Sharkoon Designs Fans With Modular Cable System
47,229 (7.55/day)
Flexible cable management is now available for fans. At CeBIT Sharkoon will be showcasing a new innovation in fan design: a case fan with modular cable system. The Sharkoon Silent Eagle SE features a 4 pin connector built into the fan's frame and comes with four different cables for connecting the fan to a mainboard, fan controller or power supply. The fan can be used with a CPU cooler or as a case or hard drive fan. The speed of the fan can be controlled via PWM signal or through three different cables directly connected to the power supply. Users can, according to need, choose the connection type, fan speed, and consequently the loudness and purpose for which the fan is used. Sharkoon offers the Silent Eagle SE in 80mm and 120mm.
Four cables are included with the fan, and include a 4-pin PWM cable that can be controlled by the mainboard and three cables with Molex connectors that limit the voltage to 12, 9 or 7 volts. The 30cm long cables are individually labelled and colour coded for easy reference as well as featuring a robust casing. Sharkoon also offers separately a 60cm cable for users with large cases. The Silent Eagle SE operates with an efficient, low-noise motor that provides silent operation under each connection. The 80mm fan has a maximum rotation of 2000 rpm and, depending on rotation, a noise level of between 6.5 and 22 dB(A). The 120mm fan has a maximum rotation of 1200 rpm and maximum loudness of 20.5 dB(A).
For Optimal airflow the fan features the typical Silent Eagle golf ball design. The surface of each blade has countless dimples, lowering resistance and limiting turbulence, in order to reduce noise at all speeds. In addition, the rounded frame helps to increase the flow of air. Included with the fan, in addition to the cables, are four screws to attach the fan or four rubber bolts that further dampen fan vibrations.
End customers will find the Sharkoon Silent Eagle Modular Fan available immediately from authorized retailers for the suggested retail price of 11 euros (80mm) and 13 euros (120mm). The optional 60cm extended cable is available separately for the suggested retail price of 2.49 euros. New for CeBIT: PC Fan with Modular Cable System
Sharkoon Silent Eagle Modular Fan: QuickConnect port with four cables for mainboards (PWM) and power supplies (7, 9 or 12V) / available in 80mm and 120mm / 60cm extended cable available separately / MSRP starting at 11 euros.
Fitseries3
Eleet Hardware Junkie
15,508 (2.48/day)
Republic of Texas
very good idea but its just an advancement of what delta is already doing.
jbunch07
5,260 (0.86/day)
Chattanooga,TN
Processor i5-2500k
Motherboard ASRock z68 pro3-m
Cooling Corsair A70
Memory Kingston HyperX 8GB 2 x 4GB 1600mhz
Storage OCZ Agility3 60GB(boot) 2x320GB Raid0(storage)
Display(s) Samsung 24" 1920x1200
Case Custom
Power Supply PC Power and Cooling 750w
Software Win 7 x64
Very good idea with the dimples on the fan blades...look like really nice fans. wonder how much air the push at 2000rpm?
h3llb3nd4
3,323 (0.58/day)
Durban, South Africa
System Name My mobo is Laughing at me
Processor E7400
Motherboard P5KPL-E Bios flashed to 0601 (Piece of poo!!)
Cooling Thermalright Ultra 120a
Memory GENERIC 2 GB DDR2 800
Video Card(s) NONE!! Beat that!!
Storage 500GB SAMSUNG SATAII, 250GB SAMSUNG SATAII and o'l crappy 4gb maxtor
Display(s) ACER X223W Q
Case AEROCOOL ZERODEGREE (planning to mod)
Audio Device(s) REALTEK ONBOARD
Power Supply GIGABYTE 460W
Software Win 7 x86 build 7022
Benchmark Scores Super Pi 1m 17.000 :(
wonder if they have one that is clear...
1,065 (0.16/day)
System Name [Primary Workstation]
Processor Intel Core i7-920 Bloomfield @ 3.8GHz/4.55GHz [24-7/Bench]
Motherboard EVGA X58 E758-A1 [Tweaked right!]
Cooling Cooler Master V8 [stock fan + two 133CFM ULTRA KAZE fans]
Memory 12GB [Kingston HyperX]
Video Card(s) constantly upgrading/downgrading [prefer nVidia]
Storage constantly upgrading/downgrading [prefer Hitachi/Samsung]
Display(s) Triple LCD [40 inch primary + 32 & 28 inch auxiliary displays]
Case Cooler Master Cosmos 1000 [Mesh Mod, CFM Overload]
Audio Device(s) ASUS Xonar D1 + onboard Realtek ALC889A [Logitech Z-5300 Spk., Niko 650-HP 5.1 Hp., X-Bass Hp.]
Power Supply Corsair TX950W [aka Reactor]
Software This and that... [All software 100% legit and paid for, 0% pirated]
Benchmark Scores Ridiculously good scores!!!
Those are some nice looking fans. Innovative too. I hope other manufacturers will pick this up as well. Sharkoon? I believe I've seen their products here and there. Mostly budget cases and such. They are sort of like the European version of Aerocool. Decent quality products and affordable as well.
WarEagleAU
Bird of Prey
10,812 (1.61/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Huge fan of this idea. With the way most case makers do the fans and the wiring, this will help clean up some unkempt fan wires.
