sapphire nitro+ rx570 8gb OC
rhynow
17 (0.01/day)
philippines
Need a little i bought a mining card and the seller said that the bios was aleady switch back to default but when i start using it i cant install any driver and device manager is giving an error which is cause by mining or corrupt bios. the seller send me an app that i need to run in order for the card to work and it work but i notuce that un every games even if its low settings its very laggy. I tried updating it to the latest software but its giving me error
even i already run tye ati pixel patcher it still giving me error with the latedt driver can you check if this bios are the default or still mining
left bios
right bios
Get picture of white sku sticker from side of card heatsink. Its close to pcie contact edge side
The side with the 1340 bios already should be running this bios (typically right bios switch position)
so ill be using this bios to flash the bios on tje second pic or the right side bios right?
Do this one first not the 1340 default yet.
Use the 1244 bios for the first pic where 1244 is the default clock.
the second bios says unverified is that safe?
It means it hasnt been verified by tpu itself.
Yes go ahead and try it, if it doesnt fix (clock speed at 0/0) or blank screen, boot up on the 1340 side and then switch back to the 1244 side and we. Will try next bios
I see, thanks for the response i'll get back to you once im done.
What about it?
Sorry for the late update i already flash both bios and drivers was installed correctly but still notice some lags on games even at very low settings saw same specs at youtube and they were able to run some games even on high settings flawlessly but on me even at low getting lags on games
Need your specs.
Specs is :
Ryzen 5 2400G
8gb 3200mhz single stick
rx 570 8gb
I saw post in youtube with the same specs and he was able to run division from medium to hight and some settings are set to ultra
on my end even eveything is set to low im experiencing lag
I cant verify a video. Most of your specs are missing, that included what brand and model of ram, motherboard, power supply, solid state drive os build, what clocks gpu are running and what games and their settings/reaolutions, what monitor is being used.
Sorry bout that
ADATA XPG D30 8gb 3000mhz
Mortar B450
ryzen 5 2400G
Deepcool 600watts
WD BLUE 1 tera
Nitro rx 570 8gb
for the GPU clock is just flashed the bios on the right side and didn't do anything after the flash so for the clock i believe its 1340mhz
Sorry bout that
Mortar B450
ryzen 5 2400G
Deepcool 600watts
WD BLUE 1 tera
Nitro rx 570 8gb
That a HDD?
And what video are you comparing to???
on this video customer is using Ryzen yet he still have the settings some high and ultra sorry bout my storage it is WD BLUE HDD 1 tera
ryzen 3 2200G compared to mine ryzen 5 2400G
He is using a ssd is why. Also are you using a dual channel kit for ram?
No its a single stick ram
thats the problem, go for dual channel 2x4gb with 3ghz speed atleash, also ocing the vega 8 to 1600-1650mhz, you will get extra 5-10% free preformance boost:)
What do you mean by doing OC on vega 8 im using rx 570 8gb
oh i was thinking your comparsion vega8&11, well all you need is dual channel ram then:D
You are holding the system back by using single channel and a hdd, get a 16 gb dual channel kit and a ssd to put windows on
