Scratched up my LCD monitor
1,850 (0.33/day)
System Name Eldritch
Processor AMD Ryzen 5 5800X3D
Motherboard ASUS TUF X570 Pro Wifi
Cooling Satan's butthole after going to Taco Bell
Memory 64 GB G.Skill TridentZ
Video Card(s) Vega 56
Storage 6*8TB Western Digital Blues in RAID 6, 2*512 GB Samsung 960 Pros
Display(s) Acer CB281HK
Case Phanteks Enthoo Pro PH-ES614P_BK
Audio Device(s) ASUS Xonar DX
Power Supply EVGA Supernova 750 G2
Mouse Razer Viper 8K
Software Debian Bullseye
So there was some hard sticky crap on my monitor that I had a hard time getting off, so I reached for the closest tool I could find (my screwdriver). Anywho, now I have scratch marks on it now and it looks even worse. How the hell do I fix this crap?
Deleted member 74752
Maybe try that stuff they advertise on tv for polishing headlite lenses?
1,972 (0.34/day)
Bulgaria
System Name penguin
Processor R7 5700G
Motherboard Asrock B450M Pro4
Cooling Some CM tower cooler that will fit my case
Memory 4 x 8GB Kingston HyperX Fury 2666MHz
Video Card(s) IGP
Storage ADATA SU800 512GB
Display(s) 27' LG
Case Zalman
Audio Device(s) stock
Power Supply Seasonic SS-620GM
Software win10
+1 There are some pastes they advertise for phone screens, which you can use to hide scratches. Maybe try with something like wet sandpaper 2000. It will sure hide the scratches, but the spot where they were will still be visible because it will have a different abrasion on the surface, unless you polish the entire surface :eek:
Also whatever method you choose, remember to always distribute the pressure over a large surface, so as to no kill your pixels. You're lucky you didn't kill any pixels with that screwdriver.
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
A screwdriver...:eek: :wtf: :slap:
You could have used a soft cloth & water or a mix of 50/50 of water/Isopropyl Alcohol
Anyhow i think your scratch will always shows no matter what you do... unless some one got a miracle solution :ohwell:
theonedub
habe fidem
8,026 (1.37/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
Very true. I wetsanded a relatively deep gash on my phone and although the scratch is pretty much gone, when looked under light at the right angle you can see where I had sanded.
1,793 (0.32/day)
System Name Old Skool
Processor E6750 @ 3.6 ghz
Motherboard GA P35 DS3L
Cooling Xigmatek Dark Knight S1283v
Memory 4gb Kingston DDR2 @ 900mhz
Video Card(s) XFX 9800GT 512MB
Storage SAMSUNG 320gb
Display(s) VIEWSONIC vx2260wm
Case HAF 922
Audio Device(s) Realtek (on board) + Logitech x540
Power Supply CM 550w
Software W7 Ultimate 64
A screwdriver...
I thought the same thing too, it sounds like suicide! ;)
Anyways, if you try the above stuff about sanding, be sure not to apply too much pressure, it might mean disaster.
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
There are ways to reduce scratches, but unfortunately as plastic has been gouged out of the display panel, it will always show.
It's time for that monitor upgrade you were wanting. ;)
Fourstaff
10,089 (1.79/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
I have heard people using Brasso and claim that it works, but I am rather sceptical.
1,132 (0.18/day)
System Name Grandpa
Processor i5 4690K
Motherboard Gigabyte Z97X-UD5H-BK
Cooling water
Memory 8GB Corsair Vengence 2400MHz
Video Card(s) Gigabyte 5850 x2
Storage Samsung SM951
Display(s) Catleap 27"
Case coolermaster stacker
Power Supply corsair AX860i
Mouse logitech g5 original
Keyboard Ducky
Software Windows 8.1
I would try filling the scratch rather than just polishing it out. Try a clear drying gel (maybe hair or sex gel lol) that can fill the scratch and then polish back smooth with a cloth.
Fourstaff
10,089 (1.79/day)
Home
but if the refractive index (or something like that) is not the same, then you might only reduce the scratch but not hide it. Safer option though.
6,871 (1.10/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
Damn, my sig quote sure seems to be appropriate here. WTF were you thinking using a metal object the scrape something off the surface of your LCD? You screwed up your monitor, it can't be 100% fixed. Buy a new one and learn from this experience.
1,132 (0.18/day)
System Name Grandpa
Processor i5 4690K
Cooling water
Keyboard Ducky
I agree the RF will be difficult to match and I didn't bother checking but it should be better than nothing.
I add to the list beeswax, if only coz if it doesn't work it should be tasty to lick off. It should be easier to apply and polish up though.
1,972 (0.34/day)
Bulgaria
System Name penguin
Processor R7 5700G
Video Card(s) IGP
Display(s) 27' LG
Case Zalman
Software win10
Umm you got me curious. How bad is it exactly? Can we get a shot? :rolleyes:
Try to shoot it under an angle so that the light hits the scratch and it is more clearly visible.
HookeyStreet
Eat, sleep, game!
7,122 (0.94/day)
Great Yarmouth, England
LOL anyone that uses a screwdriver to remove sticky gunk from a monitor clearly has bigger problems than just a scratched screen :roll:
1,972 (0.34/day)
Bulgaria
System Name penguin
Processor R7 5700G
Video Card(s) IGP
Display(s) 27' LG
Case Zalman
Software win10
Well it's not as bad as it sounds. He could have used much more terrible things. Like fire and bees or even worse FIREBEES!
brandonwh64
19,542 (3.42/day)
LOL maybe a dremel will work better.
seriously, like others have said 70% alcohol and a soft cloth would have gotten it off easy
1,850 (0.33/day)
Well, I have a picture but can't find my card reader... so.... off on the goose chase I go.
t_ski
Former Staff
11,941 (1.72/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
First, clean the scratch. Second, use a soft rubber pencil eraser and rub it gently. If that doesn't work, you can fill the scratch with things like petroleum (Vaseline) or buff it out with a scratch remover meant for plastics.
I did the eraser trick on a monitor at work and it turned out great. This will not work for a deep gouge though. You will either have to fill it or buff it out, or live with it.
269 (0.04/day)
Directly above the center of the Earth
System Name WTF it actually turns on!
Processor AMD FX-8350
Motherboard MSI 990fxa-gd80
Cooling Raystorm swiftech mcp655 xspc dual bay res Rx240 Rs240
Memory 16gb ddr3 1600
Video Card(s) Power color R9 280x
Storage 2x1tb+2x2tb seagates
Display(s) 27" Samsung S27B350H
Case Tt core v51
Power Supply CORSAIR GS700
This is your best bet and it does work for light scratches.
Try to find a hard white eraser those work the best.
