Seasonic Prime Gold SSR-1300GD PSU enough for RTX 5090?
103 (0.04/day)
Hi, I am looking PSU for RTX 5090 . I found good deal for Seasonic Prime Gold SSR-1300GD.
It says 1300W, lots of connectors, etc. But don't have ATX 3.1 stuff.
Will it be enough?
4,861 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
Power won't be an issue with that unit but the use of adapter cables on a RTX 5090 can be. Since you are looking at new units, I would pass and get a quality ATX 3.X unit as there are enough headaches as is using 12V-2×6 cables with the RTX 5090.
103 (0.04/day)
Isn't it safe to use original cable adapter from NVIDIA???
I thought only 3rd party are melting. Also that 3.1
it melts even in PSU side :D. So here only GPU side can melt
4x 8 pin > 1x 12 pin.
103 (0.04/day)
Truth is, at this point everyone who gets a 5090 is part of a testing group. What is and what isn't safe is still quite unclear.
I think soon they will release 2x 12 pin variants and that's it. It will have headroom until 1000W TDP. Win win
4,393 (2.56/day)
System Name Mean machine
Processor AMD 6900HS
Memory 2x16 GB 4800C40
The nvidia octopus included in the gpu box is probably the safest thing there is. Your psu is fine, I don't have an atx3 either, my 4090 is still fine (bought it day one)
4,861 (0.97/day)
858 (0.24/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling Arctic Liquid Freezer III 420 Push/Pull -6 Noctua NF-A14 i and 6 Noctua NF-A14 i Meshify 2 XL
Memory CORSAIR Vengeance RGB RT 32GB (4x16GB) DDR4 4266cl16 - Patriot Viper Steel DDR4 16GB (4x 8GB)
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case Meshify 2 XL- TT 37 VIEW 200MM'S-ARTIC P14MAX
Audio Device(s) Sharp Aquos
Power Supply Seasonic Prime TX-1600 ATX3.1 | Fully FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum -
Mouse G502
Keyboard G413
Spending well over 2000 dollars on a 5090 , and cheaping out on a PSU ! I went with a Seasonic Prime TX 1600 watt atx 3.1 , 5090 is 4X the cost , if you can afford one and not the other ?? bunch of click bait and posers .
103 (0.04/day)
but why do I need 1600W for 600W card?
1600 is for 2x sli or smth.
4,393 (2.56/day)
Cheaping out? My PSU costs 450€, and the seasonic op is looking at is over 250. What the heck are you talking about bud?
Just ignore , the ATX spec has nothing to do with how safe the card is. ATX 3 psus are just supposed to handle spikes better. In fact a non ATX 3 PSU is safer when it comes to the melting issue since there is only one point of failure vs 2 on an ATX 3 PSU.
103 (0.04/day)
atx 3 difference in the first glance is 12 pin from psu instead of 8 pin ones, so it can melt not only in GPU but in PSU connector too.
4,393 (2.56/day)
Exactly. A non ATX 3 PSU doesn't use the 12 pin on the PSU side, so you avoid the melting on that side. You can also buy a cable that goes from PSU straight to 12vhp into your GPU if you don't want to use nvidias octopus
103 (0.04/day)
I want use NVIDIA octopus to blame them after it melts
43,731 (6.78/day)
The psu itself by output can handle it but the connection from nv on their gpus and the design spec of the psu side is a bad design.
212 (0.17/day)
Colorado
Processor AMD Ryzen 9 9950X
Motherboard Asus ROG Crosshair X670E Gene
Cooling Full Custom Water
Memory 48GB DDR5
Video Card(s) Nvidia RTX 5080 FE
Storage Crucial T700 2TB Gen5 SSD
Display(s) Asus PG32UQX
Case Primochill Praxis WetBench
Audio Device(s) SteelSeries Arctis Pro
Power Supply SeaSonic Prime SSR-1300TR2
Mouse G502 Lightspeed
Keyboard Keychron Q1 Max, Drop + Matt3o MT3 Susuwatari, Gateron Pro switches
Software Windows 11 Pro 23H2
Will it be enough?
There's no good reason to risk using an older 2.0 PSU with the old specification cable on a new 2025 GPU.
901 (4.37/day)
Let's assume Jay2Cents did his homework. He mentioned in one of his last videos that those newer NVIDIA graphic card connector cables have some sort of mark.
If I really wanted a nvidia 5090 - I would get a quality psu like your seasonic one and would get a newer revision with the newer marking for the nvidia gpu connector.
Checking for the correct seating before you use the hardware should be obvious.
As of now, in my point of view, Nvidia did not really state why it happens or gave any improvements. It could be anything, which also may be bad circuit design of the graphic card, bad circuit design of the power supply, cables, bad connectors on the psu side or bad connectors on the graphic card side. Nvidia did not really gave any statement. I think that issue happens for more than 12 months.
I would call that a hoax - not a proper way of dealing with an issue. Please check the date of this tech article / press statement / statement
103 (0.04/day)
instead of 1 12 pin meltage you get 2.
ATX 3 for you.
They should make 2x 12 pin cards for those beefy 600W GPU's
901 (4.37/day)
We have a dedicated topic with speculations and a lot of "troll" posts myself to a certain degree only about that connector. 30 sites of fun afaik.
I think opinions about that connectors belong to that other topic.
Post #1 Wattage should be enough. Brand is a very good brand as far as I know. You may check the cables - I think Seasonic make good cables also.
The only thing poster #1 did not say - if there are wishes for overclocking and shunt mods. I think some overclockers use 1600 Watt PSU.
4,861 (0.97/day)
you can be ATX 3.x using either a native cable or the dual 8 pin to 12 pin connector cable (not to be confused with the adapter). In fact if you use either form in 3.0 you are automatically 3.1 spec.
262 (0.48/day)
ATX 3 for you.
Nvidia octopus has the 12v-2x6 pins soldered to the pcb, so the pins won't move like in Jays video and you can bend the cables as much as you want until the pcb breaks. Nvidia can't blame you for using a 3rd party(psu cables are 3rd party) cable. PSU manufacturer can't blame you for using a cable that was not supplied with the psu.
