Samsung 850 evo 2 500gb raid 0 vs 1tb evo?
Which setup is better
  • One Samsung 850 evo 1tb ssd
    Votes: 12 80.0%
  • Two Samsung 850 evo 500gb ssds in raid 0
    Votes: 3 20.0%
  • Total voters
    15
443 (0.16/day)
Processor i7 4790k / ryzen 1700
Motherboard Asus Maximus VI Extreme / gigabyte b350 mini itx
Cooling Corsair H70 / cooler master master liquid
Memory 32gb DDR3 / 32gb ddr4
Video Card(s) Gtx 1080 / gtx 1080
Storage 128gb Samsung 850 Pro, 2tb hdd / 500gb 850 evo
Case Thermaltake Chaser Mk-1 / Silverstone m13b
Power Supply 1000W OCZ Gold Full Modular / seasonic focus 850w
Mouse Proteus Core G502
Keyboard Corsair K95 RGB
Title states it all, which will be better, 2 500gb 850 evo running raid 0 or a single 1tb 850 evo? I think with the raid 0 they would be the same size as the 1tb but twice as fast??
Edit: will be using for main system disk (it will have only one drive and it'll also be the boot drive). Idk if booting off of raid is bad or not.
3,908 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
2x500 in raid0 will be faster for sequential read/write. theoretically twice as fast as single drive, in reality (much) less than that. random r/w not really faster.
raid0 will come with a huge risk to data, if one of the drives die you lose all the data.
depending on implementation, usage patterns and such, raid might introduce additional writes on disks which is not that good for ssd-s.
you are on a relatively new hardware. if you really feel you need faster drive, just go for m.2 ssd like samsung 960 evo.
520 (0.17/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
I think raid 0 will saturate bandwith of sata6 so u gain few performance vs 1tb. ifu need more speed yes u have to go m2 ssd as written by londiste
3,908 (1.33/day)
one ssd (close to) saturates sata3 bandwidth. two drives are connected to two different sata3 ports so there is double the bandwidth to play with ;)
520 (0.17/day)
sorry u are completely right!
443 (0.16/day)
I only ask this because it's $50 cheaper to buy two 500gb drives vs 1 1tb 850 evo. If one drive failed dies that mean the data on the working drive would be gone to?
Kursah
Super Moderator
14,735 (2.20/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
In a RAID 0, if one drive fails you lose all data. Each of your drives has 50% of the data. So while you have speed you have no redundancy or parity. That's the risk of performance.
I'd go with a single SSD and call it a day, sure if you lose the single drive you lose your data too, but you double your risk of failure with a RAID 0 dual-drive config as each drive has a chance to fail. You also come close to doubling performance and would save money for about the same amount of space. Comes down to what you want to do, if the performance boost is worth it, and if you're comfortable with the risks involved.
If it were me, I'd still go single drive...but RAID 0 can be fun to play with on non-critical applications. :toast:
10,885 (1.55/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Someone here did do two SSD drives in RAID 0, they showed a bandwidth over 1,000 MB/s!
Only problem is I can't remember who or what thread I saw that :banghead:
7,397 (1.04/day)
Video Card(s) Sapphire Radeon RX 590 Nitro+ SE (RX 7900 XT/XTX or RX 9070 XT?) | Intel® Iris® Xe Graphics
I agree with @Kursah no point in RAID0 with no redundancy, then u would need 3x500GB if u want RAID, if it's the speed u want from RAID why not just enable RAPID mode and call it a day?
443 (0.16/day)
Guess I could always just buy 1 500gb drive and get another one later and use it as storage or sonething. It seems raid 0 wouldn't be worth doing but raid 5 with 3 might be.
