Could you just in a few words say why?Gold
System Name | My PC |
Processor | AMD 2700 x @ 4.1Ghz |
Motherboard | Gigabyte X470 Aorus Gaming |
Cooling | Zalman CNPS20X |
Memory | Corsair Vengeance LPX Black 32GB DDR4 |
Video Card(s) | Sapphire Radeon RX 570 PULSE |
Storage | Adata Ultimate SU800 |
Case | Phanteks Eclipse P500A |
Audio Device(s) | Logitech G51 |
Power Supply | Seasonic Focus GX, 80+ Gold, 550W |
Keyboard | Roccat Vulcan 121 |
System Name | H7 Flow 2024 |
Processor | AMD 5800X3D |
Motherboard | Asus X570 Tough Gaming |
Cooling | Custom liquid |
Memory | 32 GB DDR4 |
Video Card(s) | Intel ARC A750 |
Storage | Crucial P5 Plus 2TB. |
Display(s) | AOC 24" Freesync 1m.s. 75Hz |
Mouse | Lenovo |
Keyboard | Eweadn Mechanical |
Software | W11 Pro 64 bit |
Mouse | Lenovo |
Processor | i5-9600K |
Motherboard | Gigabyte Z390 Gaming X |
Cooling | Scythe Mugen 5S |
Memory | Micron Ballistix Sports LT 3000 8G*4 |
Video Card(s) | EVGA 3070 XC3 Ultra Gaming |
Storage | Adata SX6000 Pro 512G, Kingston A2000 1T |
Display(s) | Gigabyte M32Q |
Case | Antec DF700 Flux |
Audio Device(s) | Edifier C3X |
Power Supply | Super Flower Leadex Gold 650W |
Mouse | Razer Basilisk V2 |
Keyboard | Ducky ONE 2 Horizon |
Didn't hear any issues with these recently.I checked the whole thread.
Not sure if I understand correctly. It was problem with FX and FM series and GX is not affected?
System Name | Self-built |
Processor | AMD R7 5800X3D |
Motherboard | ASUS Prime B550 Plus |
Cooling | Scythe FUMA 2 + various case fans |
Memory | 16GB: Corsair CMK16GX4M2D3600C18 at 3800C16 |
Video Card(s) | Gigabyte Eagle RTX3070 |
Storage | 2x WD Black m.2 nvme 1TB, WD HDD 6TB, Crucial 750MX300, |
Display(s) | LG 27GN950 |
Case | DeepCool E-Shield |
Audio Device(s) | Int: RealTek ALC892, NVidia GA104 HD Ext: LG 27GN950, Behringer DEQ2496, DCX2496, A500. etc |
Power Supply | Seasonic Core GM-650SRM |
Software | Linux Mint + Windows11 pro |
Benchmark Scores | Not worthy of attention |
System Name | PC-Casa |
Processor | i7-9700F |
Cooling | Artic Liquid Freezer II 240 |
Memory | 2x16gb DDR4 3200 Kingston HyperX |
Video Card(s) | Gigabyte RTX 3070 Eagle OC 8Gb |
Storage | Samsung 970 EVO Plus NVMe M.2 500Gb + Samsung SSD 870 QVO 2TB + 2x WD 2Tb HDD SATA |
Display(s) | Samsung LU28R55 4K |
Case | Sharkoon TG5 Pro RGB |
Power Supply | Cooler Master 600W 80+ |
Mouse | Corsair M65 Pro RGB |
Keyboard | Corsair Strafe |
Software | W10 Pro - 64 |
Benchmark Scores | 3D Mark Performance: 30167 3D Mark Extreme : 15862 |
Hi all, I was using outervision to calculate my PSU and with my system they gave me a 550W PSU, the same with the Seasonic calculator. My thoughs come about how much system are overpowered and how it affect really the consumption of electricity as if I had a 850W PSU I would be all the time using my PSU at 40% maybe less so far away from the best my PSU can give?I think Seasonic, from what I can gather, did have some issues about 3 years ago, maybe longer. Their more recent offerings have put them back into Tier 1. I have a Seasonic Gold, and am very happy with it: a 650w, that powers a RTX3070 (240w+), but a low power (65w) processor. Reviews indicated it would switch off at about 730w load. So I think that unless you're into 3090 SLI, you're pretty good-to-go at 850w. I have a Kill-A-Watt meter, that rarely exceeds 400w at the wall, including 2 monitors.
