Set Sound Device - the solution for the WIN11 AUDIO system tray problem
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
System Name °( ఠ ͟ʖ ఠ)°
Processor Intel | i7 _ 11700K | @ ~ 5GHz all | cooling ~ Thermal Grizzly CARBONAUT
Motherboard Asus | ROG Strix -- Z 590-E wifi
Cooling Asus | ROG Ryujin 240 2* _Noctua F PPC °3000 | 4+1* _beQuiet_ Silent/Light Wings 3 °2200
Memory G Skill | Trident Z *RGB @ 4000_ | _15-15-15-36_ |
Video Card(s) Asus | ROG Strix -- RTX 3070Ti_ #OC Edition
Storage WD black | Samsung EVO 860 / 970 EVO plus| WDC WD40 | Intenso x2
Display(s) Alienware | AW3821DW _ 38" {3840*1600} wide - curved
Case be Quiet | DARK BASE PRO 900 --- _rev. 2 --- #Silver
Audio Device(s) Asus | ROG Throne - Qi_7.1 | LOGITECH_G560 Speaker (RGB)
Power Supply be Quiet | DARK Power PRO 12 __ 1200W *titanium
Mouse Razer | NAGA Trinity (19 buttons)
Keyboard Razer | Huntsman V2 analog | Razer Goliathus (RGB) black
VR HMD Razer | Kraken Ultimate HEADSET __7.1 THX ____| DX RACER - Gaming Leather Chair_____ VR?? is odd!
Software Windows ɧ.eliX
Benchmark Scores See signature URL
SetSoundDevice is THE TOOL to end the tiresome, awkward menu clicking in the WIN11 tray. :banghead:
Why M$ has made the windows 11 soundsettings so inconvenient remains a mystery...
Briefly explained:
You don't have to go to the control panel and select the source manually anymore, everyone knows the comfortable WIN10 audio control in the tray. :oops:
It runs simply via shortcuts that can be pinned in the start menu, or put at any other place where needed.
That was it! Problem solved.
I discovered this 1.11MB small file by stumble and I loved :love: it after one minute. For example, if you always want to set one and the same source directly after booting, you can also put the corresponding shortcut into the autostart. This also eliminates the need to "switch back". No need to install by the way. U can make it invisible after setting up as well.
The author has provided this free solution with a donate button. Maybe you are merciful... :toast:
The five years old file is attached below. The web never forgets..
:rolleyes:
Sesame Street Reaction GIF by HBO Max
  • SSD.exe
