SAPPHIRE Announces NITRO+ AMD Radeon RX 9070 Series Graphics Cards
Nomad76
971 (3.42/day)
SAPPHIRE Technology announces the latest SAPPHIRE NITRO+ AMD Radeon RX 9070 XT and Radeon RX 9070 graphics cards, built on the new AMD RDNA 4 architecture specialized for gamers and creators. With a plethora of new exciting features alongside the iconic powerful cooling engineering from the SAPPHIRE NITRO+ lineup, expect a new premium centerpiece for all gaming graphical needs.
NITRO Charged for an Elite Next Generation Adventure
The SAPPHIRE NITRO+ AMD Radeon RX 9070 Series Graphics Cards will be available in these enthusiast models:
  • SAPPHIRE NITRO+ AMD Radeon RX 9070 XT GPU with 16 GB memory, AMD RDNA 4 architecture, DisplayPort 2.1a
  • SAPPHIRE NITRO+ AMD Radeon RX 9070 GPU with 16 GB memory, AMD RDNA 4 architecture, DisplayPort 2.1a
Garner an exhilarating gaming experience with the SAPPHIRE NITRO+ AMD Radeon RX 9070 XT graphics card, constructed with excellent cooling, premium materials, and a stellar design. Comprising of a strong foundation with the latest AMD RDNA 4 architecture, it features a GPU with 64 Compute Units and 4096 stream processors, a Boost Clock of up to 3060 MHz and a Game Clock of up to 2520 MHz. Vanquish the competition with 16 GB of GDDR6 high-speed memory clocked at up to 20 Gbps with 64 MB of AMD Infinity Cache technology. The graphics card is constructed with 2x HDMI 2.1 and 2x DisplayPort 2.1a ports to support a wide array of monitors on the market.
Customization to Elevate a Functional Aesthetic
The dual-layer All Metal Backplate combines sleek design and practical functionality for your graphics card with the all-new Quick Connect MagniPlate feature. This secondary magnetic backplate is designed for effortless installation with a magnetic attachment ensuring a secure fit, enhanced heat dissipation and durability to protect your graphics and elevate your build with a clean, modern aesthetic. Pioneering a clean and clutter-free look for your build, the avant-garde STEALTH Hidden Power Cable feature seamlessly conceals external power cables to ensure the SAPPHIRE NITRO+ AMD Radeon RX 9070 XT stands out without any visible distractions. The latest PCIe 12V-2x6 External Power Connector reduces cable clutter and ensures a streamlined, future-ready build - delivering enhanced power efficiency and reliability, providing cleaner and more stable energy to the graphics card, and designed to support higher power demands with improved safety standards. For gamers with builds requiring an 8-pin power connector, an adapter is included in the box.
Unleash Top-Tier Performance with Confidence
The prime cooling of the SAPPHIRE NITRO+ AMD Radeon RX 9070 XT Graphics Card is powered by the distinguished Tri-X Cooling Technology operating in conjunction with the Optimized Composite Heatpipes to aid in optimal heat flow to move and expel heat efficiently. The futuristic Free Flow cooling design is tailored for axial fan systems, featuring an advanced heatsink fin module that optimizes airflow paths. By reducing turbulence and channeling air efficiently, it maximizes heat dissipation, ensuring consistent performance even under heavy thermal loads.
The GPU is mounted onto the 16-phase power design High TG Copper PCB comprised of 12 high-density layers of 2oz copper and high TG PCB to integrate the rapid speed, high current and increased power requirement of the GPU and memory for high PCB stability during operation. The SAPPHIRE NITRO+ AMD Radeon RX 9070 XT uses the elite Honeywell PTM7950 Thermal Interface Material (TIM) for superior thermal conductivity, enhancing the reliability and longevity with outstanding material characteristics.
Secure an enriched low-noise and icy-cooling experience with our innovative AeroCurve Fan Blade Design which builds upon preceding fan designs with advancements that diminish air friction, thereby accelerating the usable fan RPM range while maintaining low noise levels. This refined design ensures an amplified airflow, optimized static pressure, and boosted cooling performance for demanding applications. Coupled with Dual-Ball Bearings, these fans are sure to increase longevity whilst keeping the component quiet. Armed with an effortless system with just one screw holding the fans in place, our fan-favorite Quick Connect Fan Feature makes our latest fan design easy to remove, clean and replace.
