SD Card error
2,143 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Software Windows 10 Pro X64
Benchmark Scores Who cares
I formated my 128gb micro SD card with GUI format and now getting this problem. The card does not show in windows as there is no drive letter, but shows in disk management as healthy. I cannot format it in windows as you see on the pic, or change/add a drive letter as you see in other pic. Any way i can recover this SD card?
thx
If it is in the wrong place, feel free to move it :)
854 (1.24/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 9 7900X3D
Motherboard ASUS ROG Crosshair X670E Extreme
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB
Software W10-11 Enterprise- Linux Mint 22.0 Cinnamon Edition.
Use GParted to remove all partitions left and make a new partition with same program. Windows only can do some basic things. Works a breeze with anything.
2,943 (2.07/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
Open the terminal as admin type diskpart and then list disk
Check that you pick the correct one, type select disk #(number of the drive), enter and then type clean.
854 (1.24/day)
Belgium
Memory 32GB DDR5
Be carefully with disk-part if you use this, you have no visual of what you are doing or selecting, you type commands blindly and what you have done can't be undone!
2,943 (2.07/day)
Germany
you see exactly what you're doing.
you get a list of the connected drives incl. the capacity.
you see which one you selected and what happened after typing in the clean command.
2,143 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Thx guys i will try what you have suggested
Got this on disk part
Fixed it. Stuck it in my spare android phone, and it said it need formatting, which it did, now it works in windows fine.
Why can't windows do this?
2,943 (2.07/day)
Germany
did you try it a second time? i just had a Sandisk Extreme that spat out the same message until i did it two or three times.
2,143 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
I tried it a few times, same as i tried windows disk management, which is weird, says could not assign a drive letter, then left it raw once. Android fixed it straight away with no problem, windows 11 is much more sophisticated and cannot do it. something wrong with that.
Is it because the phone is basically using Linux?
For anyone else with the same problem, stick the card in your phone to do it. Phone was a samsung galaxy A3(2017) btw.
Thx for your help anyway GerKNG
2,943 (2.07/day)
Germany
i use diskpart almost on a daily basis and i never encountered an issue like you had now.
at least it works now :)
2,143 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
I was trying to get it to work with my hacked ninty 2DS, but i think it only supports a max 64gb card.
2,943 (2.07/day)
Germany
854 (1.24/day)
Belgium
Memory 32GB DDR5
With GParted no problems ever. We don't use anything else anymore it handles everything and a change to undo settings if you did make an error...
2,489 (0.52/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
This reminds me of the dreaded false-write-protected error messages. (in my case, it was just a faulty drive, IIRC) It could be a warning sign of a counterfeit drive!
2,143 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
I'm sure the mem card is ok, just probably some error with the 2ds setup not supporting the card but formatting it anyway. The phone fixed it straight away with no trouble and i have had it a while and never had a problem with it before.
626 (0.60/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
It does indeed look like your sdcard was flagged write only in Windows.
2,143 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Strange
It's definatly ok now after been initialized and formatted as exFAT in the android phone.
1,707 (0.54/day)
System Name The Blind Grim Reaper
Processor Xeon X5675 Westmere-EP B1 SLBYL 4.20ghz @ 1.256v
Motherboard Asus P6X58D-E
Cooling Noctua CP12 SE14, Redux Noctua 1500rpm fan Arctic F14 x3 for intake and exhaust
Memory Corsair XMS3 CMX4GX3M2A1600C9 x6
Video Card(s) EVGA GTX 1060 6GB SC Single Fan Model
Storage Crucial mx300 750gb main system + 1TB mx500 for games and music
Display(s) 22 inch samsung curved
Case NZXT Phantom 530 black
Audio Device(s) Nvidia HDMI through HDMI adaptor for output sound for turtlebeach x12 headset
Power Supply Antec HCG 850 watt
Mouse no brand
Keyboard normal usb keyboard
Software Windows 10 22H2 v1 (main is) and Windows 11 22H2 v2 on WD 250gb 7200rpm (testing purposes os)
Benchmark Scores Cinebench R20 = 2046cb
All depends on the format windows can do exfat, fat32 and ntfs but android phone is picky about certain sd cards best to buy proper branded sd card not unbranded generic type which are prone to fail losing data in the process. How I know this people buying bottom of the barrel type for dirt cheap. Even with careless handling it can break it because I knew a friend who lost about 220gb worth of data in a blink of an eye by snapping it in the middle of the sd card that not including the fact he didn't back it up in the first place.
You can fix it in cmd by doing dskchk x: /f /r (x is the location path of the sd card).
2,143 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
The card is a sandisk ultra
2,342 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
@FoulOnWhite
This tool is great but can take a while.
587 (0.38/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
