Samsung NVMe Driver 3.3 Benchmark
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Did some quick benchmark with the new driver versus my old 3.1 driver as well as the Win10 default NVMe driver.
Sequential read/write does not seem to have changed much. Random read/write IOPS seems to have a bit improvement.
This is based on a 960Pro 1TB, YMMV for different SSD.
Download link can be found on Guru3D
1,225 (0.65/day)
Loose in space
System Name "The black one in the dining room" / "The Latest One"
Processor Intel Xeon E5 2699 V4 22c/44t / i9 14900K @5.8GHz
Motherboard Asus X99 Deluxe / ASRock Z790 Taichi
Cooling Arctic Liquid Freezer II 240 w/4 Silverstone FM121 fans / Arctic LF II 280 w Silverstone FHP141's
Memory 64GB G.Skill Ripjaws V DDR4 2400 (8x8) / 96GB G.Skill Trident Z5 DDR5 6800
Video Card(s) EVGA RTX 1080 Ti FTW3 / Asus Tuff OC 4090 24GB
Storage Samsung 970 Evo Plus, 1TB Samsung 860, 4 Western Digital 2TB / 2TB Solidigm P44 Pro & more.
Display(s) 43" Samsung 8000 series 4K / 65" Hisense U8N 4K
Case Modded Corsair Carbide 500R / Modded Corsair Graphite 780 T
Audio Device(s) Asus Xonar Essence STX/ Asus Xonar Essence STX II
Mouse Logitech Performance MX, Microsoft Intellimouse Explorer 3.0
Keyboard Logitech K750 Solar, Logitech K800
Software Win 10 Enterprise LTSC 2021 IoT / Win 11 Enterprise IoT LTSC 24H2
Benchmark Scores https://www.passmark.com/baselines/V11/display.php?id=202122048229
I posted a different link to the same 3.3 driver yesterday morning and a moderator removed it. Have you noticed any issues with it? I still haven't had time to try it out.
5,717 (0.93/day)
Smooth as butter
90 (0.05/day)
Dallas TX area U.S.A.
System Name Ryzen 7 7800X3D
Motherboard MSI MAG X670-E Wifi
Cooling Corsair iCue Link H150i RGB 360mm
Memory Corsair Vengeance DDR5-6000 RGB
Video Card(s) Asus TUF RTX 4070 TI OC
Storage (2) 4 TB WD SN850X 1 for OS and 1 for Games and Data
Case Lian Li Lancool III
Power Supply Seasonic Vertex GX-1000 PSU
Mouse Razer Viper 8K
Keyboard Corsair K70 RGB Pro MX Speed Switch Silver
5,717 (0.93/day)
3,401 (0.60/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
Unless they did some under the hood changes, the performance should be the same.
1,225 (0.65/day)
Loose in space
It's finally downloading on Samsung's site.
2,597 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
What benchmark(s)?
5,717 (0.93/day)
37 (0.01/day)
System Name Green Machine
Processor Intel i7-6700K @ 4.635 GHz Core & 4.325 GHz Cache
Motherboard ASUS Z170 TUF Sabertooth Mark 1
Cooling Corsair H110i GT 280mm AIO
Memory Corsair Dominator Platinum DDR4 16GB (4x4) @ 3300 MHz (16-18-18-36)
Video Card(s) MSI 4070 Super Gaming X Slim 12GB (2910 Mhz core 21.5 Gbps mem)
Storage Samsung 950 PRO 512GB NVME SSD , Samsung 860 EVO 1TB 2.5" SATA SSD , WD Blue 7200 1TB HDD
Display(s) Sony XBR810C 55" 4K TV
Case Thermaltake Core V51 Riing Edition Mid-Tower
Audio Device(s) OG Bose Wave Radio acting as a "soundbar"
Power Supply EVGA P2 Platinum 750w
Mouse Several
Keyboard Several
Software Windows 10 Home
Unfortunately, I noticed a significant drop in random write performance (in benchmarks, at least). There have been some windows updates and other minor changes to my software/OS environment since then, but nothing out of the normal and it has only been a month since I last tested (3/8/20, with crystal disk mark - it is now 4/5/20). This is with a 950 Pro on Z170. New results are exactly the same except the two ~400MB/S write scores in the middle are always between 200-300 now with the new 3.3 driver. The 709 read score is now never above 650/660, although I'm not nearly as worried about that.
The pic I attached are of the old results. To be honest, I am not even sure which version of the driver I had been using prior to the update, as I thought the magician software was keeping everything up to date (this is the first time I've ever had an "alert" from magician that I need to update the driver). I don't believe I ever manually updated the driver since originally installing it when I first got it around May of 2016.
One area that has definitely improved is the thermals. My motherboard (ASUS Sabertooth Z170 Mark 1) was one of the early m.2/nvme adopters, and as such it does not employ a heatsink; only a little "pocket" with a plastic lid on it that is supposed to get at least some benefit from the tiny little motherboard fan, although I don't think it helps one bit. My temps for the 950 Pro 512MB have always been 50c at idle and 55-65c when actually under (normal) use. During a long benchmark such as ATTO it creeps up to 75c and throttles itself, but this never bothered me much since that only really happened during those particular long benchmarks, which I avoided. Anyway, after installation of the new 3.3 driver the idle temps are -10c, down to 40c. These temps are with an ambient room temp of 18-19c.