Artistry Brought to Life with NITRO+
The polished and luxuriously crafted Cold Rolled Steel Frame encapsulates a fortified and durable shroud structure and provides an extra layer of protection on the sides of the PCB. The FrameDefense mechanical design of the graphics card features a robust framework that ensures exceptional build quality and durability. This solid construction provides a protective enclosure for all internal components, reducing the risk of damage during handling or installation and secures fragile components such as the GPU, memory and VRMs. Install the upgraded L-Shape Support Bracket - crafted with durable materials and a contoured and clean design - as a versatile solution to secure the graphics card in place on the PCIe Slot and prevent sagging. Use the rubber tip of the bracket to help conduct the extraction of the graphics card easily and safely when removing for cleaning and maintenance.
Personalize the look of your system with the iconic ARGB LED Light Bar with a multitude of lighting options to be chosen on the SAPPHIRE TriXX Software. For further individualization, gamers can use the 3-pin header to externally synchronize RGB LEDs between the graphics card and the motherboard, and choose whether the graphics card performs the RGB LED effects or if the motherboard controls the lighting for ultimate sleek perfection.
PURE Returns as a Frosty-White Mainstay
SAPPHIRE Technology also launches the SAPPHIRE PURE AMD Radeon RX 9070 Series Graphics Cards for gamers and creators seeking frosty-white components with quality performance.
  • SAPPHIRE PURE AMD Radeon RX 9070 XT GPU with 16 GB memory, AMD RDNA 4 architecture, DisplayPort 2.1a
  • SAPPHIRE PURE AMD Radeon RX 9070 GPU with 16 GB memory, AMD RDNA 4 architecture, DisplayPort 2.1a
Encased in a white shroud and elegantly elevated design, the SAPPHIRE PURE AMD Radeon RX 9070 XT graphics card headlines with 64 Compute Units and 4096 stream processors with a Boost Clock of up to 3010 MHz and a Game Clock of up to 2460 MHz. It also offers 16 GB of high-speed GDDR6 memory clocked at 20 Gbps with 64 MB of AMD Infinity Cache technology. To support a majority of monitors, there are up to 4 output ports available including 2x HDMI 2.1 and 2x DisplayPort 2.1a ports with DSC outputs.
A Performance Packed Sophisticated Design
The SAPPHIRE PURE AMD Radeon RX 9070 XT graphics card has a solid foundation with the ever-reliable Tri-X Cooling Technology matched with the latest AeroCurve Fan Blade Design with advancements reducing air friction, improved airflow, optimized static pressure and greater cooling efficiency. Simultaneously, the Optimized Composite Heatpipes are engineered for the cooling design to allow for greater heat flow and enabling thermals to spread out and remain cool. The advanced thermal management solution of the Integrated Cooling Module provides efficient heat dissipation across all critical components, ensuring direct contact with the GPU, memory modules and VRMs for uniform heat thermal regulation.
Well-engineered for stability with 14 Phase Digital Power for accurate power control and excellent power efficiency, the GPU is mounted on to the 12-layer High TG Copper PCB, with high reliability of the PCB during operation matching the rapid speed, high current and power requirements of the GPU and memory. Users can expect durability and longevity of graphics cards with the applied Honeywell PTM7950 Thermal Interface Material (TIM) with a high-grade thermal conductivity for a premium solution for high-performance and demanding GPUs. Furthermore, Fuse Protection is built into the circuit of the external PCIe power connector for the utmost confidence and security.
All In the PURE Details
The newly integrated ARGB LED SAPPHIRE Logo grants customization opportunities for a more personalized aesthetic for the build integration of the graphics card. Simply use the Glow! Feature in the SAPPHIRE TriXX Software to create the ultimate lighting solution. For lighting alignment with other components within your build, utilize the included External ARGB Control Sync by using the 3-pin header o select if the graphics card performs the RGB LED effects independently or if the motherboard conducts lighting control.
The beautiful frosty-white Metal Backplate rounds out the strikingly crafted design of the SAPPHIRE PURE AMD Radeon RX 9070 XT graphics card alongside the white-coated shroud for the ultimate high performance white-collar card for an eye-catching addition to every gamer's PC. Users can confidently handle the card without worrying about compromising its integrity or performance with the rigid frame comprising the FrameDefense Feature - creating a resistant casing to accidental impacts or pressure, and securing delicate components like the GPU, memory and VRMs. Install the bundled L-Shape Support Bracket for added security to secure the graphics card and prevent sagging. The rubber tip of the bracket also has a dual usage to aid and simplify the removal of the graphics card during maintenance.
