samsung 960 pro - this drive is not supported (samsung magician)
noobygirl
2 (0.00/day)
simple setup;
asus rampage v mb with intel x99 chipset
1 x samsung 960 pro nvme via m.2 port (no other drives)
windows 7 (yes, really) installed and working perfectly. fyi; used the gigabyte windows usb installation tool to create working win7 usb stick.
drive seems to perform at close-ish to expected/advertised values. (see below) drive is also using latest firmware. i know so because i booted off the samsung firmware iso and after it checks, reports as "being latest". crystal disk mark and other disk benchmark tools all report same-ish results, as expected, so drive not hindered in any significant way. (could maybe improve around 5-7%?) magician itselfs shows expected-ish results.
my only concern of sorts is that samsung's own magician isn't fully supporting it. see below. is it because it uses microsoft nvme drivers? but if yes, what can i do? i did get current latest samsung drivers, installed them, rebooted, but no change. it's as if they -the samsung drivers- did nothing. they are installed under "program files" and have an uninstall option under windows add/remove as normal, but aren't installed really.
additionally, i also tried to manually update drivers by going to device manager > hardware > drive > driver tab > update driver, then point to the correct place that holds the four needed files. they are; secnvme.cat, secnvme.inf, secnvme.sys & secnvmeF.sys. they are the same as the ones the installer installs anyway, with the last two being digitally signed by both samsung (sha1) and microsoft (sha256). i also tried to "old" right click the inf file and click install, only to get "the inf file you selected does not support this method of installation".
i suppose i can just carry on, but decided to maybe try and somehow switch to samsung drivers, so magician recognizes and starts supporting it's own damn drive before i start installing the other apps and start using windows properly. since this is early stage, i have not updated windows to the very latest, though not sure that would make any difference here. the drive is up and running just fine, seems to perform exactly how it's supposed to, just that the drive maker's own software isn't playing nice with it.
finally, the bios settings for booting are currently set to; auto for the CSM (both auto/enabled work, decided to leave on auto) and "other os" for the safe boot section.
ideas?
11,878 (2.21/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
I have a 970evo not pro I just left the driver to Ms and it works fine, magician installed ok.
Surprised me to find rapid not supported though due to not supporting nvme drive's at all.
Never owned a pro is it possible it's not supported.
The driver probably isn't important over all.
noobygirl
2 (0.00/day)
ah, yeah, i think it is very important for the drive's own software to see it properly and work with it. smasung makes both. and magician when "supported" shows drive writes, health, etc.. it lets you secure erase it and more. i'd want magician to work. it's not as if i'm wanting another ssd brand maker's software to work with the drive. then, one could understand some of the software features not working. this is samsung's own. it ain't right.
since magician is not seeing the drive, i am missing out on a lot of drive specific things. example. other software could pick up the slack sure, but why use those, when the drive's maker has it's own, and for such sensitive things it's best to use manufacturer ones. i want magician to work properly.
ps: forum "mods".. how much longer am i going to be babysat? ==> "This message is awaiting moderator approval, and is invisible to normal visitors."
bogmali
In Orbe Terrum Non Visi
9,536 (1.57/day)
Pacific Northwest
System Name Daily Driver/Part Time
Processor Core i7-13700K/Ryzen R5-7600
Motherboard ASUS ROG MAXIMUS Z790 APEX/Asrock B650 Pro RS Wi-Fi
Cooling Corsair H150i RGB PRO XT AIO/Deep Cool LS-520 White
Memory G-Skill Trident Z5 Silver 2x24GB DDR5-8200/XPG Lancer Blade 2X16GB DDR-5-6000
Video Card(s) MSI Ventus 3X OC RTX-4080 Super/Sapphire Radeon RX-7800XT
Storage Samsung 980 Pro M.2 NVMe 2TB/KingSpec XG 7000 4TB M.2 NVMe/Crucial P5 Plus 2TB M.2 NVMe
Display(s) Alienware AW3423DW
Case Corsair 5000d AirFlow/Asus AP201 White
Audio Device(s) AudioEngine D1 DAC/Onboard
Power Supply Seasonic Prime Ultra 1K Watt/Seagotep 750W
Mouse Corsair M65 RGB Elite
Keyboard Adata XPG Summoner
Software Win11 Pro 64
Benchmark Scores Xbox Live Gamertag=jondonken
PS: for as long as nobody notices the mod queues, not on purpose but by forum engine design and not everyone will see it-only the ones that moderate this section and super moderators.
