- Jun 3, 2012
- 1,981 (0.43/day)
- Denmark
Processor | Ryzen 5 7600 |
Motherboard | Asrock B650 PG LIgtning |
Cooling | arctic freezer 36 |
Memory | 2 x Team Group T-Create Expert DDR5-6000 - 32GB - CL30 (64gb) |
Video Card(s) | ASUS Dual GeForce RTX 4070 EVO |
Storage | 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives |
Display(s) | LG 32GP850, IIyama G2470HSU-B1 |
Case | Corsair 5000D airflow tg |
Audio Device(s) | Yamaha R-N800A Syatem audio signature 5 |
Power Supply | Corsair RM850X White |
Mouse | Asus Rog Gladius III Wireless Aimpoint |
Keyboard | Corsair K70 RGB TKL Champion |
Software | Windows 11 64 bit, Free Avira Security |
Asrock B650 pg lightning
Downgraded to a 7600, memory is 32 gb 6000mhz cl 30 flare x5 F5-6000J3038F16GX2-FX5
Im interested in different memory, according to the QVL list for ryzen 7000 there is alot of 6400-7200mhz ram i can use
Internet say it's harder with 4 ram sticks but some tests say sometimes 32gb is faster, sometimes it's 64gb, the same with 2 and 4 ram sticks and the same can also be the case with 32gb 6000mhz cl 30 and 6400mhz cl 32
Forget that i like many people don't need 64 gb since im only interested in getting just a little more out of my system without having to oc above rated speed (reliable,heat)
64gb 2 or 4 ram stick (no less than 6000mhz cl 30 or 6400mhz cl 32 and so on)
32gb 6400 or 6800mhz cl 32 or mabye 34 if it's 6800mhz or faster (32gb to keep price down) vs 4 x 16 gb F5-6000J3038F16GX2-FX5 one pair for 120 euros (total 4 ram sticks)
32gb 6000mhz cl 28 is to expensive (around 200 euros, cheaper to buy 6400mhz cl 30 memory)
F5-6000J3038F16GX2-FX5 - Overview - G.SKILL International Enterprise Co., Ltd.
Designed for DDR5-enabled AMD AM5 platforms, Flare X5 series DDR5 memory is built for high performance in a low-profile design. Featuring AMD EXPO overclocking profiles for easy memory overclocking, users can easily enable overclocked performance by simply enabling EXPO in the BIOS on compatible...
www.gskill.com