PULSE: The Heart. The Beat. The Game.
The iconic SAPPHIRE PULSE lineup for this generation features two models for the everyday gamer.
  • SAPPHIRE PULSE AMD Radeon RX 9070 XT GPU with 16 GB memory, AMD RDNA 4 architecture, DisplayPort 2.1a
  • SAPPHIRE PULSE AMD Radeon RX 9070 GPU with 16 GB memory, AMD RDNA 4 architecture, DisplayPort 2.1a
Built on the ground-breaking AMD RDNA 4 architecture, the SAPPHIRE PULSE AMD Radeon RX 9070 headlines with 56 Compute units and 3584 stream processors running with a Boost Clock of up to 2520 MHz and a Game Clock of up to 2070 MHz. Visualize the latest 16 GB of GDDR6 high-speed memory clocked at 20 Gbps Effective with 64 MB of AMD Infinity Cache technology. The graphics card supports up to 4 output ports including 2x HDMI 2.1 and 2x DisplayPort 2.1 ports with DSC outputs to align with the latest monitors on the market.
Experience the compact focused and powerful Dual-X Cooling Technology equipped with the newest aero dynamism on the AeroCurve Fan Blade feature by reducing air friction and increasing usable fan RPM range with a low noise output for optimized static pressure and augmented cooling efficiency. These upgraded fans are furnished with Dual-Ball Bearings for longer lifespan, durability and reliability.
The SAPPHIRE PULSE AMD Radeon RX 9070 is fitted with Honeywell PTM7950 Thermal Interface Material (TIM) for superior thermal conductivity, further enhancing the robustness and longevity of the graphics card. Benefit from 12 Phase Digital Power for increased stability, accurate power control and power efficiency, alongside a 12-layer High TG Copper PCB for excellent reliability of the PCB for the high current and power requirements of the GPU and memory. A fine-tuned cooling design with Optimized Composite Heatpipes ensure heat flow, efficiently and evenly spreading out the heat to the entire cooling module. This is compounded by the innovative Integrated Cooling Module which has direct contact with the GPU, memory modules and VRMs for uniform thermal regulation, ensuring stable thermal efficiency under sustained use. The everyday gamer can rest assured with an additional layer of security with the included Fuse Protection built into the circuit of the external PCIe power connector.
The all Metal Backplate provides additional rigidity to prevent bending and to keep dust out. The solid construction of the FrameDefense Feature provides a protective enclosure for all internal components to reduce risk of damage during handling or installation. With a polished black exterior and striking red accents, the SAPPHIRE PULSE lineup is a welcome addition to suit a vast array of battlestations.
A New and Dynamic SAPPHIRE TriXX Software
A new version of the accompanying SAPPHIRE TriXX Software will soon be available to download and will feature a freshly developed modern and clean UI design, for a simpler and more effective user experience - taking control, performance and customization to the next level. Gamers will benefit from a host of improved features including an enhanced presentation and readability of live data and monitoring of the graphics card through Hardware Monitoring for an enhanced gaming experience; the ability to unlock the full potential pf the graphics card with new Performance and Efficiency Profiles available at the click of a button; refreshed lighting customization with Glow! - alongside the latest ARGB mode called Comet for a striking lighting effect. New TriXX will feature TriXX Boost on all products to take gaming to the next level by adjusting your resolution options. Adjust resolution through a customizable scale or from additional custom resolutions based on user input. Increase FPS by slightly decreasing resolution through the TriXX software, which is adjusted through the AMD Radeon Image Sharpening technology for an incredible advantage. With the new TriXX, ultimate performance and control are right at your fingertips.
Availability
The SAPPHIRE NITRO+, SAPPHIRE PURE and SAPPHIRE PULSE AMD Radeon RX 9070 XT and RX 9070 series graphics cards are shipping now, and will be available from selected SAPPHIRE e-tailers and retailers worldwide.
