Sapphire radeon X1650 pro 256MB AGP bios flashing!
woolf
6 (0.00/day)
Hi there!;)
I still got no answer to my question: Is it possible to bios-flash my video card? If yes, than what utility shall I use - winflash or atiflash (I think none of them works..:banghead: ) or something else??...:confused:
If anyone has a clue, please help.
Thanks, woolf.
Once an overclocker always an overclocker.
what is it that you want to get out of bios flashing that card??? i dont think that core has anything left to give...no extra pipes, rops, anything.....it clocks higher then a x1600xt and has the close to the same specs.....
the reason no one has responded might be because no one knows....DL RivaTuner and see if the voltage can be adjusted for the memory ( i doubt it ) other then that, i doubt anything else could really be done to that card....also get ati tool and take a screenshot of your fuse data then post it here....this will let someone with more experience help you find out if anything can be opened up on that card....gl to ya...:rockout:
theres really nothing more that card can give... you can OC it with atitool, rivatuner, rage3d tweak... just about any OC utility really, but thats it.
i think his problem is that he cant run any overclock utility in Vista....so he wants to make a bios so he can change his default clock to his overclock, then no clocking utility would be needed....
i had to read his other posts to figure this out....
Yes, ATIonion, that´s exactly the case here. There isn´t any OC tool to work with vista so far (or am I mistaking??):wtf:
Plus in windows XP I OC -ed my card from stock 600/700 to 675- core/ 770- memory with no problems at all so you can see that there is a lot more this card can offer... I would like to bios flash my card only to OC it, nothing else..:cool: (and then I wouldn´t have to bother myself with no OC utilitys...:cry: )
Do You see my point here?
