Seasonic Launches the New PRIME PX-2200 Power Supply
GFreeman
1,471 (2.44/day)
After a successful product introduction during Computex 2024, Sea Sonic is now launching the sales of the new PRIME PX-2200 power supply. The Seasonic PRIME Series represents Sea Sonic's pinnacle of engineering, blending cutting-edge design with premium materials and advanced production processes. The latest models showcase digital fan control, modern interleaved PFC (Power Factor Correction), and a patented dual-transformer design running in parallel.
Seasonic's Latest Power Milestone Unveiled
The PRIME PX-2200 stands out above all PRIME units by capable of delivering an impressive 2200 watts of power at 80 Plus Platinum EU 230 V levels. Catering to a wide range of power users, this ATX 3.1 and PCIe 5.1 compatible powerhouse delivers top-quality power combined with long-term reliability for various high-performance applications.
Powering the AI Revolution
As Artificial Intelligence (AI) continues to advance, there is a growing demand for high-end components that consume increasing amounts of power. For future-proofing PCs and workstations geared towards AI computing, AI drawing, and edge computing tasks, the Seasonic PRIME PX-2200 emerges as the optimal choice.
Specifications:
  • ATX 3.1 and PCIe 5.1
  • 80 Plus Platinum EU 230 V
  • Fully Modular Cabling Design
  • Two Native 12V-2x6 Cables
  • Two 2x8-pin to 12V-2x6 Cables
  • 135 mm Fluid Dynamic Bearing (FDB) Fan
  • Digital Hybrid Fan Control
  • Highly Reliable Japanese 105°C Aluminum Electrolytic Capacitors
  • Micro Tolerance Load Regulation @ 1 %
  • Cable-free Connection Design
  • 12 years warranty
  • AC Input Range:
  • 200 - 240 Vac only
Availability and Price
  • China: Available, Europe: end of September / October 2024, North America: N/A, ROW: End of Q3 2024 onwards
  • N/A (USA) / €579.90 (Europe) / $499.99 (ROW)
157 (0.83/day)
System Name Main Workstation
Processor AMD Ryzen Threadripper 2970WX PBO 3,6-4,2Ghz
Motherboard Gigabyte x399 Aorus Pro (ReBAR patched)
Cooling Alphacool Eisbaer Aurora Pro 420
Memory 8x16GB (128) Kingston Fury RGB @3266Mts 16-18-18-36-74 2T
Video Card(s) RTX 3090 ROG Gaming OC @1500Mhz (1965Boost)
Storage Lexar NM790 2TB, Corsair Force MP510 960Gb, Samsung 860 SATA 2TB, 2TB WD Green 7200rpm
Case Phanteks Ethoo Pro 2 TG
Power Supply EVGA Super Nova 1000GT
A sad 4x8pin pcie connectors. Would be a nice Multi gpu psu otherwise.
12,110 (5.73/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
I don't get it. There's 9 CPU/PCI-e outputs, but only 3 CPU and 4 PCI-e cables (a total of 7). Not what I'd expect from a bazillion dollar, jiggawatt PSU from Seasonic.
819 (0.22/day)
Poland
System Name Proper
Processor 5900X + OC
Motherboard GB X570s Elite AX
Cooling WC Heatkiller 3.0 LT
Memory G.Skill 3600 CL16
Display(s) GB M32Q
Case Fractal Define R6 USB C
Mouse Log G502 X LS
Software Win10 Pro
There are additional two 2*8pin->12pin cables.
I wish Seasonic refreshed their 600-1000W portfolio, since most of those PSUs don't support the newest standards.
157 (0.83/day)
102 (0.07/day)
Processor Intel Core i7 12700KF
Motherboard Asus Prime Z690-P D4
Cooling Arctic Liquid Freezer III 360
Memory G.Skill TRIDENT Z 32GB 4000MHz CL16 DDR4
Video Card(s) MSI Suprim X RTX 4080 16GB
Storage Kingston KC3000 1TB
Display(s) Alienware AW3423DWF 34" 21:9 OLED
Case Antec C8
Power Supply Fractal Design ION 860+ Platinum
Mouse Roccat Kone Air
Keyboard OZONE StrikePro Spectra (CherryMX Red)
Software Windows 11 Pro x64
Why they keep multiplying the names for 12V PCI-E socket? First it was 12VHPWR, then 12V2x6, now Seasonic uses "PCIe Gen 5". It gets really cofusing..