641 (0.10/day)
Processor Intel i5 3550
Motherboard ASRock Z77 Pro4-M
Cooling Thermaltake Performer 2.0 AIO Liquid Cooler
Memory 32GB Corsair Vengeance DDR3 1600mhz
Video Card(s) EVGA GTX 960
Storage Corsair Neutron 256gb Boot drive, ~7tb storage combined on other drives
Display(s) AOC 27" 1920x1080 IPS and Wacom Cintiq 13" HD
Case Fractal Design Node 804
Audio Device(s) Realtek HD audio, Pyle Pro PTA2 Amp, Sony SS-B3000 Speakers, Sennheiser HD595 headphones
Power Supply Antec 750W "High Current Gamer"
Mouse SteelSeries Diablo 3
Keyboard Rosewill Mechanical with cherry black keys
Software Windows 7 Ultimate 64
I wish more fan makers did this. I get tired of making my own 7v adapters to silence fans.
Nemesis881
690 (0.10/day)
Dawsonville, GA
System Name Nemy's comp
Processor AMD Athlon x2 4200+ @ 2.61ghz
Motherboard ASUS A8M2N-LA
Cooling 1x250mm (side), 2x120mm (one front and back), 6000+ stock cooler
Memory 3Gb Corsair value select PC2-4200 (2x512mb and 2x1gb))
Video Card(s) XFX HD7770
Storage 320gb Seagate Baracuda / 160gb western digital
Display(s) ASUS 19" widescreen LCD. 1440x900
Case Apevia Jupiter-JR S-Type
Audio Device(s) on-board. Audigy died D;
Power Supply Ultra 600W X-pro
Software Vista Home Premium
Not a bad idea at all! And yea those dimples help a good bit with the noise factor.
I think I'll stick with my Scythe fans though. They move A LOT of air at low RPM's and are near silent to boot.
42,078 (6.63/day)
the fan is nice n all but i did a comparison of their 120 m3/h and converted it to CFM, well 129.7 m3/h = 76.39 CFM at 36 dBA SK SE 1, Where the Antec Tri Cool 120= 79 CFM or 134.124 m3/h at 30 dBA- so this Fan is not exactly the better deal, maybe if they would add more blades to it, now the SE2s charts that you can download via PDF doesnt exactly Specify CFM at max RPM
2,258 (0.38/day)
System Name Budget AMD System
Processor Threadripper 1900X @ 4.1Ghz (100x41 @ 1.3250V)
Motherboard Gigabyte X399 Aorus Gaming 7
Cooling EKWB X399 Monoblock
Memory 4x8GB GSkill TridentZ RGB 14-14-14-32 CR1 @ 3266
Video Card(s) XFX Radeon RX Vega₆⁴ Liquid @ 1,800Mhz Core, 1025Mhz HBM2
Storage 1x ADATA SX8200 NVMe, 1x Segate 2.5" FireCuda 2TB SATA, 1x 500GB HGST SATA
Display(s) Vizio 22" 1080p 60hz TV (Samsung Panel)
Case Corsair 570X
Power Supply Seasonic X Series 850W KM3
Flyordie Approved.
:toast:
633 (0.10/day)
Australia
System Name _Speedforce_ (Successor to Strike-X, 4LI3NBR33D-H, Core-iH7 & Nemesis-H)
Processor Intel Core i9 7980XE (Lapped) @ 5.2Ghz With XSPC Raystorm (Lapped)
Motherboard Asus Rampage VI Extreme (XSPC Watercooled) - Custom Heatsinks (Lapped)
Cooling XSPC Custom Water Cooling + Custom Air Cooling (From Delta 220's TFB1212GHE to Spal 30101504&5)
Memory 8x 8Gb G.Skill Trident Z RGB 4266MHz @ 4667Mhz (2x F4-4266C17Q-32GTZR)
Video Card(s) 3x Asus GTX1080 Ti (Lapped) With Customised EK Waterblock (Lapped) + Custom heatsinks (Lapped)
Storage 1x Samsung 970 EVO 2TB - 2280 (Hyper M.2 x16 Card), 7x Samsung 860 Pro 4Tb
Display(s) 6x Asus ROG Swift PG348Q
Case Aerocool Strike X (Modified)
Audio Device(s) Creative Sound BlasterX AE-5 & Aurvana XFi Headphones
Power Supply 2x Corsair AX1500i With Custom Sheilding, Custom Switching Unit. Braided Cables.
Mouse Razer Copperhead + R.A.T 9
Keyboard Ideazon Zboard + Optimus Maximus. Logitech G13.
Software w10 Pro x64.
Benchmark Scores pppft, gotta see it to believe it. . .
Ive been doing this to all my fans for years. Its the best way. I prefer to do my own due to the custom length of cables. If this was released years ago i would have went for it :)
633 (0.10/day)
Australia
I bet they are going to rip you off on cables.
ROFL : Cables sold seperately ?
" The optional 60cm extended cable is available separately for the suggested retail price of 2.49 euros. " <--< Is that 2.49eu each ?
OnBoard
3,033 (0.46/day)
Finland
Processor Core i5-750 @ 3.6GHz 1.136V 24/7
Motherboard Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby!
Cooling Alpenföhn Brocken HeatpipeDirectTouch
Memory Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24
Video Card(s) Gigabyte GTX 460 1GB OC (mostly stock speeds)
Storage OS: Samsung F3 500GB Games: Samsung F1 640GB
Display(s) new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD
Case new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans
Audio Device(s) new! ASUS Xonar DG & JVC HA-RX700 headphones
Power Supply Cougar CM 700W Modular
Benchmark Scores Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging
"Four cables are included with the fan, and include a 4-pin PWM cable that can be controlled by the mainboard and three cables with Molex connectors that limit the voltage to 12, 9 or 7 volts. The 30cm long cables are individually labelled and colour coded for easy reference as well as featuring a robust casing. Sharkoon also offers separately a 60cm cable for users with large cases."
