Ryzen Master vs HWInfo - >5 degree difference...
168 (0.08/day)
Processor AMD Ryzen 9 3900X
Motherboard Gigabyte Aorus Master Rev 1.0
Cooling NZXT Kraken X72 360MM
Memory G.Skill Trident Z Neo 32GB (2x16GB) DDR4-3600MHz CL16
Video Card(s) Galax GeForce RTX 2080 Ti Hall of Fame
Storage Samsung 970 EVO Plus 1TB NVMe M.2
Display(s) Alienware AW3418DW 34" UltraWide QHD 120Hz IPS 1900R Curved G-Sync Gaming Monitor
Case Lian Li PC-O11 Dynamic XL Black Steel
Audio Device(s) OnBoard Audio - ESS SABRE HIFI 9118
Power Supply Corsair RM850i 850W
Mouse Logitech G502 LightSpeed Wireless Gaming Mouse
Keyboard Corsair K70 RGB MK.2 Cherry MX Brown Mechanical Gaming Keyboard
Software Windows 10 Professional
Quick question. What am I missing??? Which software do I trust?
Ryzen Master is reporting my CPU to be 5 degrees lower (sometimes WAY more) than HWInfo and I am now not sure which one to trust.
After reading online, the author of HWInfo stated that AMD refuses to allow third parties to access the thermal sensors in the same way that Ryzen Master does.
So which software do all of you trust?
MY gut is RM
tabascosauz
7,995 (2.38/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
That's HWMonitor. Stop using HWMonitor.
HWInfo as of a while ago now reads Tctl/Tdie (the BIOS fan control reading), Die average, and CCD temps for each CCD (closer to what RM reads). If your cooling is set up properly, they should all be within 10 degrees of each other and none of them should be alarmingly warm.
168 (0.08/day)
BAH!! My SUPER bad! Sorry for that....I thought they were the same monitoring app...Let me see what HWInfo says
So I still see quite a difference but according to your post, this should be normal?
I would like to know though which one is more trustworthy.
Mussels
Freshwater Moderator
58,413 (8.02/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
HWinfo shows an average between all cores over time, ryzen master shows an average in real time.
168 (0.08/day)
Why would anyone want to see anything other than Real Time?
19 (0.01/day)
Processor AMD Ryzen 5 3600
Motherboard Asus Prime X470 Pro
Cooling CPU: CM Hyper 212 Black Edition GPU: Alphacool Eiswolf GPX-Pro
Memory Corsair Vengeance LPX DDR4 32 GB 3000 MHz
Video Card(s) AMD Radeon VII
Storage Samsung SSD M.2 960 EVO 500GB ; Corsair SSD 120GB ; Toshiba HDD 3TB ; WD HDD 1.5TB
Display(s) Acer XF270HU 144 Hz
Case Phanteks P400S White
Audio Device(s) Corsair ; Sennheizer ; Sony ; Edifier S2000 Pro
Power Supply Corsair RM650x
Keyboard HyperX RGB
MY gut is RM
I stopped to use HWInfo ages ago. Some Youtubers use it, they should know better. Core Temp is better if you want live temps.
3,334 (1.82/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 163W PPT limit, 80C temp limit, CO -8~12
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~466W (366W current) PowerLimit, 1060mV, Adrenalin v24.7.1
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSBuild 22631.4112), upgraded from Win10 to Win11 on Feb 2024
HWiNFO is the best (and most importantly updated) monitoring tool for modern systems. You can see the real time values, the min/max and avg (with columns)
RyzenMaster uses a AMD proprietary method to report CPU temp, undisclosed to public, HWiNFO developers/authors included.
Thats why there is discrepancies between readings.
HWmonitor is an outdated tool and lacks a lot for CPUs like ZEN2 at least.
RyzenMaster temp report has no direct equivalent on any other monitoring tool. It is hard for anyone to say (other than AMD) if it is the real deal because of the unknown method it uses.
For ZEN2 CPUs the HWiNFO CPU temp reports are 3 or 4* distinct readings, directly drawn from CPU itself.
1. CPU (Tctl/Tdie)
2. CPU Die (average)
3. CPU CCD1 (Tdie)
*4. CPU CCD2 (Tdie)
*(If CPU has second CCD)
ZEN2 CPUs have multiple sensors inside. At least 50 sensors per coreCCD.
1. Is the absolute higher temp inside all the CPU package. This report switches instantly to the sensor inside CPU CCD(s) with the higher reading. (aka HotSpot)
2. Reports the average CPU temp from all sensors across all CCDs combined.
3/4. Reports (a static location) temp from a specific sensor located to a side of (each) CCD. This is more like the traditional CPU temp we all used to see in past years. (aka EdgeTemp).
As I said there is no match for RyzenMaster CPU temp report, but the closest to it is the "CPU CCD"
CoreTemp for ZEN2 reports only the HotSpot one (Tctl/Tdie). This temp is used for CPU cooling (fan control/curves, as Tctl defines).
tabascosauz
7,995 (2.38/day)
Western Canada
System Name ab┃ob
That's curious. Last time I checked, Coretemp is an absolute shitshow on Ryzen 3000. There has been, after all, a singular Coretemp revision from August 2019 to add basic support for Matisse, while HWInfo has gone through countless fixes and feature additions for Matisse support since July.
These aren't Intel chips. They don't have per-core temperature monitoring. They have a single digit ms response time, and proprietary temperature sensors. Absolute frequency monitoring (as opposed to HWInfo's "effective" clock average) is laughably pointless in any software outside of Ryzen Master, all those freq readings are more or less useless unless the chip is under continuous load. Granted, Coretemp does have a faster default polling rate than HWInfo, but it's still reading the antiquated fan-control Tctl/Tdie temperature reading as every other software that isn't Ryzen Master. Ryzen Master is the only accurate reading, and HWInfo provides you an additional die sensor and per-CCD readings.
If that wasn't enough, the cherry on top is the highly entertaining 1.48-1.50v idle Vcore reading. My system runs a -0.075V offset; it's literally impossible to peak past 1.43v at these settings, ever.
Sounds to me like those Youtubers know something that you don't.
19 (0.01/day)
Keyboard HyperX RGB
1. CPU (Tctl/Tdie)
3. CPU CCD1 (Tdie)
*4. CPU CCD2 (Tdie)
LOL!!!
3,334 (1.82/day)
