Sacred 1920x1200
Status
Not open for further replies.
Violeta
61 (0.01/day)
Lincoln, NE
System Name Sinister
Processor Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz (2 CPUs)
Motherboard MICRO-STAR INTERNATIONAL CO.,LTD, MS-7365
Memory 3326MB RAM
Video Card(s) NVIDIA GeForce 8800 GT
Storage WDC WD3200AAKS-00YGA0 305.2 GB
Audio Device(s) SB Live! 24-bit
Software Windows Vista™ Ultimate Service Pack 1
Is it possible to set the original Sacred to play in 1920x1200??? I have the Sacred Gold edition (with Underworld) installed.
Thanks!!
xu^
1,114 (0.18/day)
Lancs,UK
System Name Mr_average ( hoping 1 day to upgrade to Mr_above_average )
Processor AMD Ryzen 7 5700x @3.4ghz/4.6ghz
Motherboard MSI B450 Tomahawk Max
Cooling Deepcool AS-500 Plus - White | 6 Lian Li ST120mm case fans - White
Memory 32gb Corsair Vengeance RGB PRO SL 4x 8GB 3600MHz DDR4 - White
Video Card(s) Asus Dual GeForce RTX 4070 12GB OC
Storage 512gb Sabrent Nvme | 4tb Samsung SSD | 2tb WD Blue SSD| 1tb Crucial P3 Nvme| 1tb WD Blue HDD = 8.5tb
Display(s) D1: LG Ultragear GL850-B 27" 1440p 144hz | D2: Asus Tuf - VG249 24" 1080p 144hz
Case Lian Li Lancool 2 Mesh RGB - White
Audio Device(s) Phoinikas USB Soundcard :- Creative Gigaworks T20 Series II | Steelseries Arctis 3 Headset - White
Power Supply Corsair TX650M Semi Modular 80+ Gold
Mouse Razer Basilisk V3
Keyboard Razer Huntsman V2
i thought it was stuck at some god awful low res like 800*600 or soemthing ?
maybe u could try look for any cfg files in the game folder where u can manually change the res.
Violeta
61 (0.01/day)
Lincoln, NE
Memory 3326MB RAM
Hmmm... I've done some google searches for this and I have not found any advice from anyone! What should I do with the "settings.cfg" file? I don't see anything as obvious as 800 or 600 or resolution-looking type of sequence so.... would this file be where I would change anything?
It's in the Underworld folder - I just installed the Gold edition CD, but I had the Demo installed ahead of time. Now the only two directories under "Ascaron Entertainment" are Sacred Demo and Sacred Underworld. Should I have un-installed the demo??
Solaris17
Super Dainty Moderator
26,700 (3.82/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
post up the cfg file in a zip and ill look at it for you
Violeta
61 (0.01/day)
Lincoln, NE
Memory 3326MB RAM
Thanks!
Here it is!!
  • Settings.zip
Solaris17
26,700 (3.82/day)
Alabama
VR HMD Quest 3
well i couldnt find anything but i added a resolution line it may or may not workill look more into it see whats up.
  • Settings.zip
4,267 (0.68/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Probably not...
http://forum.sacredeng.ascaron-net.com/showthread.php?t=40886
and
Sacred still looks good even though it's been a while since the original game was released. The game uses 3D characters and 2D pre-rendered backgrounds and it's a mix that works well and doesn't demand high PC specifications. It's a shame that the game is locked at the screen resolution of 1024x768 though. With many gamers using a 17" TFT screen nowadays it would have been great to have seen the game support the 1280x1024 screen resolution. However the game does look OK on a 17" and isn't as blurry as some games that are locked at lower resolutions. You can zoom in quite close and whilst the backgrounds do pixelate a little it's nothing major. Likewise you can zoom out quite a distance too which is handy when you're in an area filled with enemies.
Solaris17
26,700 (3.82/day)
Alabama
VR HMD Quest 3
well if not ill look into were the other settings are sotred and if i cant violeta you can try going into the nvidia CP and seeing if you can force a resolution in the game settings tab thing...
