Searching for a good vBios
Sansara
4 (0.01/day)
Hey guys,
I'm actually searching a way to overcome the 80w limit of my vBios. I was thinking about changing it but i'm not sure it's a good idea. I would say i need between 90w and 110w (100w is perfect). Also it's a bit strange, i see a maximum of 130w on GPU-Z but it's still blocked at 80w (sometimes it goes to 81w).
Oh and i forgot to add these informations:
  • GA106.rom
1,396 (0.81/day)
Just try using MSI Afterburner to increase TDP/Powerlimit over those 100%, that should give you more watts and no harm of messing with the BIOS.
Deleted member 182555
already tried but it seems to be blocked
is it locked against overclocking or only tdp? I advise against doing crossflash for now and waiting if there are developments on the biosmod... I'm working on the desktop counterpart.
Tatty_Two
Gone Fishing
25,962 (3.73/day)
Worcestershire, UK
Software Win 11 Home x64
18,584 (2.67/day)
System Name AlderLake
The VBIOS is most likely integrated in the laptop main BIOS so there's no way of just flashing the GPU BIOS....
I think the rom has been attached or am I wrong? I also see certificate...
ok, I should analyze it but not now.
2,701 (0.41/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Laptop GPU TDP increase is risky due to shitty cooling
Sansara
4 (0.01/day)
I actually have a decent cooling for a laptop so I can afford the change of TDP. I tried searching in nvidia profile inspector there was nothing.
see if you can achieve something with curves editor of msi afterburner if you haven't already.
Tatty_Two
Gone Fishing
25,962 (3.73/day)
Worcestershire, UK
I think that is locked too since he couldn't do it from afterburner, on other my gpu it is bios that locks it.
the only ways to increase performance are either via voltage curves or via biosmod which doesn't exist yet or risky crossflash.
