sata 3
1,205 (0.20/day)
Huntington Beach CA
System Name ROG MACHINE
Processor Ryzen 9 5950x
Motherboard Crosshair viii Hero
Cooling NZXT Kraken Z 73 my corsair H115i kicked the bucket corsair sucks lol
Memory g-skill rgb 64gb 4x16gb ddr4 3200mgz
Video Card(s) MSI Ventus 3x oc 3080
Storage Samsung 990 pro 4TB M.2 Samsung 980 pro 2TB M.2 two 16TB Seagate Iranwolf HD 10TB and a 12TB ironwol
Display(s) Samsung Odyssey G9 49-inch Monitor/ Samsung C34J79x 34 inch curved monitor
Case thermal take view 71 rgb
Audio Device(s) creative ae-5 sound card
Power Supply Seasonic Vertex 12 watt power supply
Mouse ROG CHAKRAM
Keyboard Rog Strix Flare II Animate Keyboard
Software windows 11 pro 64bit
i know this is a dumb question but i have sata 2 and thinking of getting i ssd but its sata 3 will it work on a sata 2?
2,644 (0.45/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
yes it will work exactly the same, only at half the speed of sata 3.
913 (0.16/day)
nebraska
System Name TheBruise
Processor i7-960
Motherboard Gigabyte x58A -Ud5
Cooling Vantage ALC push pull/2x180mm fans/1x120mm silverstone
Memory 12GB Corsair Vengeance 1600Mhz
Video Card(s) 2 Sapphire Vapor-X 5870's in Xfire
Storage Ocz Vertex 3 Max Iops (OS) 300GB Velociraptor, 750 GB WD Black
Display(s) Asus 23" VS238H-P
Case Silverstone Ft01-BW Fortress
Audio Device(s) Creative X-fi Titanium
Power Supply Corsair HX-850
Software W7pro SP1
Itll work just fine....But if you havent bought an ssd yet why not get a Sata2 one? Itll be cheaper....unless your gonna upgrade your mobo soon...(Fingers crossed!)
10,242 (1.45/day)
Granite Bay, CA
System Name Big Devil
Processor Intel Core i5-2500K
Motherboard ECS P67H2-A2
Cooling XSPC Rasa | Black Ice GT Stealth 240 | XSPC X2O 750 | 2x ACF12PWM | PrimoChill White 7/16"
Memory 2x4GB Corsair Vengeance LP Arctic White 1600MHz CL9
Video Card(s) EVGA GTX 780 ACX SC
Storage Intel 520 Series 180GB + WD 1TB Blue
Display(s) HP ZR30W 30" 2650x1600 IPS
Case Corsair 600T SE
Audio Device(s) Xonar Essence STX | Sennheisser PC350 "Hero" Modded | Corsair SP2500
Power Supply ABS SL 1050W (Enermax Revolution Rebadge)
Software Windows 8.1 x64 Pro w/ Media Center
Benchmark Scores Ducky Year of the Snake w/ Cherry MX Browns & Year of the Tiger PBT Keycaps | Razer Deathadder Black
It won't be at half the speed. A lot of SATA 3 drives have read and write speeds for them running on both SATA specifications. If you're going to upgrade your motherboard within the next 6 months, get a SATA 3 drive now.
2,644 (0.45/day)
System Name MRCOMP!
Processor 5800X3D
Memory 64GB 3600mhz
Storage 1TB SSD
since sata 2 is 300mbps and sata 3 is 600mbps.... then yes the interface is half the speed.
i never claimed the drive would be.
1,205 (0.20/day)
Huntington Beach CA
Mouse ROG CHAKRAM
on newegg all the 128 gig drives cost around the same
10,242 (1.45/day)
Granite Bay, CA
The question was about an SSD, and you said it would work at half the speed, so technically you did. Just wanted to make sure that the OP didn't misinterpret what you meant like I did.
800 (0.15/day)
US
System Name Desktop
Processor AMD Ryzen 5 5600X [3.7GHz/4.6GHz][6C/12T]
Motherboard ASUS TUF Gaming X570-PRO [X570]
Cooling Cooler Master Hyper 212 RGB Black Edition
Memory G.SKILL Ripjaws V Series 32GB [DDR4 3600][2x16GB][16-19-19-39@1.35V]
Video Card(s) ASUS KO GeForce RTX 3060 Ti V2 OC Edition 8GB GDDR6 [511.65]
Storage [OS] Samsung 970 Evo 500GB | [Storage] 980 1TB | 860 Evo 1TB | 850 Evo 500GB | Seagate Firecuda 2TB
Display(s) LG 27GL850 [27"][2560x1440@144Hz][Nano IPS][LED][G-SYNC Compatible][DP]
Case Corsair Obsidian 750D
Audio Device(s) Realtek ALC S1200A High Definition Audio CODEC
Power Supply EVGA SuperNOVA 1000 G1+ [+12V: 83.3A 999.6W][80 Plus Gold]
Mouse Logitech M570 Trackball
Keyboard Corsair Gaming K55 RGB
Software Microsoft Windows 10 Pro [21H1][64-bit]
Here is an example for the OP of a SATA3 drive running at SATA2 speed.
EX: Corsair Force Series 3 120GB SATA3 running at SATA2: (ATTO Benchmark)
Corsairs Benchmarks can be found here: http://www.corsair.com/blog/corsair-force-series-3-ssds-are-now-with-us/
(Corsair Rated Write: 510MB)(Half: 255MB)
SATA2 Score: 260MB Write
(Corsair Rated Read: 550MB)(Half: 275MB)
SATA2 Score: 277MB Read
10,242 (1.45/day)
Granite Bay, CA
I'd be curious to see a Crucial M4, Intel 510, or Corsair P-3 on both tests. I don't think it's going to cut them in half.
Running a SATA 3 SSD on SATA 2 will not cut its read/write speeds in half. It will simply limit the maximum reads/writes at about 260MB/s (which is the realistic limit of SATA 2)
Sandforce controllers are spec'd to completely saturate the SATA specification that they were created for, and SATA 3 has twice the bandwidth of SATA 2, which is why your theory works for Sandforce drives, but not with others.
800 (0.15/day)
US
System Name Desktop
http://images.anandtech.com/graphs/graph4253/36345.png
Are you talking to me?
10,242 (1.45/day)
Granite Bay, CA
Anybody who is debating that a SATA 3 drive will run at half speed on SATA 2. I found it intriguing and counter-intuitive that speeds were half for Sandforce 2000 drives, so I did some research to disprove that.
800 (0.15/day)
US
System Name Desktop
I don’t think anybody has made that claim, but indeed, performance will vary depending on controller, SF of course being the fastest available at the moment.
2,671 (0.48/day)
System Name Old Gateway
Processor i5 4440 3.1ghz
Motherboard Gateway
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3
Video Card(s) RX 560D 4GB
Storage 240gb 2.5 SSD 3TB 7.2k Seagate
Display(s) Dell @ 1280*1024 75hz
Case Gateway
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago)
Power Supply 380w oem
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100
VR HMD Lmao
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC
I'll put it this way... on a SATA 3.0gbs connection the drive will not exceed 300MB/sec. however on a sata 6.0Gbs connection, it will perform at its max speed (i've yet to see one at 600MB/sec, 514MB is the highest i've seen i think)
either way... its faster than any HDD you'll find (non insane industrial kind anyway)
basically the same idea as running a SATA3.0Gb/sec drive on a SATA1.5Gb/sec controller