6,169 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
113 (1.53/day)
CO
System Name Zen 3 Daily Rig
Processor AMD Ryzen 9 5900X with Optimus Foundation block
Motherboard ASUS Crosshair VIII Dark Hero
Cooling Hardware Labs 360GTX and 360GTS custom loop, Aquacomputer HighFlow NEXT, Aquacomputer Octo
Memory G.Skill Trident Z Neo 32GB DDR4-3600 (@ 3733 CL14)
Video Card(s) Nvidia RTX 3080 Ti Founders Edition with Alphacool Eisblock
Storage x2 Samsung 970 Evo Plus 2TB, Crucial MX500 1TB
Display(s) LG 42" C4 OLED
Case Lian Li O11 Dynamic
Power Supply be Quiet! Straight Power 12 1500W
Mouse Corsair Scimitar RGB Elite Wireless
Keyboard Keychron Q1 Pro
Oh no...theh are adopting 12V 2x6 too huh? Hope they load balance it.
6,169 (0.84/day)
Ikenai borderline!
Mouse Logitech G604
1,144 (0.18/day)
Florida
System Name Blackwidow/
Processor Ryzen 5950x / Threadripper 3960x
Motherboard Asus x570 Crosshair viii impact/ Asus Zenith ii Extreme
Cooling Ek 240Aio/Custom watercooling
Memory 32gb ddr4 3600MHZ Crucial Ballistix / 32gb ddr4 3600MHZ G.Skill TridentZ Royal
Video Card(s) MSI RX 6900xt/ XFX 6800xt
Storage WD SN850 1TB boot / Samsung 970 evo+ 1tb boot, 6tb WD SN750
Display(s) Sony A80J / Dual LG 27gl850
Case Cooler Master NR200P/ 011 Dynamic XL
Audio Device(s) On board/ Soundblaster ZXR
Power Supply Corsair SF750w/ Seasonic Prime Titanium 1000w
Mouse Razer Viper Ultimate wireless/ Logitech G Pro X Superlight
Keyboard Logitech G915 TKL/ Logitech G915 Wireless
709 (0.34/day)
Moscow, Russia
Processor Intel 12600K
Video Card(s) Palit RTX 4080
Display(s) Dell S2721qs
Case Phanteks P300A Mesh
Mouse Glorious Model D-
Only Nitro+. Pure and Pulse are 2x8-pin.
Besides, Nitro is probably going to cost way too much to make it a sensible choice for someone who isn't a die-hard Sapphire/AMD fan.
7,431 (1.04/day)
Video Card(s) Sapphire Radeon RX 590 Nitro+ SE (Wishes for RX 9070 XT Pulse) | Intel® Iris® Xe Graphics
Only the Nitro+ have the 12VPWR connector both the Pulse and Pure have 8pin PCI-E connectors.
You can all see more details on Sapphire's own page for the different models
RX 9070 Nitro+: https://www.sapphiretech.com/en/consumer/nitro-radeon-rx-9070-16g-gddr6
RX 9070 XT Nitro+: https://www.sapphiretech.com/en/consumer/nitro-radeon-rx-9070-xt-16g-gddr6
RX 9070 Pure: https://www.sapphiretech.com/en/consumer/pure-radeon-rx-9070-16g-gddr6
RX 9070 XT Pure: https://www.sapphiretech.com/en/consumer/pure-radeon-rx-9070-xt-16g-gddr6
RX 9070 Pulse: https://www.sapphiretech.com/en/consumer/pulse-radeon-rx-9070-16g-gddr6
RX 9070 XT Pulse: https://www.sapphiretech.com/en/consumer/pulse-radeon-rx-9070-xt-16g-gddr6
Personally I will see if I can buy a Pulse or Pure because Sapphire didn't send me one :(
961 (4.51/day)
I had a good impression about sapphire. This is now gone. This makes future buying decisions easier. 12V6 - nope. I will not bother checking every sapphire card for the connector when other amd graphic cards are 100% - 12V6 free from the connector.
Skimba
5 (0.01/day)
You can see clearly from their marketing material that it has only 2 shunt resistors and fuses. It will be cooked
Such a shame sapphire took the route of idiocracy.
It appears trendy to put melting connector to top model so people can fail their cards faster and buy a new one. Who would have known everyone else starts to follow when Nvidia figured out its possible and people would still buy the product.
7,431 (1.04/day)
I haven't like the design and colour scheme of the Nitro+ series since my Sapphire Radeon RX 590 Nitro+ Special Edition which is the reason why I just get their Pulse or Pure instead awesome cards :D
Notional
2 (0.40/day)
That Nitro+ card is one of the nicest looking cards on the market. But I don't understand why it's 3.2 slots and not just 3? Or why it doesn't have screw holes on the right side for sturdier installation.