876 (0.14/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 970PRO 500GB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/ilvewh https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
This one is an Absolute UNIT :D
2,095 (6.24/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (23H2)
I am not sure what the GPU connector issue is. You can potentially hook up up to FOUR GPUs with provided connectors. How much more multi GPU can you get?
Or is this “12V 2x6 bad” striking again? Because I would be willing to bet that all next gen GPUs, yes, AMD too, will use the connector.
157 (0.83/day)
Only one 8 pin instead of two 6+2s per string.
So you can use 4 newer Gpus which no one can afford, but only really have legacy support for two older cards as most gpus use two adapters per unit.
Two "12v" and the rest 6+2 would have made much more sense.
And dont pretend like the 12v-high-failure-adapter is not trash. It needs to go.
12,110 (5.73/day)
Midlands, UK
Look at the number of cables attached. There's 9 CPU/PCI-e sockets, but only 4 8-pin cables in the box. That's 600 W (675 W with slot power) in total. What do you need the other connectors and 2.2 kW for if you don't have cables to use it all?
Not that I can think of any way I could build a home PC that eats 2.2 kW, but that's besides the point.
No, it's the naming. Seasonic now calls it "PCI-e gen 5" for some reason.
Besides, AMD is leaving the high-end with RDNA 4. The top dog is rumoured to be around 250 W. They have no reason to use the connector on it and alienate a portion of the potential buyer base.
213 (2.39/day)
There was some difference in the mechanical and electrical dimensions.
That PCIE 5.0 bullshit makes other marketing stupdity people also. There is no PCI Express BUS as far as i know in power supply units. Feel free to correct me with the datasheet and application notes from a well known power supply unit manufacturer like seasonic and so on. Basically fraud as there is no pci bus in it. I have one such psu, there is no possibility to physically put in my Radeon 7800XT in that psu with the 16 lanes pcie connector.
The picture claims 100-240 VAC, the text claims:
  • AC Input Range:
2,095 (6.24/day)
I am sure that people buying a new top of the line specialized PSU are dirt poor and can’t afford their GPUs. Makes sense.
And dont pretend like the 12pin high failure adapter is not trash. It needs to go.
Nobody managed to make the revised 2x6 fail even deliberately. It’s a non issue. The revision fixed the problem that was causing the failures.
Your math is off. There are two 2x6 cables AND two 8-pin to 2x6. So just with the 2x6 ones you can connect up to 1200W of GPU potentially. This is not counting 8-pin at all. And the CPU can be power hungry too, anyone using mGPU nowadays is unlikely to run something desktop. More likely a TR system.
Because the connector is adopted as part of PCI-e 5.x spec.
12,110 (5.73/day)
Midlands, UK
You're not gonna use GPUs with both the old and new connectors in the same system. I mean, yes, you can have two 4090s and a 7900 XTX, and have one 8-pin cable spare, but why would you? And it's still only 1255 W in total. A power-hungry CPU is another 300-350 W, so we're totalling at 1.6 kW at the CPU+GPU even with the above, highly unrealistic config. You can't do a lot more than 1.2 kW with a system that actually makes sense with this cable layout.
Really? Isn't it called 12V HPWR or something?
2,095 (6.24/day)
12VHPWR is the old one. 12V-2x6 is the revised one.
...I think you misunderstand something. The 8-pin end of the connector is going INTO THE PSU. Into two of those CPU/PCIe ports. Not the GPU.
819 (0.22/day)
Poland
System Name Proper
Display(s) GB M32Q
Mouse Log G502 X LS
Software Win10 Pro
If You use it with two 4090s and one 7900XTX then You'll have plenty left - 4090s take both of native 12V-2x6 connections, while 7900 XTX gets at most three 8pin PCIe. Another 2 of those go to the motherboard so that leaves five 8pin outputs to spare. You could eg. use another 2 nVidia GPUs with it.
Abby Normal
3 (0.01/day)
Could we just not send close to 200A over one rail? Despite the 12pin cables' best efforts, turning PSUs into an arc welders is best continued to be avoided.
