Scythe Announces New Entry-level Versions of Katana 3 CPU Cooler
47,534 (7.47/day)
Scythe Group is announcing two new entry-level versions of Katana 3 CPU Cooler. Both new models are offered at a lower price, and are equipped with dedicated mounting bracket and thermal grease. Katana 3 "Type A" (SCKTN-3000A) is compatible to AMD socket 754, 939, 940, AM2(+), AM3 whereas "Type I" (SCKTN-3000I) is compatible to Intel socket 775, 1156 and 1366.
Katana 3 TYPE A & I CPU Cooler is equipped with a genuine Scythe 92 mm fan which supports the PWM feature for flexible fan control by motherboard. Fan speed can be adjusted between 300 to 2,500 rpm which provides airflow of 12 to 95 m³/h respectively 6.7 to 55.55 CFM. By adopting the S.P.S. (Slant Pipe Structure), generated airflow is furthermore effectively used to cool various components such as RAM, Chipset as well as Voltage Regulators.
By adopting the Fast-Phase Structure, the additional fin structure on the Katana 3 TYPE A & I CPU Cooler base is used to improve the heat dissipation. Supplied clips allow users to mount Katana 3 CPU TYPE A & I CPU Cooler within a few minutes without removing the motherboard. Improved slide Push-Pin mounting brackets can be used for socket 775, 1156 as well as 1366 with just a single socket clip.
Katana 3 "Type A" (SCKTN-3000A) as well as "Type I" (SCKTN-3000I) are available for 14,75 EUR (MSRP,exc. VAT) or 28.00 USD (MSRP,exc. TAX).
887 (0.15/day)
Processor Intel Core i3-8100
Motherboard ASRock H370 Pro4
Cooling Cryorig M9i
Memory 16GB G.Skill Aegis DDR4-2400
Video Card(s) Gigabyte GeForce GTX 1060 WindForce OC 3GB
Storage Crucial MX500 512GB SSD
Display(s) Dell S2316M LCD
Case Fractal Design Define R4 Black Pearl
Power Supply Corsair CX600M
Mouse Logitech M500
Keyboard Lenovo KB1021 USB
I like the fact that these coolers were designed to provide cooling for the voltage regulators. Too many vertical coolers give little or no thought to this requirement.
A bolt-through kit for the Type I model would be nice. I don't trust push-pins to maintain a good grip on the motherboard. Plus, they tend to warp the hell out of the board.
3,779 (0.64/day)
Latin America, Uruguay
System Name The Lizard v2.4
Processor Intel Celeron G1840 (for the time being
Motherboard Gigabyte GA-H81-S2PH
Cooling Intel Stock Fan
Memory 16GB Kingston HyperX 1600
Video Card(s) MSI Gaming GTX 750Ti (For the time being)
Storage 500GB Samsung F1, 160GB Maxtor "Older than god"
Display(s) AOC 28' LCD
Case Coolermaster N200
Power Supply Antec VP500P
Benchmark Scores No crashes in the last 24 minutes.
any info on the weight.
if they dont weight much i may order one from USA
vaiopup
840 (0.13/day)
England
System Name Crunching and smapping!
Processor i7 920@3.8
Motherboard Gigabyte EX58-UD3r
Cooling True
Memory 6gb Gskill pc12800
Video Card(s) Crossfired 5770's
Storage 1tb Samsung Spinpoint
Display(s) 50" Panny Viera 1080p
Case Antec 200 I think
Audio Device(s) Audio via Logitech 680's or 580's....or something
Power Supply Corsair 850 TX
Software Win 7 64
Benchmark Scores Just a few coffee stains!!!
Mussels
Freshwater Moderator
58,412 (7.83/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
screw VRM's, that would work really well to cool ram :D
180 (0.03/day)
Scythe announce it few mont later, why? This cooler is available for 3 month at least and old Katana 2 is nowhere available for at least mont more.
Doesnt really like it cause they sell it at the same price with 92mm cooler (instead 100mm) that rotates at higher rpm and they went to that easier mounting clips which in fact is more hassle than the old ones which screw into base
180 (0.03/day)
Oh oh i get it .... they now make it in two flavors AMD and Intel one so you cant excange platforms, and wait it cost exactly the same as old Katana 3 or even Katana 2 (which was indeed something). Crude way of making money tbh :wtf:
Ad wait they only announce it on eu site :mad: (that cubersome, not really customer oriented like their usa site)
TheMailMan78
Big Member
22,598 (3.48/day)
'Merica. The Great SOUTH!
Holy cow thats an ugly cooler Batman.