698 (0.23/day)
System Name Unimatrix
Processor Intel i9-9900K @ 5.0GHz
Motherboard ASRock x390 Taichi Ultimate
Cooling Custom Loop
Memory 32GB GSkill TridentZ RGB DDR4 @ 3400MHz 14-14-14-32
Video Card(s) EVGA 2080 with Heatkiller Water Block
Storage 2x Samsung 960 Pro 512GB M.2 SSD in RAID 0, 1x WD Blue 1TB M.2 SSD
Display(s) Alienware 34" Ultrawide 3440x1440
Case CoolerMaster P500M Mesh
Keyboard Corsair K75
Benchmark Scores Really Really High
"Better" means different things to different people. In terms of performance the RAID 0 will be better but then you have twice the chance of a hard drive failure. For me I back up stuff so I'll take the performance any day.
Kursah
Super Moderator
14,735 (2.20/day)
Missoula, MT, USA
RAID5 would provide parity, but you'd gain no write performance, only read. It would however allow a single drive to fail and the array to not totally kick the bucket due to maintaining parity between the three drives to ensure two drives have enough to rebuild the third. Keep a spare drive handy though, so you can swap it in and rebuild the array ASAP. You don't want to wait and risk a second failure.
RAID 10 with 4 drives would offer some increased write and read performance, but you'd only have 50% usable space (it is two RAID1 arrays, which is a 1:1 mirror, in a RAID0).
Not sure what you'd use to handle the RAID processing, but I don't recall a consumer-grade mainboard solution that offered RAID10.
@Gasaraki also brings up a good point, backups. Definitely something to consider depending on how critical the data and your time to start from scratch again are.
443 (0.16/day)
I think what I'm going to do is buy either 1 850 evo or 2 850 evos and run them as separate drives. The 1tb is just too expensive. Trying to justify spending $280 on SSDs though xD
13,791 (1.85/day)
Go with single 1TB. RAID0 is fast, but is just calling for failure. RAID0 is worth when you can't go any higher for single drive. If you can, go to desired capacity with single drive, go with that. Much less problems, less chances for failure and less complications overall.
7,397 (1.04/day)
I got one 960 EVO 250GB for Windows 10 and two 850 EVO's 1TB for gaming no raid I don't feel the need for it.
7,412 (2.69/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
That'd be me and my 850 Pro's in raid0.
If you think SATA 6gbps is gonna hold 2 SSDs back, then look at 4 of those in RAID0. (found on ocn http://www.overclock.net/t/1639921/u-2-ssds). Until I put my own drives in raid0 and then investigated further (3,4 drives), I believed stata 6gbps will limit the performance of sata ssds in raid0, just cause everyone kept telling me that nonsense. 2 drives reach 1100mb/s, three do up to 1600mb/s, four come close to 2000mb/s. Sequential read/write only, but that's raid0 limitation not the sata limitation.
It has to be said that raid0 only increases sequential read/write, random numbers stay about the same. I'd say with 850Pro's in Raid0 my system is maybe slightly more responsive if I'm really doing a lot of bandwidth-dependent things at the same time but a single SSD is still more than enough for a home user. If you have a choice I'd go with 850 evo 2x512 raid0 cause it's free perfromance, whether you'll be able to see it will be very limited though.
13,791 (1.85/day)
Like I've said, unless you need raw throughput (basically copying MASSIVE data sequentially) you don't need or want RAID0. It's fast but volatile and tends to complicate things like HDD/SSD status monitoring, software support for backup etc. It's just not worth it unless you absolutely need it for specific tasks. And even there, I'd reconsider M.2 NVMe drives. Most even basic ones reach 1.5 GB/s and have slightly lower latencies because of more direct connection than SATA.
7,412 (2.69/day)
Poland
Cooling Noctua D15S
yes but they also tend to be more expensive,have less warranty (960 evo 3 years - 850 evo 5 years, 960 pro 5 years - 850 pro 10 years) and they have massive overheating problems at their rated speeds unless you cool them with a radiator, which adds to the cost. It's basically a trade between one and the other having both pros and cons. RAID0 splits data in half, which means 50% less TBW for each drive in the array actually.
