Sharkoon Announces Light² S Lightweight Gaming Mouse
47,449 (7.50/day)
Sharkoon Technologies is an international supplier of high-performance quality PC components and peripherals. Sharkoon now presents the Light² S, a gaming mouse that is extremely smooth to handle due to its low weight. The gaming mouse not only promises unrestricted freedom of movement, but also the symmetrical shape of the mouse makes it suitable for both right and left handers. The downloadable software also offers additional features for a high degree of customization.
Due to its completely symmetrical design, the Light² S can be used with either hand and is therefore suitable for both right-handers and left-handers. Corresponding to this, the Light² S has two thumb buttons on each of its sides. These can be freely assigned via the downloadable software, which allows the functions of all the mouse buttons to be modified to suit the user's needs. According to Sharkoon, because of the uniform shape of the gaming mouse, it should lie comfortably in the hand and, in conjunction with the special honeycomb structure, ensure a firm grip for both right-handed and left-handed users.
A Robust Lightweight
As the latest gaming mouse in the Light² range from Sharkoon, the Light² S also remains true to the tradition of the series and, thanks to the honeycomb structure of the housing, weighs only 78 grams. This should result in smooth handling and a noticeably feather-light feel. Nevertheless, according to the manufacturer, the mouse is very robust thanks to its well-designed housing and should therefore also be suitable for long periods of use.
Unrestricted Flexibility
According to the manufacturer, the light weight of the Light² S should allow quick and fluid movements at all times so that the user can always keep events under full control. The uncomplicated handling is also supported by the four mouse feet made of 100 percent PTFE, which allow the mouse to glide smoothly over the mouse pad and other surfaces. In addition, the ultra-flexible, textile braided cable should provide maximum flexibility.
Precise Handling
Perfect tracking and top degrees of precision are provided by the high-performance PixArt PAW3327 optical sensor. With a resolution of up to 6,200 DPI, the sensor should allow high-precision maneuvers and, using the Light² S software, can also be customized within five freely adjustable levels. With the help of the DPI switch, the levels can also be easily switched through at any time, always enabling situational adjustment according to different genres and usage behavior.
Varied Illumination
The atmospheric lighting of the Light² S is generated by a light strip running around the mouse. The strip sets colorful accents on the mouse body and emphasizes its streamlined design. In addition, the illuminated Sharkoon logo is recognizable as a subtle highlight through the honeycomb structure at the back of the mouse. Via the downloadable software of the Light² S, the lighting can also be customized with a wide selection of effects and colors from the entire RGB spectrum.
With the Light² 200 White Edition from the same product range, Sharkoon has also introduced another gaming mouse. This was launched on 22 October this year and corresponds to its black counterpart. At 62 grams, the Light² 200 White Edition is not only one of the lightest mice in the world but is also extremely accurate with its high-precision sensor of up to 16,000 DPI. With five mouse feet made of PTFE for very smooth gliding properties and a customizable modular design, the Light² 200 White Edition from Sharkoon provides technology at an e-sport level.
Price and Availability
The Sharkoon Light² S is now available at the manufacturer's suggested price of 24.99 euros, and the Sharkoon Light² 200 White Edition is available at the manufacturer's suggested price of 49.99 euros.
6,374 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
If these drilled-out/swiss-cheeze rodentia get any lighter, you'll have to turn down your fans to keep them from sucking them into your case or blowing them off your desk, hehehehehe :)
172 (0.03/day)
These mice are becoming more and more stupid every release, I've been looking to replace my old G5 and cant find anything close
504 (0.13/day)
Cyprus
Processor 13700KF - 5.7GHZ
Motherboard Z690 UNIFY-X
Cooling ARCTIC Liquid Freezer III 360 (NF-A12x25)
Memory 2x16 G.SKILL M-DIE (7200-34-44-44-28)
Video Card(s) XFX MERC 7900XT
Storage 1TB KINGSTON KC3000
Display(s) FI32Q
Case LIAN LI O11 DYNAMIC EVO
Audio Device(s) HD599
Power Supply RMX1000
Mouse PULSAR V2H
Keyboard KEYCHRON V3 (DUROCK T1 + MT3 GODSPEED R2)
Benchmark Scores Superposition 4k optimized - 20652
78g is not light enough to warranty those holes, stop using holes unless you are under 60g, it doesn't make ANY sense.
671 (0.43/day)
Austria
System Name nope
Processor I3 10100F
Motherboard ATM Gigabyte h410
Cooling Arctic 12 passive
Memory ATM Gskill 1x 8GB NT Series (No Heatspreader bling bling garbage, just Black DIMMS)
Video Card(s) Sapphire HD7770 and EVGA GTX 470 and Zotac GTX 960
Storage 120GB OS SSD, 240GB M2 Sata, 240GB M2 NVME, 300GB HDD, 500GB HDD
Display(s) Nec EA 241 WM
Case Coolermaster whatever
Audio Device(s) Onkyo on TV and Mi Bluetooth on Screen
Power Supply Super Flower Leadx 550W
Mouse Steelseries Rival Fnatic
Keyboard Logitech K270 Wireless
Software Deepin, BSD and 10 LTSC
Holes in a mouse, i think its funny to clean:roll:
1,823 (0.61/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
What's with every new mouse having holes.... Didn't Glorious do this first?
14,234 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Less material used in production = cheaper to make.
Marketing selling these holes as a positive, lol.
3,301 (0.53/day)
System Name Thakk
Processor 9800X3D
Motherboard MSI B650M Gaming Wifi
Cooling Id Cooling A410 + 2400 RPM push pull
Memory 32GB DDR5 6000 C30
Video Card(s) Zotac RTX3080 Trinity
Storage Crucial NVME 512 / Intel 250GB SSD / Samsung Pro 512 SSD / SanDIsk 1TB SSD / WD Black 6TB
Display(s) Acer Predator X34 100hz IPS Gsync
Case Generic mATX
Audio Device(s) Hyper X 7.1 USB Soundcard
Power Supply Corsair CV750 Bronze
Mouse Logitech G200
Keyboard Monsgeek MG75S Hall Effect + XDA Keycaps + Holee Mod
VR HMD HTC Vive
Software Windows
Benchmark Scores https://www.3dmark.com/3dm/123890762?
This is one trend I can't wait for to end. Holes on a mouse
2,555 (0.79/day)
I want it to glide like a air hockey puck. Speaking of which I wonder if anyone has ever put their mouse on a air hockey table and tried it. I would think the tiny holes in the table would be a sensor problem unfortunately, but how it would feel would be fascinating to know.
