Timothy Verreault
- Mar 9, 2016
- 5 (0.00/day)
Benchmark Scores | Faster than yours... I'd bet on it. :) |
The three fans at the front are screened by foam and alimunum screening in front of the fans. On initial build and testing, this gave me a slight but stable reduction in intake. With 2x 240mm and 1x120mm in, against 1x120mm and 240mm neutral outflow, it provides good airflow through the case.So you have all intake and no exhaust fans?
Are there three fans there on the front? Two large ones on the L and R and another in the middle? You say filters (plural) but then only mention a single fan mount.
You would see even better results with better airFLOW... but the point here is quiet so I understand the choices made.
A very unique case and airflow... well done!![]()
Processor | amd athlon 620 x4 2.60ghz |
Motherboard | biostar n68s3+ |
Memory | 2x2 gb kingston ddr3 1333mhz |
Video Card(s) | xfx hd 5450 |
Storage | samsung 1tb |
Display(s) | aoc e2043fk |
Case | fortrek gamer |
Power Supply | aerocool 500w e80 |
Software | windows 8.1 |
