Scratched mobo traces with a screwdriver
y2faulty
3 (0.09/day)
So my idiot ass managed to scratch my 1month old mobo with a screwdriver :facepalm: there is a pretty evident scratch over some traces on the mobo between cpu, ram and the pci-express slot.
I'm currently typing from that same pc. Ran some Prime no problem, ran superposition, furmark and timespy, no problemo apparently.
Did the Silicon Gods save me or could it cause problems in the future?
(best pics I managed to get) :
13,120 (1.96/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
You probably just scratched through the protective resin coating designed to keep air (oxygen) and moisture out. If me, since it appears all is still working, I would put a light coat of clear fingernail polish over it, then go buy a lottery ticket.
42,091 (6.63/day)
Yeah you wont be able to warant that, if it doesnt work, find a pcb repair specialist like northidgefix
freeagent
8,508 (3.77/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I did something similar to my Strix B550-XE..
RIP to my board :cry:
Looks like yours should be ok :toast:
6,691 (4.69/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Bill's suggestion for fingernail polish is the correct repair for this. If you're zealous, you can replace the clear polish by more appropriate PCB varnish, it's specifically meant to isolate circuit boards and protect traces. You can find it at electronics stores. The PCB varnish application should last for the lifetime of the motherboard.
2,090 (1.03/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Software Windows 10 Pro X64
Benchmark Scores Who cares
Looks fine to me, as they say, only scratched the surface.
