So long story but this card i got for free i started messing with it on a HiveOS rig when i got it and we get Radeon RX580 UNKOWN Memory (when chips are on) one bios and other we get Radeon RX 460/470 i cant get the Linux or Windows Flasher to work so i said what ever i have a programmer i removed both chips then booted with card i get Radeon RX 460/470 on both switch positions even with the chips removed must be something in the GPU or another chip some where with some sort of programming or identification in it.
Here is some pics of what Hive is seeing as of now with no bios chips plus the 2 locations of the bios chips i removed from board:
I know i got the right chips as auto detects pick this up with no help
Here is a read of a chip
Or maybe hiveos is seeing something and just labeling it that way before removing both BIOS chips also to take note there where no fan speeds or temps.
Any ways i been fiddling around and maybe its just not like a motherboard or something because i flash one chip solder back to board and nothing much changes or im using the wrong bios but i match the memory type as far as the other parameters i have no idea so any help here would be good.
I would just like what you guys think is a working bios file ill flash to both chips solder back to board and see whats up...
I guess question is also do both Bios have to be programmed and on board at same time for everything to register i have ran in to dual nands in the past that where in like a RAID 0 lets say both required to work... I don't think this is the case as from reading each chip there different but alike.
If any one needs more pics or info let me know!
Here is all the labels i can find on card!
Thanks in advance!
Thanks in advance!