13,791 (1.85/day)
I think write wear is irrelevant for today's drives unless you scrub 100GB of data every single day. And even then we are talking roughly 37TB a year. 850 Pro has warranty of 300TB I think. That's 8 years of daily 100GB writes just to reach the warranty limit. Like I've said, most 850 Pro's do 1PB rather easily. That's 1000TB. That's 27 years of 100GB daily writes. In 27 years, I'm sure even my 2TB SSD will be greatly outdated and only something people would get in entry level laptops so far in the future (I doubt they'll even have SATA anymore).
This write wear anxiety is really annoying and it would be better if no one even mentioned it ever. I managed to shake it off, but I'm sure it's hard when you pay 500 bucks for a drive and you worry it'll wear out too soon. Well, don't worry at all. I have my 850 Pro 2TB for 2 years, 2 years and a half maybe. It has 13TB writes and I use it as my main drive for everything and I don't babysit it at all. I just use it like I did my old HDD. That makes it almost impossible to wear it out during normal usage. Not to mention, we're talking 100GB write scenarios EVERY single day without exception. Which is entirely unrealistic. You may install 2x massive 50GB games, but then you'll be busy playing them for next several days in which you'll maybe write only 1GB every day. Each day this happens, the write average goes down.
443 (0.16/day)
I actually just ended up getting a single 500gb 850 evo drive. It was $155 at newegg (sale ends today). I think it'll be sufficient for the system I'm putting in (building a dedicated VR machine with a ryzen 1700 that'll also render videos for me) so I'm thinking that 500gb will be enough for sony vegas 15, windows 10, and some VR games plus steam and oculus home. I have a 1tb 850 evo that I was going to use for my main rig (4790k) but I might put the 500gb in that and the 1tb in the other once singe my main rig will have like 8 hard drives in it.
Either way thank you all for your advice. Seems like if I did end up buying another 850 evo I'd be better off leaving it as its own separate drive since it's fast enough on it's own and that way if one failed i'd only lose half my data instead of all my data. If I really needed more performance I would have bought an NMVE ssd.
7,412 (2.69/day)
Poland
Cooling Noctua D15S
Yes but the warranty and thermals are a concern, you seem to conveniently forgotten. Anyway, the OP seems to have chosen.
7,412 (2.69/day)
Poland
Cooling Noctua D15S
I know this thread is dead, but I just wanna get some things straight as I clearly made a mistake due to my lack of knowledge. Contrary to what I believed, RAID0 does make a difference for random read/write. The only thing which it doesn't seem to improve is 4K data at QD1, which is harldy indicative of any practical,real-world workloads at all.
This is a SATA3 SSD (XPG 950 3D MLC)
Those are my two 850 Pro's
2x faster than a single SATA3 SSD at 512K random, 44% faster in 4K QD32 write, 10% faster in 4K QD32 read. Only thing that doesn't seem to be affected or sees negative scaling is 4K QD1.
19,376 (3.51/day)
I surely wouldn't call it massive... I don't have heatsinks on my two M.2 drives and they don't overheat.... just depends on the location and other factors...
Also, writes haven't been a worry on SSDs in generations. ;)
Last, most files are less than 4K. 4k R/W is where SSD's money is made bud. Clearly indicative to typical OS work and loads.
It also appears you are using two different versions of CDM? Why does one say 4K and the other says 4K QD4. QD1 v QD4 will make a difference. ;)
7,412 (2.69/day)
Poland
Cooling Noctua D15S
seems you're partly right on 4K files. 50-60% is 4K or less. Dunno about QD but I suppose higher queue depths (QD32/64) are more indicative than QD1. I read 4K files are clustered most of the time.
This is the same version of CDM (3.0) but I don't know how to set up QD4 (TT article said they set this QD size up themselves). Not that it matters in any way, QD1 and QD32 still tell pretty much most of the story. The higher the QD, the better RAID0 performs on smaller files.
Now this is really interesting. Found an article comparing 3x256GB 850pro's vs a single PCI-E 3.0 4x drive. This is really staggering. Time for a third one for me ? :p
Even 950 pro gets hammered at 4K/4K QD4 write
