Terminator
Cooling DeepCool AG500
Memory Kingbank 3200Mhz C18 16G*2
Video Card(s) PowerColor Radeon RX6950XT Red Devil
Storage Hikvision C4000 2TB & Zhitai SC001 1TB & Sandisk HR3 2TB
Display(s) DIY 27" 2K 170Hz (Innolux K7E fastIPS Panel)
Case SAMA blackhole 1
Power Supply Segotep Kunlun KL-1250G
Mouse VGN Dragonfly R1
Keyboard Hyeku X3 Pro
This situation is fine, many of the 78x3D have the same temperature status as you, so don't need to worry about that. I have seen lots of Ryzen 7000 series idle temperatures around 55℃, most users don't know what programs are running in their background.
11,351 (5.49/day)
Midlands, UK
13% usage is not idle. Idle is 1-2%. Something seems to be eating away your CPU's power. I'd monitor that if I were you.
1,571 (1.82/day)
G-City, UK
System Name AMDWeapon
Video Card(s) Powercolor 7900 GRE Red Devil
Case Montech 903 MAX AIR
Audio Device(s) Corsair void wireless/Sennheiser EPOS 670
Mouse Glorious Model D l Pad GameSir G7 SE
Keyboard Redragon Vara K551P
Software Windows 11 Pro 24H2
Benchmark Scores Fast Enough.
Mine hits 85C in CineR23 with air cooling. But as I have been told, these chips are designed to be hitting those temps.
3,743 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Cpu with high idle is telltale sign of a bad mounting, ie. in your case your aio's cpu block. Idle should be around 30c w/o load, putting ambient aside. With a higher ambient that could swing upto 40c but even so you're into the 55-60s.
11,351 (5.49/day)
Midlands, UK
Yeah, but a 13% CPU usage is not idle. That's basically one core in full blast. I think that's the problem here.
Edit: Also, Zen 5 idles a bit warmish, especially with high speed RAM and a high VSOC. Around 40-45 degrees is quite normal.
6 (0.60/day)
Motherboard Gigabyte B650E Aorus Master
Cooling Antec Vortex 360 ARGB
Memory 64GB G.Skill Trident Z5 Neo RGB 6000C30
Video Card(s) MSI Geforce RTX 4090 SUPRIM X 24G
Storage 2 x 2TB Samsung 990 Pro + 4TB Crucial P3
Display(s) MSI MPG 271QRX QD OLED @ 360HZ
Case Antec C8
Power Supply MSI MPG A1000G PCIE5
I think that as long as your idle/low-load temp is within spec and is not thermal-throttling the CPU then you should not worry about it. You should really only care about it if you're having issues during intensive applications and high-load scenarios. I have my 7800x3d at 40-42c at low CPU load because I prefer having the fans in my case to be whisper quiet, only when I launch a game or something do they pick up and the temp stays in check to prevent thermal-throttling.
3,374 (1.84/day)
Mounting issues can be a lot of stuff.
Not correct tightening, wrong paste application...to name a couple.
But before you get into that and re-do installation other aspects need to be investigated first like...
Show us please a full screenshot of HWiNFO64 like what I've shown on previous post and also a task manager one like this:
You want to get to the bottom of this, you have to show us what we ask and answer questions we ask.
We dont have any crystal balls here that we can magically know what is happening
We spend time to think and write regarding your concerns.
sospicyy
4 (0.40/day)
ok thank you so much guys
that should be all, ty for the reply
8,604 (3.23/day)
Cooling In Win SR36
freeagent
8,163 (3.73/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I am not seeing anything that jumps out. temps arent that high, and look relatively stable. CPU has not seen very much load at all, so no heat. The potential for spiciness is there though..
sospicyy
4 (0.40/day)
i also used the mx6 from arctic, my pump is mounted into the cpu_opt slot in the mobo, and the screws should be tightened pretty good. I also got pbo enable at level 2 80. i was thinking about doing an undervolting
yeah thats why im asking, i thought that my aio wasnt mounted correctly, i just realized that my ring on the cooler can be the cause of the high temperatures, take a look at the photos it seems that it isnt fully in.
Solaris17
Super Dainty Moderator
26,579 (3.81/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
You have it in CPU opt but your rpm show your sys fans are at like 800rpm. The CPU fan is higher which I’m assuming are your rad fans going to the cpu fan header. This isn’t right though. You should ramp that pump up.
also please stop double posting. Edit your posts.
Edit: see if you can go into bios and modify the CPU_Opt header. If you can try maxing it out and see if those readings change. You should not touch the controls for your fans at all.
