Ryzen 7 7800X3D Issues
13 (0.03/day)
Processor Ryzen 7 7800X3D
Motherboard B650M Pro RS Wifi
Cooling Cooler master
Memory 2 x Trident Z5 DDR5 16GB @6400
Video Card(s) 2060S Super
Storage 1 x SSd, 1 x HDD
Display(s) Some facebook marketplace monitor thats been working for years
Case Generic Case
Audio Device(s) Artics 7
Power Supply 750 W
Mouse Superlight
Keyboard K555
Software Win 10
Benchmark Scores https://www.userbenchmark.com/UserRun/67161985
hi guys, below are my specs. My pc is stuttering hard every minute or so and benchmarking in the bottom 20% on UserBenchmark. (I benchmarked multiple times and this was the best it ever was https://www.userbenchmark.com/UserRun/67161985) Now I know people are not fans of this site so i also downloaded cinebench and everything benched fine.
with a 2060 Super.
Also I have 32 gigs of ram, i just took one out for troubleshooting when i took this screenshot
What do??
331 (0.80/day)
Mile High City
System Name Keds
Processor 5600X3D
Motherboard Gigabyte X470 AORUS ULTRA GAMING
Cooling Corsair H100i
Memory 32 GB Team Force DDR4 3200 CL16
Video Card(s) Power Color RX 7900 XT Red Devil
Storage 2x 1TB SSD / NVME
Display(s) AOpen 27in 1440p 170hz (27HC5UR)
Case Modified Corsair 540 Air
Audio Device(s) Logitech G35 / Corsair HS80
Power Supply EVGA 850GQ
Mouse Corsair M65
Keyboard Corsair Strafe Silent
Software Win 11 Home (Modded)
Benchmark Scores It will beat a snail in a down hill race.
Well, looking at your specs. You have a top tier CPU, paired with a few generations old, bottom tier GPU and to top it all off. Your running your games on a mechanical hard drive.
So, the stutter could be caused a few things. The slow hard disk drive, since it is not able to provide data to the system as a reasonable rate.
Also, depending on the game, it could be stuttering due to poor performance of the GPU, since it is a few years old now.
888 (1.13/day)
System Name Lenovo slim 5 16'
Processor AMD 8845hs
Motherboard Lenovo motherboard
Cooling 2 fans
Memory 64gb 5600mhz cl40
Video Card(s) 4070 laptop
Storage 16tb, x2 8tb SSD
Display(s) 16in 16:10 (1920x1200) 144hz
Power Supply 270w psu
The OP has a SSD, maybe the games is installed on it.
13 (0.03/day)
Case Generic Case
Power Supply 750 W
Mouse Superlight
Keyboard K555
Software Win 10
The games are installed on the SSD, the HDD is for my videos / movies I have downloaded. I recently upgraded from a i7 - 9700k to my new Ryzen along with a new motherboard and new ram. Regardless though, the freezing is happening outside of the games so I don't think the drives are the problem.
ir_cow
4,818 (0.80/day)
USA
It says your have a single stick of 16GB. With moderns Windows OS and all the apps, that could be a cause. Running out of memory and its going to HDD Temp.
Other thing you could try is go into windows power settings and change it to high performance.
13 (0.03/day)
Case Generic Case
Power Supply 750 W
Mouse Superlight
Keyboard K555
Software Win 10
While I like to try the "change hardware and see if Windows adapts if it can" route first, since often times it can these days, what did you do here? Was Windows installed fresh or is this the installation from before?
Is the BIOS up to date?
Fresh install of windows. BIOS version is in the screenshot and I believe it is the most up to date.
As mentioned in the OP, I had one stick in for testing purposes. I have both in now and I'm still having small locks. I have changed windows settings to high performance and I'll update if the locks go away / become less frequent
194 (0.06/day)
Denmark
System Name Red Bandit
Processor AMD Ryzen 7 9800X3D 5.425 1.29v
Motherboard ASUS PRIME X670E-PRO WIFI
Cooling Mo-Ra3 420 W/4x Noctua NF-A20S - 2xD5's/1xDDC 4.2
Memory G.SKILL Trident Z5 NEO EXPO 6000CL28/3000/2000
Video Card(s) Power Color RX7900XTX Liquid Devil
Storage Adata SX8200 PRO 2TB x 2
Display(s) Samsung G8 34" QD-OLED 175hz / Samsung Odyssey G7 32" 240HZ
Case Lian Li o11D Evo RGB
Audio Device(s) Apple AirPods Max
Power Supply Corsair RM1000i
Mouse Logitech G502X
Keyboard Keychron K3 Pro V2
Software W11 Pro
Have you installed the cpu cache drivers ? is it a clean install of windows ?
3,540 (1.12/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
AMD's cache driver primarily benefits dual CCD X3D cache chips as programs can benefit from favoring frequency or cache depending on their workload. The 7800X3D doesn't have that complexity and by extension doesn't require the driver to get full performance.
194 (0.06/day)
Denmark
Software W11 Pro
True , but it did help me with edge cases ( Snowrunner, Anthem(yea i know) and DiabloII Res ) with some insane stutters. Maybe it would help him
1,131 (0.79/day)
Bavaria ⌬ Germany
System Name ✨ Lenovo M75q-1 [Tiny]
Display(s) DELL S2722DGM
Software Windows 11 Pro (Debloated)
Maybe you fill out your "System Specs" in your profile first. ;) Makes things easier.