System Name | Dumbass |
Processor | AMD Ryzen 7800X3D |
Motherboard | ASUS TUF gaming B650 |
Cooling | Artic Liquid Freezer 2 - 420mm |
Memory | G.Skill Sniper 32gb DDR5 6000 |
Video Card(s) | GreenTeam 4070 ti super 16gb |
Storage | Samsung EVO 500gb & 1Tb, 2tb HDD, 500gb WD Black |
Display(s) | 1x Nixeus NX_EDG27, 2x Dell S2440L (16:9) |
Case | Phanteks Enthoo Primo w/8 140mm SP Fans |
Audio Device(s) | onboard (realtek?) - SPKRS:Logitech Z623 200w 2.1 |
Power Supply | Corsair HX1000i |
Mouse | Steeseries Esports Wireless |
Keyboard | Corsair K100 |
Software | windows 10 H |
Benchmark Scores | https://i.imgur.com/aoz3vWY.jpg?2 |
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality Fractal Design Define R4 case, 2 x FD 140mm fans, CM Hyper 212 EVO HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
But this is misleading. It suggests Platinum PSUs are better than Golds just because they are certified Platinum. That is not true.If you can afford it, go Platinum, there might only be a slight increase in efficiency but the peace of mind from having the best is worth it.
Great question! Typically, it is only about the money. But you would have to properly test and compare two specific PSUs to accurately answer that question. But for sure, if the Platinum turns out to be a better supply in a proper test/review, it will NOT be simply because it is Platinum.Is it only about the money or is there another difference?
BTW, it is highly unlikely you need a 850W PSU. That is HUGE! Another common misconception is that bigger is always better. Not so! You might want to plug your components into the eXtreme OuterVision PSU Calculator. This will calculate your minimum needs and recommend a suitable size for those needs.
I recommend setting CPU utilization to 100% and Computer Utilization Time to 16 hours per day. These settings will help compensate for component aging, and add a little extra padding to the results.
So what? I also have 4 other computers here with various demands. And I am directly responsible for dozens more client (business and personal) computers too. "So what" for them too! Your point is pointless. And for the record, PCIe slots are limited to 75W. That's exactly why more hungry graphics cards require supplemental power directly from PSUs. So again, so what?Well Bill, you have a HUGE 550w supply for a 1050Ti and i5! The 1050Ti barely pulls 75-77w through the PCIe slot.
Now add 200w for a 3060-3080 (or RX6xxx), and another 50w for a beefier processor, and you're already looking at 800w. I used to run a...
NO again!!!! You don't know that. You are only assuming and that is wrong. You are suggesting any no-name generic "Platinum" certified PSU has better regulation and tighter specs than every "Gold" rated Seasonic, EVGA, SuperFlower and every other PSU from every reputable brand. One might hope that is the case but it would be huge mistake to assume that. This is why I said you have to be specific about which two PSUs you are comparing.You are correct that the Platinum series doesn't imply a 'better' PSU. But the suppliers themselves provide better regulation through tighter-specced components
System Name | 1 Desktop/2 Laptops/1 Netbook |
Processor | AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom |
Motherboard | EpoX ATX motherboard/Samsung/Toshiba/Lenovo |
Cooling | Stock |
Memory | 4 GB/4 GB/2 GB/2 GB |
Video Card(s) | Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA |
Storage | 6+ TB Total |
Display(s) | HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor |
Case | None |
Audio Device(s) | Various |
Power Supply | Seasonic 500 Watt & VenomRX 500 Watt |
Mouse | Wayes Iron Man Wireless Mouse |
Keyboard | Rexus VR2 Wireless Keyboard |
Software | Win10 & WinXP SP3 |
Benchmark Scores | It sucks... |
There is nothing wrong with speccing his PC build with 550 Watts PSU. He might have lots of "stuff" plugged into his system so that 550 Watts EVGA PSU of his might be correctly specced for is build or there could be other reasons.Well Bill, you have a HUGE 550w supply for a 1050Ti and i5! The 1050Ti barely pulls 75-77w through the PCIe slot.
Just so you know, a 3060 Ti is only 200 Watts TDP while a 3080's TDP is 320 Watts & a RX 6800/6900 XT has TDP of 300 Watts while an non-overclocked i7 shouldn't go higher than 150 Watts, add in 100 Watts from other components & peripherals, I don't see how you could get 800 Watts from? Seems like an exaggerated number there.Now add 200w for a 3060-3080 (or RX6xxx), and another 50w for a beefier processor, and you're already looking at 800w.
I doubt that's how it works. Certification is given AFTER speccing a PSU design with components. What use is there in decking out PSU design with high quality components if it turns out that it couldn't meet the Platinum/Titanium certification & got a Gold or lower certification instead. At least those Gold/Silver/Bronze/Normal PSU would have the same quality components as those on Platinum or Titanium rated PSU.But the suppliers themselves provide better regulation through tighter-specced components (and more complex design), and generally, they provide better quality components in these 'Premium' PSUs. Yes, they leverage the Platinum name, but reputable suppliers aren't going to fill their Premium PSUs with no-name components.
