Sapphire Nitro+ Vapor 7900 XTX RGB Bar not working
KoffyGG
4 (0.01/day)
Wondering of someone could somehow help me out.
I'm having issues with my GPU. It's RGB bars stopped working. They worked perfectly fine until I wanted to swap colors or set Trixx to work from an external source like MSI Mystic Light or SignalRGB RGB controller software. I've since uninstalled every RGB controller software.
So far, I've tried the following troubleshooting:
  • Uninstalled all RGB controller software.
  • Uninstalled AMD Adrenalin software
  • Uninstalled AMD Chipset driver
  • Unplugged and plugged the GPU back on the same motherboard.
  • Unplugged and plugged the GPU on a different computer.
  • Shorted JT1 header
  • Cleared CMOS
  • Restored optimal defaults in BIOS
  • Updated Led Firmware.
  • Fresh Windows 11 install on an empty SSD
  • Fresh AMD Adrenalin Driver
  • Fresh Trixx 9.0 install.
    So far I'm in a tech support ticket with Sapphire and they've also told me to contact Althon Micro.
The issue with the GPU is only regarding the RGB bars. Gaming performance and everything else is as it should. I recorded the following video once I reinstalled windows and the GPU driver and Trixx 9.0:
43,188 (6.73/day)
You must turn off csm in the uefi
43,188 (6.73/day)
Althon Micro is their RMA Department, reach out to them as Sapphire directed you to do
2,969 (2.05/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
Probably broken or not correctly plugged in.
43,188 (6.73/day)
Toothless
Tech, Games, and TPU!
9,712 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
9700 XTX? Dang dude you're from the future.
7,332 (4.93/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Personally I would never RMA a card because the RGB lighting stopped working. There's a reasonable chance that the card you will get back is a stinker of a sample, or may potentially have issues that your present hardware does not. Instead of that - I'd leave it as is and then eventually just get some upgraded cooling for it. Invest in a water block, man! :D
43,188 (6.73/day)
Not everyone is you though, its not working as advertised.
Solaris17
Super Dainty Moderator
27,186 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Bios is already in UEFI mode
but is CSM off? Some BIOS support dual config. In my experience CSM must be explicitly set to disabled.
43,188 (6.73/day)
Some boards its Auto or Disabled (On or Off)
7,332 (4.93/day)
São Paulo, Brazil
Sure, but it's fluff. If it's just the RGB leds, you can always activate the warranty closer to its expiry date anyway. :D
7,328 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
In a lot of cases the companies won't extent your warranty on the product you get back.
Companies have their way of transferring the remaining guarantee to the replacement product they send you back.
It would be something else if you could purchase warranty extension.
KoffyGG
4 (0.01/day)
I mean bottom line is that a 1000 bucks card isn't working right and so far other 4 people have reached out to me with the same problem. Maybe it's just cosmetic and won't hit the performance of the card but it is still defective and within warranty so I might aswell just apply for it.
5,576 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
that's great if the problem was ReBar bt it's the RGB light bars on the card that aren't working
Personally I would RMA it, it's under warranty so let them deal with it
KoffyGG
4 (0.01/day)
The other day I turned the PC on and the GPU's bar lit up almost completely. Still stuck on one color and looking washed out in the middle and wouldn't react to any changes I made in the software. Next time I turned it on the bar didin't light up at all.
7,332 (4.93/day)
São Paulo, Brazil
True, if your card isn't bad, you could maybe request of the RMA department another complete cooling assembly with the shroud and lightbars, they would probably ship you a replacement with no downtime. The downtime is what sucks, man.
1,293 (1.52/day)
Just throwing this out there (and apologize if it was brought up above and I didn't catch it), but are you using the three pin cable to connect the GPU to the MB for ARGB control? If so, is there any difference when connected/disconnected? And is it connected to a compatible port on the MB? There's usually two different types.
43,188 (6.73/day)
Rma the card, dont waste time
