Set up RGB cooler without rgb header
34 (0.02/day)
Europe - Austria
System Name Main computer
Processor i7-6700K
Motherboard ASUS Z270F
Cooling Alpenföhn Ben Nevis
Memory 32GB Corsair
Video Card(s) ASUS RX 480 ROG STRIX 8GB
Storage Samsung M.2 SSD 960 Evo
Display(s) AOC 32" 4K and LG 27" 4K
Case Fractal Design Focus G grey
Audio Device(s) SoundBlaster ZXR
Power Supply Bequiet Straight Power 11 650W
Mouse Logitech M570 Trackball
Keyboard DBPOWER USB Gaming
Software Windows 10 x64 Pro
I will install a Silverstone PF240 ARGB watercooler within the next days, but my ASUS Z170 Deluxe Board has no RGB header. I could mount a RGB controller but I don't like blinking lights and only want to set up the colours once.
Is ist possible to set the RGB light once (for example with a USB-adapter) via software and then run the cooler without an active rgb controller?
2,743 (0.68/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
Certainly possible, but would probrably just keep doing it's default color pattern if not actively controlled somehow.
Unless you can actually change what this default pattern would be, that's what I'd expect it to do.
Others with setups using RGB may know of a way to do what you're asking for.
34 (0.02/day)
Europe - Austria
Processor i7-6700K
Memory 32GB Corsair
Thank you. I have also second computer with an ASUS Z270A Board with Aura RGB Headers. I could try to set the lights up with this Mainboard and then mount it on the Z170 Deluxe
newtekie1
Semi-Retired Folder
28,473 (4.08/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
AFAIK, the PF240 comes with a tiny ARGB controller in the box. Just mount it somewhere and use that to control the RGB on the cooler. You can then just use that controller to set the color you want and forget it. I don't see the problem in having the ARGB controller in the case, just tuck it away somewhere and forget about it.