Ahhzz
Super Moderator
8,948 (1.46/day)
System Name OrangeHaze / Silence
Processor i7-13700KF / i5-10400 /
Motherboard ROG STRIX Z690-E / MSI Z490 A-Pro Motherboard
Cooling Corsair H75 / TT ToughAir 510
Memory 64Gb GSkill Trident Z5 / 32GB Team Dark Za 3600
Video Card(s) Palit GeForce RTX 2070 / Sapphire R9 290 Vapor-X 4Gb
Storage Hynix Plat P41 2Tb\Samsung MZVL21 1Tb / Samsung 980 Pro 1Tb
Display(s) 22" Dell Wide/24" Asus
Case Lian Li PC-101 ATX custom mod / Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Mouse Logitech G502 Lightspeed Wireless / Logitech G502 Proteus Spectrum
Keyboard K68 RGB — CHERRY® MX Red
Software Win10 Pro \ RIP:Win 7 Ult 64 bit
simple setup;
ideas?
So, it seems like the issue is Magician not recognizing your drive properly. What did Samsung's chat support say when you reached out to them?
Hugis
824 (0.15/day)
Spain(Living) / UK(Born)
System Name Office / Gamer Mk IV
Processor i5 - 12500
Motherboard TUF GAMING B660-PLUS WIFI D4
Cooling Themalright Peerless Assassin 120 RGB
Memory 32GB (2x16) Corsair CMK32GX4M2D3600C18 "micron B die"
Video Card(s) UHD770 / PNY 4060Ti (www.techpowerup.com/review/pny-geforce-rtx-4060-ti-verto)
Storage SN850X - P41Plat - SN770 - 980Pro - BX500
Display(s) Philips 246E9Q 75Hz @ 1920 * 1080
Case Corsair Carbide 200R
Audio Device(s) Realtek ALC897 (On Board)
Power Supply Cooler Master V750 Gold v2
Mouse Cooler Master MM712
Keyboard Logitech S530 - mac
Shouldn't the view of magician look somewhat like this.
it is possible that your "Samsung " drive is a fake
Have you spoken to Samsung about an RMA? or to whoever supplied the drive?
Also, do us all a favor and fill in your System Specs :)
344 (0.13/day)
additionally, i also tried to manually update drivers (...)
On what device exactly did you try this procedure?
There are separate devices displayed in device manager, one is an NVMe controller, and the second one is the disk itself. When switched to "devices by connection" view, you'll see the controller as parent of the disk.
The driver is for the controller.
201 (0.03/day)
Switzerland
Processor Intel i5 13600K
Motherboard MSI MPG Z790 CARBON WIFI
Cooling Noctua Chromax NH-U12A
Memory Kingston Fury Renegade DDR5 32GB 6400MHz
Video Card(s) ASUS TUF RX7900XT OC 20GB
Storage Western Digital WD850X 2TB
Display(s) Dell G3223D
Case Fractal Design Meshify XL
Audio Device(s) Creative X3
Power Supply Seasonic HX1000i
I think even without the Samsung driver you should still see it in Magician .
Step 1: Check if the drive appears correctly in the BIOS
Step 2: Install the latest 3.3 driver. (if you do the INF method, do it on the controller not the drive)
Step 3: Install the latest Samsung Magician to see what it reads now.
If you have trouble seeing anything, check with Samsung support. You might have a defective or fake drive.
Also idealy Windows 10 would be better, not 100% sure but NVMe driver support is better on Windows 10 than 7 and also because it's obsolete.
Finally X99 was in the begining of of NVME drives if I remember correctly, so the compatibility and support isn't 100% perfect.
1,191 (0.66/day)
Loose in space
System Name "The black one in the dining room" / "The Latest One"
Processor Intel Xeon E5 2699 V4 22c/44t / i7 14700K @5.8GHz
Motherboard Asus X99 Deluxe / ASRock Z790 Steel Legend WiFi
Cooling Arctic Liquid Freezer II 240 w/4 Silverstone FM121 fans / Arctic LF II 280 w Silverstone FHP141's
Memory 64GB G.Skill Ripjaws V DDR4 2400 (8x8) / 96GB G.Skill Trident Z5 DDR5 6400
Video Card(s) EVGA RTX 1080 Ti FTW3 / Asus Tuff OC 4090 24GB
Storage Samsung 970 Evo Plus, 1TB Samsung 860, 4 Western Digital 2TB / 2TB Solidigm P44 Pro & more.
Display(s) 43" Samsung 8000 series 4K / 50" Vizio M-series 4K
Case Modded Corsair Carbide 500R / Modded Corsair Graphite 780 T
Audio Device(s) Asus Xonar Essence STX/ Asus Xonar Essence STX II
Mouse Logitech Performance MX, Microsoft Intellimouse Optical 3.0
Keyboard Logitech K750 Solar, Logitech K800
Software Win 10 Enterprise LTSC 2021 IoT / Win 11 Enterprise IoT LTSC 24H2
Benchmark Scores https://www.passmark.com/baselines/V11/display.php?id=202122048229
There's a section in Magician that indicates if the drive is authentic or not. I think it's on the update page.
7,053 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
It might be an OEM drive such as SM961 masquerading as a 960 Pro.
