Samsung 980 pro running in gen 3
15 (0.01/day)
San Diego, California
Processor I7-13700K
Motherboard Asus Strix Z790-E
Cooling Custom loop
Memory 32Gb G-Skill Trident Z5 6000
Video Card(s) 4080FE
Storage Samsung 980 Pro Nvme
Display(s) Asus VG27AQ
Case Fractal Meshify 2
Power Supply EVGA 850
Hello all I need some help I just finished a new build and read a article about the 980 pros software should be updated so I did to firmware 5B2QGXA7. To my surprise Samsung magician says it’s running in PCIe Gen 3 x 4 recommend to connect to gen 4 for optimal speed (running about 3500 read and write). I have the nvme plugged into m2_1 on my motherboard which supports PCIe 5.0 x 4. Is this the correct slot? Is it backwards compatible to gen 4 x 4 or do I need to move ssd to one of the other slots.
asus z790e
I7 13700k
Samsung 980 pro
i attached pics of magician and manual of where I slotted nvme
thank you in advance
17 (0.02/day)
québec, canada
Processor I7-4790k
Motherboard Asus Z97-AR
Cooling Noctua NH-D9L 2xfans
Memory Hyperx Fury ddr3L 4x8gb at 1600mhz
Video Card(s) R9 295x2 /modified with 280mm radiator
Display(s) Samsung oled 43inch 4k tv
Case Cooler Master HAF evo
Audio Device(s) tv
Power Supply Corsair RM750x gold
Mouse Corsair M65 PRO
Keyboard Logitech k400 plus
Software Windows 10 pro
Benchmark Scores Graphics score of 25 250 in 3dMark FireStrike
Could you use crystaldiskinfo?
18,584 (2.68/day)
System Name AlderLake
Hmm, yeah that's odd, I would ask how many PCIe devices you have installed but I think it wouldn't matter for the highest M.2 slot.
854 (1.23/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 9 7900X3D
Motherboard ASUS ROG Crosshair X670E Extreme
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB
Software W10-11 Enterprise- Linux Mint 22.0 Cinnamon Edition.
I would try slot M2_2 to see what it gives.
366 (0.42/day)
asus z790e
I7 13700k
Samsung 980 pro
There is a BIOS setting that shows/sets the M2_1 Link Speed. By default it is set to Auto but it can be set manually to PCIe Gen 4 if it is not being detected correctly.
On most recent Asus motherboards this setting can be found under Advanced->Advanced->System Agent (SA) Configuration->PCI Express Configuration.
Lei
1,143 (0.89/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
That answer might help:
