Sapphire Nitro+ Radeon RX 580 8 GB
AAraujo
5 (0.00/day)
Hello, I recently bought this card from a miner who said that flashed it with the original BIOS but I suspect this is the wrong "performance bios" for this card and also I'm not sure if I have the stock "quiet bios" either...
The computer seems to be stable, at least no issues in 2D mode but I won't risk gaming before reverting everything to stock first.
Anyone can help me please?
Thank you very much!
43,298 (6.75/day)
Give me a moment and i will give all info needed
Here you go, just read all directions, make sure to flash 1340 position with the 1340 bios from the link and the 1411 position with the 1411 bios from the link below, get the flash tool from the link as well.
@AAraujo
AAraujo
5 (0.00/day)
Wow, that was fast! Thank you so much, I'll try it tomorrow and give you some feedback :)
43,298 (6.75/day)
Easy card, all values are the same is why lol
AAraujo
5 (0.00/day)
I started with the 1411 bios file and after rebooting the Radeon drivers won't recognize the card in Windows anymore.
Then I flashed again with the bios backup and everything seems fine.
Are you sure those are the correct BIOS files?
222 (0.11/day)
System Name Temp SFF Rig :'(
Processor Q9550
Motherboard HP OEM
Cooling just about...
Memory 8GB DDR2 :rockout:
Video Card(s) Gigabyte GT 1030 LP OC to 1850+ Boost!!!
Storage 120GB SSD & 160GB HDD :(
Display(s) Acer ED242QR - 24" Curved 1080p 75Hz Freesync
Case HP SFF Desktop
Power Supply HP SFF 260w
Software Windows 10 1903
The gpuz ss you posted initially look OK, did you bk them up, if so reflash and put under 3d load, no need to worry if it's stock l bios it will work no issues, if not you'll likely get a crash, no buggy, just restart, there's no risk to the card in doing this.
AAraujo
5 (0.00/day)
It seems stable with the quiet bios.
With the performance bios I get sound distortion in games (sound is coming from the HDMI cable) and also occasional D3D errors and crashes to the desktop :(
222 (0.11/day)
Processor Q9550
Motherboard HP OEM
Case HP SFF Desktop
OK ill have a look for some for you to try
AAraujo
5 (0.00/day)
Thanks!!
What is a good quick test for 100% stability?
I though it was Furmark but crashes and issues were in real games only...
222 (0.11/day)
Processor Q9550
Motherboard HP OEM
Case HP SFF Desktop
Just run a game or 3dmark you should know straight away
There are more but see how you get on with those first