MxPhenom 216
ASIC Engineer
13,098 (2.47/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
A 300w GPU should have no issues with that cable. F****ing absurd statement
348 (0.51/day)
System Name Can it run Warhammer 3?
Processor 7800X3D @ 5Ghz
Cooling Enermax Liqmax III 360mm
Memory Teamgroup DDR5 CL30 6000Mhz 32GB
Video Card(s) Gigabyte 4090
Storage Silicon Power XS70, Corsair T700
Display(s) BenQ EX2710Q, BenQEX270M
Case NZXT H7 Flow
Audio Device(s) AudioTechnica M50xBT
Power Supply SuperFlower Leadex III 850W
Somebody doesn’t want a failed connector standard on their $600+ graphics card, and that’s absurd to you?
I agree, and I’ll be looking for a 3x8 model.
MxPhenom 216
ASIC Engineer
13,098 (2.47/day)
Loveland, CO
Yes, on a 300w card...
5090 is 575w, and will hit 600w regularly. So yes, its absurd
348 (0.51/day)
Case NZXT H7 Flow
So my options are a connector with known issues or one with none…
Really easy choice
961 (4.51/day)
Show me the 8D report and all the specs. Than we can talk. Especially step 7.
years ago quality claims had to be finished for the automotive branch in less than 7 calendar days. We had nice customers who filed quality claims on friday 11 am. So no early friday end of work shift for myself in the quality department
How many days do we have these issues wiht that nvidia gpu connector? Or should I already write, how many years do we have problems with that nvidia connector?
Also show me the FMEA for that connector, which dates back to the first issue reported.
Note: I talk about this: https://asq.org/quality-resources/fmea
I do not want to use an adapter or buy a cable just for a graphic card. Other graphic cards do not need a cable adapter or a newer cable or a newer power supply unit which ships with that connector.
go on - give me a non - absurd statement.
Whataboutism: It's the same why I did not bought any gigabyte mainboard. Because of those nice gigabyte power supplies which exploded like a fire cracker. Or any SAMSUNG NVME - because of those Firmware issues over all those years.
edit: other thread implies that this issue is well known since nvidia 3090 ....
MxPhenom 216
ASIC Engineer
13,098 (2.47/day)
Loveland, CO
Really easy choice
Yes, known issue on cards that pull close too or beyond the connector's specs.
Easy choice if you live your life by irrational fears.
What is the common denominator on these melting connectors? What GPU has been getting covered overwhelmingly in the reports? What is the power demand of said card, relative to what this 9070XT is specc'd at?
2,539 (1.18/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
Indeed. For the styling of a brick, it's a very stylish brick :laugh:
I have a XTX NITRO+ @TM, and was tempted by the 9070XT NITRO+, in the hopes I could get my PCIe Gen4x4 slot back. Nope. not happening, apparently.
If 300+W over a single +12V / +12V/Gnd pair / Gnd were 'safe', then sure.
Without active input balancing, there's a high chance of one wire/pair becoming the primary current path.
Perhaps, the short length between card and PSU will keep things manageable but as-is, 300W would be roughly double what a single 16AWG conductor is rated for.
MxPhenom 216
ASIC Engineer
13,098 (2.47/day)
Loveland, CO
If 300+W over a single +12V/Gnd pair were 'safe', then sure.
You really think the engineers of these cards would allow it to do that? There's no world to you where the board makers for these cards with understanding to what is happening on Nvidia cards to just not account for any of that?
That isnt even happening on 5090s without the line balancing unless you force it to do that by cutting wires like Jayztwocentz did in his video.
2,539 (1.18/day)
Olympia, WA
I don't 'think'. We've all watched it happen.
-then, had our own 'lying eyes' be confirmed true by long time and highly-technical professional-enthusiasts (Der8aur, Buildzoid) within the community/industry.
As if that were not enough confirmation, we're now at least 3 revisions into this new connector. -Meaning even the manufacturers and sponsors of the interconnect recognized shortcomings and oversights (repeatidly).
It's demonstrated already. Indeed, "they* allow it to do that".
*AIBs, OEMs, ODMs, etc.
MxPhenom 216
ASIC Engineer
13,098 (2.47/day)
Loveland, CO
So you don't think engineers at Sapphire OR Asrock (both of who so far have announced their cards with this connector) is not accounting for "lesson learned" from Nvidia cards?
2,539 (1.18/day)
Olympia, WA
I think they're just as liable to(wards) industry norms, as any other company:
[snip]
