Sapphire R9 290X Tri-X freeze with anything past 13.12
8 (0.00/day)
Processor AMD FX-8320 @ 4.3 GHz
Motherboard ASUS Sabertooth 990FX R2.0
Cooling Cooler Master Hyper 212 Evo
Memory 2x4GB Kingston HyperX Fury 1866 MHz
Video Card(s) Sapphire R9 290X Tri-X OC
Storage 500 GB WD Blue, 2TB WD Green
Display(s) ASUS ML238H
Case Enermax Ostrog
Audio Device(s) Asus Xonar DGX
Power Supply Corsair RM850
Software Windows 8.1 x64
Hello. I have a problem with my fairly new R9 290X (got my new build the 26th of June): since I got it, I haven't been able to use any driver past 13.12.
As soon as I finished building my rig, I installed Windows 8.1 x64 and the 14.4 drivers. Everything was going fine, BF4 was going fine too. Then, I went into the graphics options and changed from DirectX to Mantle and the whole system froze. Mouse wasn't moving, sound wasn't working, keyboard caps light wasn't changing, etc. I had to hard reset, but after BIOS POST, I kept getting a blank screen/black screen.
Uninstalled 14.4 from safe mode and installed 13.12 and everything works.
Now, I know that I can keep using 13.12 but I really would like to use more recent drivers, with Mantle.
If I try to install anything past 13.12 (I tried 14.1, 14.2, 14.3, 14.4, 14.6, 14.7), even with a complete clean install of Windows 8.1 or Windows 7, after the driver installation + reboot, I can't open any applications that are somewhat related to the GPU, like: GPU-Z, HWMonitor, MSI Afterburner, etc, but I can open applications like Windows Explorer or Firefox.
The biggest problems, though, are the freezes. If I open Internet Explorer, the system freezes. Same thing if I try to open any games, sometimes I get a freeze even in 30 seconds after logon, doing absolutely nothing.
What could be the problem here? My card's memory is Hynix by the way.
Thank you.
19,371 (3.57/day)
Does your new card have a dual bios? For giggles, switch to the other bios and see if that helps...
8 (0.00/day)
Case Enermax Ostrog
Yes, it does. I tried with both Quiet bios and Uber bios but nothing changed.
Thanks though.
12,062 (2.63/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
14.4 drivers is a crap. Wait for 14.7 or back to 13.12 is you can't wait.
Cursor on BSOD, lol.
Yup, 0x7E BSOD's are almost always related to dodgy video drivers...
EDIT: Uninstall 14.4, run a driver sweep, redownload 14.4, and click on custom installation, untick the AHCI driver that it tries to install, but install the rest of the components. DO NOT INSTALL THE 14.4 AHCI COMPONENT
This should fix everything. The issue is with AMD Chipsets that use AMD's AHCI driver. 14.4 has a broken AHCI driver, so don't install that with the driver update.
8 (0.00/day)
Case Enermax Ostrog
The thing is, there is no AHCI driver in the list.
12,062 (2.63/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
Try unticking everything except the Display and HDMI. It's a start. If that works, begin adding on from there.
8 (0.00/day)
Case Enermax Ostrog
Already tried that, installing just the Display drivers. Same thing, freezes and can't open GPU-related applications.
I also tried installing just the driver .inf from Device Manager, same thing.
12,062 (2.63/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
All of this after running driver sweeper? Seems your card is really boned if you can't install a WHQL video driver with just the video only and not all the rest.
8 (0.00/day)
Case Enermax Ostrog
I didn't use Driver Sweeper, but I used Display Driver Uninstaller (DDU).
If the problem is my card, why can I use 13.12 with no problems? :/
12,062 (2.63/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
Not a clue, I was under the impression WHQL was supposed to be the stable version.
8 (0.00/day)
Case Enermax Ostrog
This is weird..
I contacted AMD, and they told me to ask for a RMA. Contacted Sapphire, and they told me it's a driver problem so I should ask AMD.
I asked AMD again 4 days ago and they said "I've added this to the Catalyst issue tracker, we'll take a look. We may contact you for additional details. Will be tough to repro because it's isolated, may need your help."
All I can do is wait I guess.
4,284 (1.11/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
This is weird..
Try downloading the 14.7 beta drivers and see what happens. My cards are PowerColor R9 290X but I am having no issues with my trio right now.
8 (0.00/day)
Case Enermax Ostrog
As I wrote in the OP, I tried 14.7 too and nothing changed.
4,284 (1.11/day)
Texas
Mouse Logitech G5
Oh I missed that when reading sorry, well anyway it sounds like a bad video card in all honesty and I would RMA it.
I do not understand why 13.12 would be stable and the other versions would not, but this seems to be the problem at least to me.
41,905 (6.61/day)
Tell sapphire you tried the card in another machine and it failed to work. Record the pn and sn down of the card and send it back for replacement.
8 (0.00/day)
Case Enermax Ostrog
Alright, I'll probably wait then. I can't RMA it right now cause I'm going on vacation. When I'll be back, I'll check if the new drivers have fixed it, if not, RMA.
Thank you guys.
