Sapphire pulse RX 7900 xt start up issues
3 (0.08/day)
Processor R7 5800 X3D
Motherboard MSI B450 Tomahawk
Cooling ID-cooling SE 226 xt
Memory 4 x 8gb Corsair vengeance 3000
Video Card(s) RX 7900 xt
Storage SP A80 2TB M.2 NVME
Power Supply Corsair RM1000e
Hi I have been having problems at start up windows 11 sometimes I get a garbled multicolour strip on a black background Sometimes it will boot to desktop & freeze, sometimes it will not recognise Adrenalin software.
After 2 or 3 restarts it will run fine all day. Anybody else getting these issues & have you found a solution any help would be greatly appreciated.
2,835 (2.12/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
tried a clean driver installation with DDU?
41,482 (6.58/day)
Have you swapped video cables? Tried a different monitor.
Provide full and detailed specifications of your computer please. While you are on desktop get hwinfo64 load sensors only and get a screenshot of power supply volts and gpu volts
554 (0.11/day)
mississauga, on, Canada
System Name YACS amd
Processor 5800x,
Motherboard gigabyte x570 aorus gaming elite.
Cooling bykski GPU, and CPU, syscooling p93x pump
Memory corsair vengeance pro rgb, 3600 ddr4 stock timings.
Video Card(s) xfx merc 310 7900xtx
Storage kingston kc3000 2TB, amongst others. Fanxiang s770 2TB
Display(s) benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H,
Case lian li LANCOOL III
Audio Device(s) obs,
Power Supply FSP Hydro Ti pro 1000w
Mouse logitech g703
Keyboard durogod keyboard. (cherry brown switches)
Software win 11, win10pro.
on AMD (and you system has never installed nvidia drivers) just uninstall the amd Graphics software in the Win11 remove programs and apps… then install the new driver. (24.7.1 is not good for Black Myth:wukong. IMO, you MUST go back to 24.5.1 for it to run.). when 24.8.1 is out, perhaps that will fix the problems… but i digress.
in any case, make sure your 7900xt is level… problems have been solved by making Sure your graphs card is level.
2,835 (2.12/day)
Germany
AMD has a specific hotfix driver for BM Wukong since day one and with that it works flawless.
41,482 (6.58/day)
Parallel with the top and lower edge of the motherboard, sometimes the motherbord is not properly aligned in the case.
554 (0.11/day)
Processor 5800x,
Mouse logitech g703
i did not know that. 24.5.1 works. and the 24.7.1 stalled and stopped the game… went www surfing and used reddit advice…
(will try the hotfix, 24.7.1 reports a but more stats in the overlay…)
2,835 (2.12/day)
Germany
237 (0.13/day)
I have the Pulse 7900XTX. Bought it NIB on another forum for $610 shipped :pimp: It has been rock solid stable. I am currently on the 24.10.37.4 betas and so far so good for my use. When I first installed it, it was picky about HDMI cables for my TV connection. It did not like the 18Gbps Monoprice, but works perfect with Amazon Basics 48Gbps.
I presume you have everything in order like ample wattage and quality PSU with no dodgy cable extenders. Latest mainboard bios and chipset drivers. Nuked the GPU drivers with DDU and started fresh. Tried a different DP cable and or different port on the card. Checked that the fans are spinning up properly etc.
3 (0.08/day)
Thank you for your replies have tried DDU on many occasion's and also tried windows ten. I have just swapped DP cable & Adrenalin software has just this second updated so have done that will let you know tomorrow if it has fixed it as it only seems to happen on cold boot.
472 (0.36/day)
Germany
System Name Homebase
Processor Ryzen 5 5600
Cooling Scythe Mugen 5 RGB
Mouse Sharkoon Sharkforce Pro
Keyboard Fujitsu KB955
2,835 (2.12/day)
Germany
Black Myth Wukong does no longer crash wit 24.8.1 as well. Hotfix is no longer needed.
41,482 (6.58/day)
Read the last part please
3,426 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -8~12
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (375W current) PowerLimit, 1060mV, Adrenalin v24.8.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.1882), upgraded from Win10 to Win11 on Feb 2024
Can you please provide details of your system?
The more the better.
Write them in your profile and make them visible to all users.
Without knowing your system in details trying to find a solution is like shooting in dark.
Cold boot issues are usually power related.
41,482 (6.58/day)
And that is what I was getting at with my first reply on this thread
3 (0.08/day)
Booted this morning got regular MSI logo then black screen with two horizontal strips of distorted colours one at the top one at the bottom of the screen. Restarted and it has worked perfectly for 2 hours
41,482 (6.58/day)
You aren't listening
Provide full and detailed specifications of your computer please. While you are on desktop get hwinfo64 load sensors only and get a screenshot of power supply volts and gpu volts.