1,961 (0.44/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Cooling Noctua NH-D15S
Display(s) EIZO CX240
Case Lian-Li O11 Dynamic Evo XL
Audio Device(s) Creative Sound Blaster ZxR / AKG K601 Headphones
Mouse Logitech G500s
Keyboard Keychron Q6
It's fool proofing for people like you, so you can't plug in ALL the cables and overload the rail.
6,483 (4.62/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Power supplies of this capacity cannot operate on a regular 100V AC line. The current load is too high. Specialty wiring and breaker is required to operate low voltage mains with devices that use this much power (for example, electric showers have a circuit all their own). This is why it's specifically rated for 230V AC mains. This is just a render of the power supply, or a preproduction unit using the housing of another model.
Oh yeah it's definitely going to "go" - go be deployed on practically every GPU from here on out, that is. Including AMD's ;)
freeagent
8,368 (3.75/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Needs a dryer plug to run in North America..
3,236 (1.07/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Replicating the issue with the 12VHPWR connector was difficult too. GN only managed to do so unintentionally, all instances of the issue came from the public.
Just because it isn't receiving media attention doesn't mean it isn't happening or couldn't happen.
12V2X6 only fixes one mode of failure for the connector, specifically it's ability to draw power when not fully seated. It does not fix the issue where bending the cable spreads the pins out leading to a potential runaway thermal scenario. It also doesn't fix the low safety margins. Pretty important given the 4090 already pushes those and the 5090 is slated to draw even more power.
Regardless of how rare people think the issues are, it is still an issue that prior connectors didn't have.
213 (2.39/day)
I had a bad power supply. To determine a power supply issue I bought another power supply unit from another brand to crosstest
For some reason some cables went loose while doing the cable management from the new power supply unit.
I crosstested with the cables from the bad power supply to see if the retention force was similar.
It's not always the user fault when new cables from the power supply unit are not in specifications.
In my case they did not had the retention force. Visually I could not see any differences. I do have the old and the new replacement cable set.
Therefore I knew the retention force was obvious defective and made a quality email claim to the psu manufacturer. I instantly got a new cable set for free.
This happened around 1.5 years ago with a brand with 5 years guarantee on psu.
It's just a matter of cables.
There are government regulations here which determines the cable type, wall socket type and so on.
I'll wait and see if AMD is smart enough to use existing cables or go with the NVIDIA plug. I would recommend AMD to not go with the NVIDIA GPU PSU Plug. I have one PSU with that plug lying around. I'm not that happy about the physical dimension of that plug
764 (0.23/day)
Earth's Troposphere
Mouse various/various/various
VR HMD -
You just don't get it now , do you?
As per the picture, it comes with just4 PCIe straight 8(6+2) because of Mr little green troll need of attention .
Where the 12 to 16 8pin ones(not accounting for EPS8 or 4+4)? No dayisychain -piggyback nonsense, nevermind , I got my fix for those .000001% extreme scenarios.
2,205 (0.32/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 5800X3D
Motherboard Asus Prime X570-Pro BIOS 5013 AM4 AGESA V2 PI 1.2.0.Ca.
Cooling Corsair H150i Pro
Video Card(s) XFX Radeon RX 7900 XTX Magnetic Air (24.10.1)
This.
i'm sticking with my current PSU for now and won't go newer until they clean this up.
927 (0.46/day)
The New England region of the United States
System Name Gaming Rig
Processor Ryzen 7 3800X
Motherboard Gigabyte X570 Aurus Pro Wifi
Cooling Noctua NH-D15 chromax.black
Memory 32GB(2x16GB) Patriot Viper DDR4-3200C16
Storage Samsung 970 EVO Plus 1TB (Boot/OS)|Hynix Platinum P41 2TB (Games)
Display(s) Gigabyte G27F
Case Corsair Graphite 600T w/mesh side
Audio Device(s) Logitech Z625 2.1 | cheapo gaming headset when mic is needed
Power Supply Corsair HX850i
Mouse Redragon M808-KS Storm Pro (Great Value)
Keyboard Redragon K512 Shiva replaced a Corsair K70 Lux - Blue on Black
VR HMD Nope
Benchmark Scores Nope
You wouldn't find a proper power cord for that. You need a NEMA 14-20/L14-20 outlet which does 240v at 20 amps. I've never seen them in a home, but they are pretty common in server rooms.