Does anyone else have results with a 950 Pro (512MB or otherwise)?
37 (0.01/day)
Mouse Several
Keyboard Several
Tried going back to the old 1.1 driver that I had been using, but the installer comes back with the error "latest version already installed". I rolled back to the microsoft nvme driver, tried installing Samsung's 1.1 driver again (from my old install file, which I found) but it still throws the same error. The microsoft driver definitely shows up as installed in device manager, whereas the 3.3 samsung one was showing up before I rolled back...
Anyway, attached here are results after rolling back to old MS driver. They are very similar to what I got prior to installing the Samsung 3.3 driver (possibly identical - this test was done right after a restart, without waiting for all OS disk activity to cease). Temps also went right back up to the old values as well. From here it looks like older drivers may be better for the 950 Pro - you just won't get the cooler temps.
Hugis
827 (0.15/day)
Spain(Living) / UK(Born)
System Name Office / Gamer Mk IV
Processor i5 - 12500
Motherboard TUF GAMING B660-PLUS WIFI D4
Cooling Themalright Peerless Assassin 120 RGB
Memory 32GB (2x16) Corsair CMK32GX4M2D3600C18 "micron B die"
Video Card(s) UHD770 / PNY 4060Ti (www.techpowerup.com/review/pny-geforce-rtx-4060-ti-verto)
Storage SN850X - P41Plat - SN770 - 980Pro - BX500
Display(s) Philips 246E9Q 75Hz @ 1920 * 1080
Case Corsair Carbide 200R
Audio Device(s) Realtek ALC897 (On Board)
Power Supply Cooler Master V750 Gold v2
Mouse Cooler Master MM712
Keyboard Logitech S530 - mac
Well i have just done a "freshy" of win10 pro (November edition 1909?) on my sm961, it was a very quick 10-15mins max install time.(some time after as well)
below are some windows CDM results from fresh then the new 3.3 Samsung driver (i also noticed a +/- 5 sec advantage startup with the Samsung driver)
This is a Z97 so not the best platform.... but a slight improvement
Here ya go …
924 (0.18/day)
System Name future xeon II
Processor DUAL SOCKET xeon e5 2686 v3 , 36c/72t, hacked all cores @3.5ghz, TDP limit hacked
Motherboard asrock rack ep2c612 ws
Cooling case fans,liquid corsair h100iv2 x2
Memory 96 gb ddr4 2133mhz gskill+corsair
Video Card(s) 2x 1080 sc acx3 SLI, @STOCK
Storage Hp ex950 2tb nvme+ adata xpg sx8200 pro 1tb nvme+ sata ssd's+ spinners
Display(s) philips 40" bdm4065uc 4k @60
Case silverstone temjin tj07-b
Audio Device(s) sb Z
Power Supply corsair hx1200i
Mouse corsair m95 16 buttons
Keyboard microsoft internet keyboard pro
Software windows 10 x64 1903 ,enterprise
Benchmark Scores fire strike ultra- 10k time spy- 15k cpu z- 400/15000
and while we're at it, how do you replace the default windows driver on the OS nvme drive without crashing the system? did that on the storage drive of course easily, but not on the OS drive.
edit: my drives are not samsung, so regarding other manufacturers and 3rd party drivers when available.
7,395 (1.04/day)
Video Card(s) Sapphire Radeon RX 590 Nitro+ SE (RX 7900 XT/XTX or RX 9070 XT?) | Intel® Iris® Xe Graphics
How did I actually check what NVME driver version I am using?
Because if check Windows Storage in Aida64 I just get driver version 10.0.18362.1 which is a Microsoft driver even I clearly remember I installed Samsung's own NVME driver during the installation of my Windows 10 :roll:
Lol just ran the NVME 3.3 update and driver version on my Windows 10 remains the same and my 970 Evo give this out while running light work so I guess this is alright then :confused:
Because it's a little above the rated reading of 3500MB/s and a little under the rated write speed 2500MB/s
56 (0.01/day)
System Name AMD
Processor AMD Ryzen 7 3700X
Motherboard Asus ROG Strix X570-E Gaming
Cooling Corsair H100x
Memory 64GB G.Skill Ripjaws V (F4-2800C14Q-64GVK)
Video Card(s) Gigabyte GV-N108TD5X-B
Storage Samsung 970 Evo Plus / WD141KRYZ
Display(s) Asus PG279Q ROG SWIFT
Case NOX Hummer TGX
Audio Device(s) on board
Power Supply Seasonic Prime Ultra 750W Gold
Mouse Corsair Vengeance M65
Software Microsoft Windows 10 Pro 64Bits
This is my result in a 970 EVO PLUS
17,595 (4.66/day)
System Name Patient King of Finding Good Sales
Processor 7800X3D -25 all core ($196)
Motherboard B650 Steel Legend ($169)
Cooling Frost Commander 140 ($42)
Memory 32gb ddr5 (2x16) cl 30 6000 ($80)
Video Card(s) Merc 310 7900 XT @3100 core $(705) (July 2023)
Display(s) Agon 27" QD-OLED Glossy 240hz 1440p ($399)
Case NZXT H710 (Red/Black) ($60)
Power Supply Corsair RM850x Gold ($109)
17,595 (4.66/day)
my WD black 1tb sn750 for comparison if anyone is interested. $129.99
168 (0.10/day)
Samsung MZVLB1T0HBLR 1TB
