Ryzen 7600x with 2x8GB and 1x16GB is it possible to run?
PsyGab
2 (2.00/day)
I have a nonstandard ram configuration 1x16gb on one channel and 2x8gb on the second channel and was wondering if at least 5200mhz with docp timings could work for me since as of now it will crash windows everytime i load into it. And it seems to be stable at bear minimum default motherboard settings at 3600mhz LOL. (Hynix memory on 2x8 and micron on the 1x16 both are A-die both kits are rated for 5200mhz)
23 (0.21/day)
System Name Fedora Linux
Motherboard MSI X570-A Pro
Cooling 360 Arctic Liquid Freezer 2
Memory 64 GiB Crucial Ballistix DDR4-3200
Video Card(s) 16 GiB ASRock RX 7800XT Phantom
Storage Plenty
Display(s) 40" UWQHD cheap LC-Power 144Hz
Case BeQuiet! Silent Base 802 Mesh Front
Power Supply 750W Seasonic Focus GX Platinum
Keyboard Cherry MX Board 3.0S Blue Switches
Well... Since you already gave the answer, I'd say no :D
Even putting the same 8GiB-sticks times four can or cannot work at the specified XMP/EXPO-speeds. So you might get this to 4000 (or 4400) with high timings and a lot of voltage, but I wouldn't call this config a good idea in general.
7,207 (1.03/day)
Processor AMD Ryzen 7 7700 Raphael \ i5-1135G7 Tiger Lake-U
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Intel® Iris® Xe Graphics
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p
Software Win11 Pro 23H2 UK | Win11 LTSC UK / Arch (Fan)
Problem with running more than 2 sticks are the stress on the mem controller (Memory controller) in the cpu, it's more stressful for it to run 4sticks than 2sticks and running EXPO (the memory profile of your ram).
It gives a boost running dual channel over single channel but if you do it over a short period of time lets say you can only afford 1x16GB or 2x8GB now than personally I would take 1x16GB and upgrade later if you can find the same/identical ram stick to the one you already have it should make running EXPO easier without much effort but it's always recommended to buy a kit with the stick you need for best compatibility.
Remember EXPO or XMP or DOCP or whatever the memory tweaked settings are called is still an overclock and have to be validated to make sure it's stable.
8,685 (3.25/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Black Friday is coming
1,796 (0.71/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
even if ignoring AMP tweaks, running mixed chips is the problem.
amds never liked running different dies, so short of using jedec settings and testing with TM5/HCI, to confirm its stable, i wouldnt, 2x8 is enough for gaming anyway, and still allows for dual channel config.
dgianstefani
TPU Proofreader
4,906 (1.99/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+, TOFU-R CNC Alu/Brass, SS Prismcaps W, Jellykey, Lube/Mod, TLabs Leath/Suede Wristrest
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
Nah 2x8 is insufficient for many games at this point.
Even 2x16 runs into issues in certain games.
1,796 (0.71/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
not as long we dont know what games, all my stuff (nothing from the last 2-3y) works fine.
23 (0.21/day)
Storage Plenty
Thanks for the replies
Ye, I kinda figured that out. I already ordered another 1x16GB stick.
I hope the same as the other one?!
41,435 (6.58/day)
Read your motherboard manual to know what set of slots are channel a/0
and the others are channel b/1 etc
1,796 (0.71/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
not really making a difference, unless you know its identical dies.
many brands will switch between brands/tiers, one major reason i would always recommend to get a kit, unless its intel or sticks known to have specific chips.
23 (0.21/day)
Storage Plenty
You can see it on the SN. For example, my ballistix sticks have 1R and 2R versions. Since I already had (unknowingly) bought two 1R, I wanted two more 1R for dual-channel. That was decipherable via the serial number. Should be possible here too with some research.
1,796 (0.71/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
doesnt mean much, unless you remove the heatsinks and look at the actual dies.
part of the reason why ppl "hate" corsair is the fact they are one of the brands swapping dies as they wish, with sticks having identical specs/model nbrs, but using different chips or even different brands, making it troublesome to go past jedec on amd cpus.
even on those using (samsung) b-die (or equivalent), you will still have different tiers/different characteristics, and you will have a hard time matching 2 kits (for 4 sticks), as some dies will like clocks vs timings.
there is a reason why virtually all brands test/sell kits with multiple sticks, and its not just to make the purchase easier..
