Sapphire Intros FS-FP5V SFF Motherboard Based on Ryzen Embedded
47,376 (7.52/day)
Sapphire introduced the FS-FP5V, a mini-ITX (147.3 mm x 139.7 mm) SFF motherboard designed for AIO desktops, digital signage boxes, and compact desktops. At the heart of this board is an AMD Ryzen Embedded V1000 series FP5 SoC based on the 14 nm "Raven Ridge" silicon. Since this SoC also integrates a southbridge, the board is practically chipset-less. The Ryzen Embedded V1000 chip is configured with a 4-core/8-thread "Zen" CPU clocked at 2.00 GHz with 3.35 GHz boost, and 4 MB L3 cache. The iGPU is a Radeon Vega 11, which may look overkill, but is required to pull the four DisplayPort 1.4 outputs of this board (handy for digital-signage applications).
The Ryzen Embedded V1000 is wired to two DDR4 SO-DIMM slots, supporting up to 32 GB of dual-channel DDR4-2933 memory. Storage connectivity includes an M.2-2280 slot with PCI-Express 3.0 x4 wiring, an M.2 E-key slot with x1 wiring for WLAN cards; and a SATA 6 Gbps port. Networking options include two 1 GbE interfaces. USB connectivity includes two USB 3.1 gen 1 ports at the rear-panel, and two USB 3.1 gen 1 ports (direct ports) at the front side of the board, one each of type-A and type-C. Stereo HD audio makes for the rest of it. The board draws power from either 2-pin DC (external) or 4-pin ATX.
2,186 (0.50/day)
Deez Nutz, bozo!
Definitely an mini-STX form factor. Still, it packs a lot of features for it's size.
123 (0.03/day)
WV
System Name Portable Gamer
Processor Intel Core i5-3570K @ 4.2GHz
Cooling CPU / Noctua NH-L12 GPU / ARCTIC Accelero S1 Plus
Memory G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400
Video Card(s) EVGA NVIDIA GTX 960 SSC
Storage ADATA SP550 480GB SSD
Display(s) ASUS 23" LCD
Case SilverStone Sugo Series SG05BB-LITE
Power Supply SILVERSTONE ST45SF 450W
Mouse Logitech G500
Keyboard CMStorm Trigger Z
Software Windows 8.1 Pro
Even though a cooler isn't pictured embedded boards come with coolers.
According to Tom's Hardware this board will have 4 different chip options see here. So I bet some coolers will be passive and some active depending on TDP.
silentbogo
5,586 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Now I can't wait to buy a barebone based on this thing. Definitely a worthy contender for my "dream-machine" which I wanted to build based off Xeon D supermicro boards.
But there's one interesting question - how to cool this board and what coolers fit on it
From the looks of it the standard AMD box heatsink w/ through-hole mount will fit just fine (akin to AsRock STX boards w/ standard LGA115x mounts).
According to AMD's datasheet it's 12-54W range (which must read 24W max TDP for dual-core parts and 54W max TDP for quad-core parts), so even on the lower side I doubt just passive will suffice(unless you put a monstrous heatsink like on ye olde embedded Athlons of the past decade). Low-ball digits in that range are "scenario" TDP for downclocked SoC.
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Very nice, board is great for it's target. While this specific board is not for me, I can see upgrading my G4600T / ASRock H110 STX build once more Ryzen Embedded configurations are available. Keep it up Sapphire! :)
I'm cooling with a Cryorig C7, but I have a standard socket. The hole pattern on the Sapphire board is definitely smaller. Early adopters (outside of the target) will most likely need to take what's given to them and focus on case airflow.
2,355 (0.46/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
4 DisplayPort outputs? curious
silentbogo
5,586 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
What's even more curious is that the platform features a dual 10GbE interface on the SoC itself (dual 1GbE for the lowest part), but I've just noticed that Saphire decided to opt-in for a pair of old and crappy RTL8111GR's, probably 'cause they have a "leftover" pair of PCIe lanes...
42,984 (6.72/day)
Too bad they never could become a big mobo contender against Asus, Gigabyte and MSI.