3,942 (0.62/day)
System Name Widow
Processor Ryzen 7600x
Motherboard AsRock B650 HDVM.2
Cooling CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5)
Memory 32GB Gskill Flare X5
Video Card(s) GTX 1080 TI
Storage Samsung 9series NVM 2TB and Rust
Display(s) Predator X34P/Tempest X270OC @ 120hz / LG W3000h
Case Fractal Define S [Antec Skeleton hanging in hall of fame]
Audio Device(s) Asus Xonar Xense with AKG K612 cans on Monacor SA-100
Power Supply Seasonic X-850
Mouse Razer Naga 2014
Benchmark Scores FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x
Can you try using a manual addition in the shortcut or command target line?
I.e. adding -x 1920 -y 1200 after the "sacred.exe" or whatever it's called.
Not sure if that's the right sequence for this game, though a similar approach works for some 3d applications.
Violeta
61 (0.01/day)
Lincoln, NE
Memory 3326MB RAM
None of those things worked! It looks so bad it's almost unplayable! I can't believe a game that came out in 2004 has such unexpected and serious flaw. I didn't even think to check for something like this because I didn't expect it from a game that is not very old. Anyway, what did you mean by "nvidia CP and seeing if you can force a resolution in the game settings tab thing"? That's the only thing I haven't tried but somehow I doubt the game will respond well - worth a try tho.
Thanks
Temps_Riising
121 (0.02/day)
Isle of Wight
Processor E8500 @ 4.75gig....E8200 @ 4.4gig
Motherboard Gigabyte x38T DQ6 and EVGA 790i Ultra
Cooling TRUE and lots of 120mm fans
Memory 2GB OCZ DDR3 1600mhz 7-7-7-18
Video Card(s) Inno3D 512MB 8800GTS G92 @ 835/2087/1075
Storage Western Digital 500gb 32MB cache SATA II
Display(s) Samsung SyncMaster 205BW 20" TFT on DVi
Case Antec 900
Audio Device(s) XiFi Xtreme Gamer/Audigy 4
Power Supply Tagan 800W U33 2ForceLL
Software XP Home SP3 and Vista 32bit Home Premium dual boot
Benchmark Scores Don't Bench....too busy gaming!
Have you tried the good old registry hack method?............works far more than the command line editor, type regedit in "start menu.....run"
Then go to "HKEY_LOCAL_MACHINE\SOFTWARE\name of game developer\sacred(or whatever it's called"
You will see both a screen heigh and a screen width command, change those to 1920 and 1200 respecively...........
...................Make sure the "base" is in decimal
Then save and exit
keep your fingers crossed!
Violeta
61 (0.01/day)
Lincoln, NE
Memory 3326MB RAM
Grr!! It's not there... In the registry, there is no name of this game developer (Ascaron Entertainment). I looked under all other directories in "SOFTWARE" just to make sure it wasn't named something else. It's named Ascaron Entertainment in Program Files so I would expect that... but nope. *stomps foot* This is sooo annoying, ugh!!
Solaris17
26,700 (3.82/day)
Alabama
VR HMD Quest 3
click on the computer icon in regedit
than go to edit and click on find all and type in sacred and hit enter then just keep hitting F3 until you find the entry ;)
Violeta
61 (0.01/day)
Lincoln, NE
Memory 3326MB RAM
I did a "search" for all "sacred" in registry and nothing I found opened with anything that let me change a height or width. I think it's a lost cause :(.
Temps_Riising
121 (0.02/day)
Isle of Wight
Case Antec 900
CanTahir
1 (0.00/day)
Open settings and add last line Resolution: 1280x1024
Just 1920x1080 not compatible.. But you still playing full screen. I tried.
First called this idea Solaris17 thanks !
I want who experiencing this problem after us i help them cuz i play kind of Diablo series time is doesn't matter. Today playing Sacred 1... My remembrance history signature here : )))
Don't forget me/thanks... : ) CUL CUL !
Toothless
Tech, Games, and TPU!
9,544 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Dude the thread is 8 years old.
Toothless
9,544 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
You want thanking for Resurecting a 8 year old thread
OK Dr Zombie Resurector
contibute something usefull in a Current Thread
You have them forums rules bookmarked for our new friend? I don't think i have it on mobile.
dorsetknob
9,106 (1.27/day)
Kind of think showing them those rules a waste of time
if they don't read thee old thread post warning ""IN VIVID RED "" what makes you think they going to read the rules
Toothless
9,544 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Good point.
Tatty_Two
Gone Fishing
25,902 (3.79/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -075mV PL max @225w
Software Win 11 Home x64
Necro thread necro'd permanently by closure.
Status
