Scythe Unveils the Kaze Master Flat II Fan Controller
4,784 (1.02/day)
Still on the East Side
Japanese cooling-expert Scythe is hereby announcing the successor of the Kaze Master Flat. The new version is using the classic design of the predecessor but omits the Protective Display Cover and replaces it with a solid front-panel with decently implemented buttons, offering users a clean appearance and fast access.
The big Vacuum Fluorescent Display (VFD) covers most of the front-panel space and provides great overview of values that matter. Total of four touch-sensitive buttons are located in the corners, giving access to all the main functions of the Kaze Master Flat II fan-controller. The buttons on the right side allow users to adjust the fan speed in the range from 0 to 9.999 RPM, depending on the connected fan. Fan speed is adjusted by changing the input-voltage between 3,7 and 12 volts, as it has been done with other Scythe fan-controllers in the past. Each fan channel supports regular 3-pin and 4-pin PWM fans. Total consumption per channel has been tripled to 3 ampere (36 watts).
Each of the four temperature channels supports measurement from 0 to 100 degree Celsius and 32 to 199,9 degree Fahrenheit. Switching the jumper on the rear side of the fan-controller allows users to choose between the two measurement units. In case of failure of a connected fan or reaching the set temperature limit, the alarm function will kick in. Pressing the button on lower left corner will shut down the alarm. Desired temperature limit can be set from 50 to 90 degree Celsius (131 to 194° Fahrenheit) in 5-degree steps using the dip-switch.
Switching between modes, channels and functions is possible by using the "mode" button in the upper left corner. Similar to the predecessor, new Kaze Master Flat II fits perfectly into a vacant 5,25 inch- (13,34 cm) bay of the PC chassis. The height of the new display has been increased by 4 mm to 20 x 118 mm (0,79 x 4,65 inch) to show the fan speed and temperature of each channel clearer.
Scythe followed the customer wishes and supplies the Kaze Master Flat II with professionally sleeved fan and sensor cables. Scope of delivery incudes the multi-lingual manual, mounting screws and adhesive tape.
Kaze Master Flat II fan controller (model no. KM08-BK) is available as of today for 26,00 EUR from retails and etailers (excluding Taxes).
5,701 (0.79/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
SCYTHE
Y U NO PWM?
Aquinus
Resident Wat-man
13,159 (2.84/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
SCYTHE
Y U NO PWM?
Who cares? This alone makes it worth it:
The fact you can drive say, DELTA fans with it, is impressive and might be reason alone to get one. Unfortunately I have 6 fans I need to control so I would prefer a couple more fan headers unless I used one for just intake and one for just exhaust. :p
68 (0.02/day)
Processor i7 3770K (4.3 GHz)
Motherboard P8P67M-Pro
Cooling Zalman CNPS10X + Noctua NF-F12
Memory 16GB (4x4GB) DDR3 1600MHz
Video Card(s) Asus R9 280x DCUII Top @ 1155 MHz - 1200mV
Storage Samsung 850 evo 250GB // Samsung 830 128GB // Barracuda 1TB // Travelstar 250GB
Display(s) 1440p 144Hz Freesync Samsung
Case Corsair 400R
Power Supply XFX 550w
Software windows 10 Pro - Ubuntu 16.04.1
In the news they say that can control PWM fan either, but I can't see 4pin PWM connector.
AsRock
TPU addict
19,019 (3.01/day)
UK\USA
Put some heatsinks on that thing it would help it kee much cooler and improve it's lifetime.
4,421 (0.89/day)
It can control the PWM fans same way when you connect a PWM fan to a 3pin fan header on motherboard. Fan connectors are separated by a small distance which would aid in installing a 4-pin PWM fan into those.
1,334 (0.23/day)
I wouldn't trust it to burn even one volt at 3A. Look at those transistors, no heatsinks at all and it's tricky to fit a decently-sized homemade one in.
5,701 (0.79/day)
Ikenai borderline!
Not to mention a SATA power connector provides 9A maximum...
1,946 (0.44/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Cooling Noctua NH-D15S
Display(s) EIZO CX240
Case Lian-Li O11 Dynamic Evo XL
Audio Device(s) Creative Sound Blaster ZxR / AKG K601 Headphones
Mouse Logitech G500s
Keyboard Keychron Q6
Get the Kaze Master Pro.
Using that myself to control my 5 Noctua NF-S12A's
It's a really beefy controller.
296 (0.07/day)
System Name Darkside
Processor R7 3700X
Motherboard Aorus Elite X570
Cooling Deepcool Gammaxx l240
Memory Thermaltake Toughram DDR4 3600MHz CL18
Video Card(s) Gigabyte RX Vega 64 Gaming OC
Storage ADATA & WD 500GB NVME PCIe 3.0, many WD Black 1-3TB HD
Display(s) Samsung C27JG5x
Case Thermaltake Level 20 XL
Audio Device(s) iFi xDSD / micro iTube2 / micro iCAN SE
Power Supply EVGA 750W G2
Mouse Corsair M65
Keyboard Corsair K70 LUX RGB
Benchmark Scores Not sure, don't care
Sweet! As a current Kaze Master (x 2) user I am excited about this. I never really liked the flip down option of the original, these simply look gorgeous. I love minimalistic designs for my tech, and this fits the bill.