What RAM are you using? Ryzen is pretty picky about it. You should if possible only use what is listed on the compatibility list of your mainboard. Also, what PSU are you using? Might not get enough juice. You could also test to run the bench without non crucial devices connected (esp. the HDD). I personally once had random hard stutter and the issue was a faulty Molex connector where the HDD was connected to.
1,288 (1.81/day)
Processor Ryzen 7800x3d
Motherboard Asus B650e-F Strix
Cooling Corsair H150i Pro
Memory Gskill 32gb 6000 mhz cl30
Video Card(s) RTX 4090 Gaming OC
Storage Samsung 980 pro 2tb, Samsung 860 evo 500gb, Samsung 850 evo 1tb, Samsung 860 evo 4tb
Display(s) Acer XB321HK
Case Coolermaster Cosmos 2
Audio Device(s) Creative SB X-Fi 5.1 Pro + Logitech Z560
Power Supply Corsair AX1200i
Mouse Logitech G700s
Keyboard Logitech G710+
Software Win10 pro
As someone else said, list your exact hardware - what precise memory kit are you using, and at what settings ?
From what i can see in user benchmarks it looks like a gskill 6400 mhz kit optimized for intel - not a ryzen kit.
331 (0.80/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
Did you install the latest Chipset driver?
3,540 (1.12/day)
Mouse PMM P-305
VR HMD Valve Index
Software Win 10
Interesting. I'm wondering if that's due to the driver itself or to power modifications that come bundled with it.
13 (0.03/day)
Case Generic Case
Power Supply 750 W
Mouse Superlight
Keyboard K555
Software Win 10
Just installed them, also it is a new install of windows
System specs is filled out. RAM is 2x 16GB Trident Z5 @6400. I did have quite a few problems setting up the RAM so that might be the cause of all of this.
750W PSU and I tried benching the cpu after I removed my gpu, got the following - https://www.userbenchmark.com/UserRun/67162054
The guy at microcenter said this was a ryzen kit when I told him i had a ryzen cpu.
Just did. Havnt seen a stutter in the past 5 minutes so thats good...?
331 (0.80/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
Yes that good. There is no real performance increase form high ram speed on the X3D chips. I hear the 7800X3D prefers 6000 speed.. but I dont have one to confirm.
1,288 (1.81/day)
Software Win10 pro
331 (0.80/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
If you got it from Micro Center.. and it was less than 30 days. Walk back in with a smile. and say I dont want this anymore and I want to exchange it for something else. Then walk your happy ass out with the better set of memory for your chip.
13 (0.03/day)
Case Generic Case
Power Supply 750 W
Mouse Superlight
Keyboard K555
Software Win 10
What would you guys recommend? Something that is less than 6000 mhz or something that is exactly 6000 mhz? Or maybe I could underclock my current ones.
I set all my motherboard settings back to auto, and got the following
I dont understand why my MOBO wants to set my ram to 4800mhz
9,828 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
1,288 (1.81/day)
Software Win10 pro
I'd recommend returning your current kit, and get a 6000 cl 30 kit.
This specific kit
Or this one if you want rainbow vomit
331 (0.80/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
6000 MT.. Any kit will do.. lower CL if you can find it.
**EDIT** What the guy above me posted seconds before I posted. :)
1,131 (0.79/day)
Bavaria ⌬ Germany
6000MHz is the "sweet spot" for AM5, so I would get a kit of that. :) A 6000MHz kit works out of the box without tinkering around. Also make sure the kit supports "AMD EXPO".
There are tons of kits out the, pick your poison. But I personally would go for a G.Skill kit, they work exceptionally well on AMD systems. I would go for one of those kits:
F5-6000J3038F16GX2-FX5
F5-6000J3038F16GX2-TZ5N
Both of them got a very low latency (CL 30) and the price is also great. The chips on them should be the same, just pick what you like wore design wise. Personally :love: the FLARE's.
13 (0.03/day)
Case Generic Case
Power Supply 750 W
Mouse Superlight
Keyboard K555
Software Win 10
Hey all,
I went and got new ram and the problem still persists.
I got the Trident f5-6000J3038F16GX2-TZ5NR
3,540 (1.12/day)
Mouse PMM P-305
VR HMD Valve Index
Software Win 10
Hey all,
First I'd check CPU and GPU temps to ensure nothing is overheating. (HWInfo is great)
Might be a good idea to check event viewer to see if anything correlates to the stuttering.
Then I'd try running MemTest86 to eliminate RAM as a potential variable. It is possible to get 2 bad kits in a row.
Is it only your CPU that's under-performing or is your GPU as well? You can run a well known benchmark and compare scores to people with the same video card to find out.
I ask this because your PSU brand or model is not listed so I assume it's a low end model. While the capacity of 750w is ample if it's a cheap unit the issues you are experiencing can manifest regardless of capacity used.
Check drive temps and health status as well. Might want to try disconnecting the HDD (including the power cable, not just the data) to see if it makes a difference. Could be the SSD as well although that's a bit harder to test given you don't have another SSD.
In addition, sometimes Nvidia GPUs can be picky with the monitor / cable used. My friend had an issue with his 3060 stuttering / displaying artifacts only with a certain display. Thought the card was dead until it worked perfectly fine in my little test station I have. Might be wise to try a different monitor / TV and cable. I put this later on the list though because it's definitely the less likely scenario. Couldn't hurt to see if any USB device might be causing the issue as well, either by unplugging them or swappign them and / or swapping ports.
