Seasonic FOCUS-PX (Platinum) vs Seasonic Prime (Platinum)
285 (0.35/day)
Processor Ryzen 5 7600X
Motherboard Asus Proart B650
Cooling Noctua U12S
Memory Corsair Vengeance DDR5 32GB (2x16GB) 5600MHz C36 AMD Expo
Video Card(s) Sapphire RX 7800 XT Nitro+
Storage Samsung 990 Pro 1Tb
Case Fractal Design Pop Silent
Audio Device(s) Edifier r1900tII
Power Supply Seasonic Prime Platinum 650W
These PSUs seem similar enough. Are there any known differences that could be mentioned in a nutshell?
OneMoar
There is Always Moar
8,800 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
they are both excellent units the prime is the slightly better unit
13,422 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I agree that both are excellent. But you pay considerably more just because they are Platinum when all you get is a couple points better efficiency than a quality Gold unit - which already have excellent efficiency ratings. As seen here when you hover over the logos, at 50% load the difference between Gold and Platinum is just 2% (90% vs 92%). Unless you just happen to find the Platinum on a big discount sale, it would take years of use to make up the difference in purchase price with savings in energy costs.
It is critical to remember the 80 PLUS certifications are only about efficiency. There is nothing to suggest a Platinum will provide better performance, better ripple suppression, better regulation or a longer life span than a quality Gold.
For example, if you look at these two Seasonic 750W supplies. Both are excellent. But is the Platinum really worth $50 more? I say, "no way!"
